Calculating the volume of a function that rotates around the x-axis
  • Thread starter Thread starter jakobs
    Function Volume
To calculate the volume of the solid formed by rotating the function y = 1/x around the x-axis between x = 1 and x = 2, the correct integral setup is V = π∫(1 to 2)(1/x²)dx. The antiderivative of 1/x² is -1/x, leading to the evaluation of the integral from 1 to 2, resulting in V = π[(-1/2) - (-1)] = π/2. Some participants discussed alternative methods, such as using cylindrical shells, but the primary focus remained on the disk method. The final volume is confirmed as π/2 cubic units.
jakobs
y=(1/x) is rotating around the x-axis.
find the volume for the figure between x=1 and x=2
V=pi y2 = pi*(1/x)2
V= 1∫2 pi(1/x)2dx which gives V= 1∫2 pi(1/x2)dx
A primitive function for (1/x2) is -(1/x)
V=1∫2 pi((-(1/2))-(-(1/1)))
How do I go from here?
Why are you multiplying in your last line:
V=∫21 (pi)...
Once you have the antiderivative , you evaluate the antiderivative at the endpoints
2,1 respectively, and that is the value of the integral.
Sorry, I posted wrong, don't know what happened.
but pi*(-(1/2))=-1,57
pi*(-(1/1))=-3,14
-1,57-(-3,14)= 1,57
is this the right answer?
Yes, but a nicer answer would have been \frac{\pi}{2} units3.
V=pi y2 = pi*(1/x)2
Easily stated you want :
2π\int_{1}^{2}\frac{1}{x^2}dx
You could have also used :
π\int_{1}^{2}1dx
The OP correctly identified the volume of revolution to be V = \pi\int_{1}^{2} \frac{1}{x^2} dx.
π\int_{1}^{2}1dx
What mathematical reasoning gives this?
CAF123 said:
The OP correctly identified the volume of revolution to be V = \pi\int_{1}^{2} \frac{1}{x^2} dx.What mathematical reasoning gives this?
There are two formulas I remember from Stewart calc 4th edition which highlight the formulas to use when calculating volumes of solids.
\pi\int_{a}^{b}xf(x)dx
2\pi\int_{a}^{b}f^2(x)dx
I have come across the method of cylindrical shells, where for some rotation about y axis, V = 2\pi \int_{a}^{b} x f(x) dx
I was wondering if someone could attempt the problem in the OP using cylindrical shells, because I am always getting either π or π/4, not the required π/2.
π\int_{1}^{2}1dx
You've remembered incorrectly.
Show us what you tried. You should have had to split it up into two integrals.
I split it up into 2 regions: one integral using y limits from 1/2 to 1 and another from 0 to 1/2.
For the first region: V = 2\pi \int_{\frac{1}{2}}^{1} (\frac{1}{2} + y)(\frac{1}{y} - 1) dy , where the shell radius is 1/2 + y and it's height is 1/y - 1.
Then the region using y limits 0 to 1/2 was a rectangular region:
V = 2\pi\int_{0}^{\frac{1}{2}} y dy, where the height is a constant 1 unit.
Doing the integral does not give me the correct answer. Where am I going wrong?
Many thanks.
The shell radius in the first integral should simply be y.
Perfect, I must have thought that I was rotating about the line y = 1/2 at my first attempt, but I see why it is simply y: y is the distance from the axis of rotation, which is the x axis. I now have the correct answer.
Thanks again.
π\int_{1}^{2}1dx
It would be a good idea for you to review formulas that you "remember" to see if they are actually valid. The one above has nothing to do with this problem.
  • · Replies 20 ·
