Calculating the angle of a double-slit experiment
14 replies · 7K views
MadMartigan
So, my physics professor has been behind all semester long and basically taught the entire light wave and optics chapters in a single day and explained absolutely nothing, hence massive confusion on the following problem:[In a double-slit experiment, the slit separation is 1.75 mm, and two coherent wavelengths of light, 425 nm and 510 nm, illuminate the slits. At what angle from the centerline on either side of the central maximum will a bright fringe from one pattern first coincide with a bright fringe from the other pattern?]
d (split separation) = 1.75 mm = 1.75E-3m
λ1 = 425 nm = 425E-9m
λ2 = 510 nm = 510E-9m
θ = ?
ΔX = dsinθ
dsinθ = mλ
[/B]
Now, I think it's a constructive interference since the question references the bright fringes, not that I think that necessarily matters.
I've tried working this a few different ways and I honestly don't know if I'm on the right track since my professor spent of all 5 minutes on this and just spat out the equations he gave us on the board.
My first thought was to just use ΔX = dsinθ and plug and chug using path length difference.
510nm-425nm = 1.75E-3m*sinθ
Which would result in a tiny angle of 2.78E-3° which seems super small and has me questioning if I've screwed up.
And if I use the 2nd equation and add the wavelengths and have m=1, I get an angle of 0.031°. Small, but larger.
Am I on the right track on either of these methods or am I missing a concept entirely because my professor didn't explain jack?
Homework helpers on the Physics Forums aren't supposed to just give out the answer, but I will try to steer you to the answer. ## \\ ## Bright spots occur in a two slit pattern when ## m \lambda=d sin(\theta) ## where ## m ## is an integer. Two bright spots will coincide if ## m_1 \lambda_1=m_2 \lambda_2 ## for ## m_1 ## and ## m_2 ## being integers. The idea is to find the smallest ## m_1 ## and ## m_2 ## that works besides ## m_1=m_2=0 ## which is the central maximum for both colors/wavelengths. Once you find that, then compute ## \theta ## from the equation ## m_1 \lambda=d sin(\theta)=m_2 \lambda_2 ##. Notice that your solution for ## m_1 ## and ## m_2 ## can be both negative or positive=the pattern is symmetric so that ## \theta ## can be positive or negative. ## \\ ## Editing: Additional item: You don't need to have ## m_1 \lambda_1=m_2 \lambda_2 ## to 3 decimal places. If you can find ## m_1 ## and ## m_2 ## that satisfy this approximately, that should be a correct answer. Editing some more... In fact, now that I have computed the answer, this one is exact.
Hahah. Haven't gotten to it. But I also checked with physics major friend and I think I understand the process now. We'll see when I go about answering.
I'll update with what I came up with after dinner.
Okay, I'm not sure if my math skills/reasoning are garbage right now, but I got m1λ1=m2λ2 to equal 425 nm using m1=1 and m2=0.8333333333
This leads me back to getting that angle of .0139°.
unless I've gone stupid, that is the actual angle right?
## m_1 ## and ## m_2 ## must be integers. .8333333 is not an integer. Try again=it's really kind of simple once you figure out the answer.
Brain fart.
m1 should equal 6 when λ1= 425nm. That results in 2550. As a result when λ2= 510nm, m2 should equal 5, resulting in 2550.
MadMartigan said:
Brain fart.
Good. Now all you need to do is finish it up by calculating ## \theta ##, remembering that these integers can also both be negative as well. The pattern of bright spots for the two-slit interference pattern is symmetric about m=0 ==>> i.e. symmetric about ## \theta=0 ##.
MadMartigan said:
angle is approx .088 right?
I assume the units for your angle is degrees (and not radians). I get a slightly different answer. Scratch that=I remebered the slit spacing incorrectly. With d=1.75 mm, I think your answer is correct=in degrees.
MadMartigan said:
yes, that was in degrees.
I get .084, but I'm doing it without a calculator. Please check your arithmetic=I think I calculated it correctly.
Might have had a typo. You're closer. It should come out to 0.0834
