Calculating the percentage of silica
  • Thread starter Thread starter xiphoid
The discussion focuses on calculating the percentage of silica in a partially dried clay mineral sample. The original sample contained 12% water and 45% silica, leading to a non-water component of 88%. After drying, the sample retains the same amount of silica and other components, but the water content decreases to 8%. Participants suggest using a hypothetical 100 g sample to simplify calculations, emphasizing the need to establish a relationship between the water content before and after drying to determine the new percentage of silica.
  • Understanding of percentage calculations
  • Basic knowledge of clay mineral composition
  • Familiarity with mass balance concepts
  • Ability to set up and solve equations
  • Learn how to perform mass balance calculations in mineralogy
  • Study percentage composition calculations in chemistry
  • Explore the effects of drying on mineral properties
  • Investigate the role of water in clay mineral behavior
Students in chemistry or geology, educators teaching mineral composition, and anyone involved in materials science or clay mineralogy.
xiphoid
A partially dried clay mineral contains 8% of water, the original sample contained 12% water and 45% silica. Then, the percentage of silica in the partially dried sample is nearly?
Don't know if this is would help in the calculation,
in the original sample, 12% water is present, hence non water components are consisting of 88%
Attempted one but was out of range of the concept to be used.
hi xiphoid! :smile:
hint: suppose the original sample was 100 g (12 g water, 45 g silica, 43 g other stuff) :wink:
I had that stuff in my mind but couldn't manage to calculate further
tiny-tim said:
hi xiphoid! :smile:
ok, after the sample has dried, the water is less but everything else is the same
so call it x g water, 45 g silica, 43 g other stuff, …
from the question, what equation can you find for x ? :wink:
11K
