Calculating the Steady State Value of Vc After Opening a Switch in a RC Circuit
The steady-state value of the capacitor voltage (Vc) after opening the switch in an RC circuit is calculated using the formula Vc = IR, where I is the current through the resistor. In this case, with a 1kΩ resistor and a current of 10mA, Vc equals 10V. The capacitor behaves as an open circuit at steady state, and the time taken for Vc to reach within 1 percent of its steady-state value can be determined using the equation Vc = Vie^(-t/RC).
  • Understanding of RC circuits and capacitor behavior
  • Familiarity with Ohm's Law (V = IR)
  • Knowledge of exponential decay in electrical circuits
  • Ability to solve differential equations related to circuit analysis
  • Study the concept of time constants in RC circuits
  • Learn about Norton and Thevenin equivalent circuits
  • Explore the use of Laplace transforms in circuit analysis
  • Investigate transient response in electrical circuits
Electrical engineering students, circuit designers, and anyone studying transient analysis in RC circuits will benefit from this discussion.
compEng
Please Help me with this problem or with understanding it. Thank you!
What is the stead-state value of Vc after the switch opens? Determine how long it takes after the switch opens before Vc is within 1 percent of its stead-state value.
Vc = Vie-t/RC
It doesn't look like you've attempted the solution. but I'll give you some tips.
when the system is in a steady state the capacitor acts as an open circuit (ie: all the current goes through the 1k resistor.)
what is the voltage across the 1k resistor at steady state: 1x10^3 x 10x10^-3
what do you know about elements connected in parallel.
I've made this part really obvious for you. finish the first part and attempt the second part and I'll give you some more help if you need it.
Good luck
okay i think I figured it out.
Because the capitor becomes an open circuit, and because it is in parrelel with the resistor it begins to imitate a Norton Equivilant circuit. and Vc=IR
Vc= 10 * 10-3 * 103 = 10
thank you!
