Calculating the electric field, multiple point charges
10 replies · 27K views
aliaze1
What are the strength and direction of the electric field at the position indicated by the dot?
Part A:
Give your answer in terms of the horizontal and vertical components, separated by commas. Take the positive directions to be up and to the right.
Part B:
Specify the strength of the electric field.
[1/(4πε0)]*(|q|/r2)
[1/(4πε0)]=9*109
q1=-5*10-9
q2=10*10-9
q3=10*10-9
r1=0.02m
r2=0.04m
r3=√(0.002)=(0.002)0.5=~0.0447m
E1={[9*109]*[5*10-9]}/(0.02m)2
E2={[9*109]*[10*10-9]}/(0.04m)2
E3={[9*109]*[10*10-9]}/(0.002m)
E1=112500 j
E2=56250 i
E3=45000
E3_i=45000*(0.04/0.0447)=40249 i
E3_j=45000*(0.02/0.0447)=20134 j
Right is positive, therefore:
E2= -56250 i
E3_i= -40249 i
ETotal_i= -56250 + -40249 = -96499 i
ETotal_j= 20134 + 112500 = 133534 j
This is coming out as 'incorrect', and therefore I cannot proceed to part 2
Where am I going wrong?
Thanks!
neutrino said:
You need to redo E3.
typo, sorry, E3 is actually 45000, unless you mean that that is also incorrect
Oh, okay. 45000 is correct.
I just calculated the x-comp. of E3 and it comes out to 40,268.45638, while your answer is off by almost 20 N/C. I think it's a calculation error somewhere.
yea idk for some reason my calculator is giving me the 40249.22359..., anyways, is my y-component correct? i have very few attempts left
thanks
Part A:
Part B:
[1/(4πε0)]*(|q|/r2)
[1/(4πε0)]=9*109
q1=-5*10-9
q2=10*10-9
q3=10*10-9
r1=0.02m
r2=0.04m
r3=√(0.002)=(0.002)0.5=~0.0447m // r3 = 0.4472
E1=112500 j
E2=56250 i
E3=45000
E2= -56250 i
E3_i= -40249 i
Thanks!
The answer is E(0,0.2) = (-964.15,-922.9) where E(0,0.2) = 1334.7
please correct the value of r3, then everything should fall into place.
I got (-96392,-92272)
your J value is incorrect. your e1 is incorrect. using the correct sign convention, since e1 is a negative charge, it pulls the dot towards it. not away, therefore e1 should be negative since up and right is positive
