Calculating Electric Flux Through a Rectangle with Given Electric Field
The discussion focuses on calculating the electric flux through a rectangle with dimensions 3.60 cm by 4.50 cm in the presence of an electric field represented by the vector E = (80.0i + 50k) N/C. The correct formula for electric flux, Φ = E * A * cos(θ), is emphasized, where A is the area of the rectangle calculated as 0.00162 m². The initial calculation of electric field magnitude as approximately 94.34 N/C is noted, but the error lies in the misunderstanding of vector multiplication versus scalar multiplication. The correct approach requires incorporating the angle between the electric field vector and the normal to the rectangle's surface.
  • Understanding of electric flux and its formula (Φ = E * A * cos(θ))
  • Knowledge of vector operations in physics
  • Ability to convert units from centimeters to meters
  • Familiarity with calculating the area of geometric shapes
  • Study vector multiplication and its application in physics problems
  • Learn about the concept of electric field direction and its impact on electric flux
  • Explore examples of electric flux calculations involving different geometries
  • Review unit conversion techniques for physics applications
Students studying electromagnetism, physics educators, and anyone seeking to understand electric flux calculations in the context of electric fields.
arileah
Hello,
A 3.60cm x 4.50cm rectangle lies in the xy-plane. What is the electric flux through the rectangle if E=(80.0i + 50k) N/C ?
Φ = E * A =EAcos(θ)
My attempt:
First convert the rectangle units from cm to m.
4.50cm = 0.045m
3.60cm = 0.036m
Find the area of the rectangle.
A = 0.036m x 0.045m = 0.00162 m^2
Find the magnitude of the electric field.
E = sqrt (50^2 + 80^2) = 94.34 N?C (aprox.)
Multiply the two,
electric flux = E * A = 0.15283 Nm^2 / C (aprox.)
However, this answer is wrong. Could anyone point me in the right direction? I am not sure how to incorporate the cosine into this. Thank you.
BvU said:
Your error is at the point where you multiply the two: that is a vector multiplication, not a magnitude multiplication.
Thanks!
