Calculating the Required Section Modulus for a 200mm Wide Flange Beam
  • Thread starter Thread starter joemama69
    Beam
3 replies · 4K views
joemama69
A simple beam of length L = 5m carries a uniform load of intensity q = 5.8kN/m and a concentratexd load 22.5kN. Assuming stress allow = 110MPa, calculate the required section modulus S. Then select a 200mm wide flange beam (W shape) from the table. recalculate S taking into account the weight of the beam. select a new 200mm beam if necessary.
Of first I was trying to calculate the Mmax and i made a boo boo somwhere.
First I found the Moment about A
0 = 5.8(5)(2.5) + 22.5(3.5) - 5RB... RB = 30.25kN
About B
0 = 22.5(1.5) + 5.8(5)(2.5) - 5RA... RA = 21.25kN
Then so determine the Maximum Moment I was preparing the Shear & moment graphs. I took x starting from the left where x = 0 @ A
0<x<3.5
Force sum in y = 0 = RA - qx - V... V = 21.25 - 5.8x
Sum of M = 0 = RAx - qx2/2 - M... M = 21.25x - 2.9x2
3.5<x<5
Force in y = 0 = RA - qx - P -V... V = -1.25 - 5.8x
Sum of M = 0 = RAx - qx2/2 - 22.5(x - 3.5) - M... M = 78.75 - 1.25x - 2.9x2
when I graph the V's, the lines do not intersect... did i do something wrong. Would it even matter as long as I did the M's correctly. Could someone just double check my work.
  • 1.pdf
    1.pdf
on Phys.org
Your equations look OK. Max moment occurs at point of zero shear. Draw a shear diagram. There is an abrupt change in shear at the applied concentrated load. If you plot your 2 shear equations, they won't intersect at a common point because of the concentrated load discontinuity.
ok i found V = 0 @ x = 3.664
So pluged this into the second M equation and got Mmax = 35.7kN*m
S = M/[tex]\sigma[/tex] = 3.25X10^-4 what happened here
