Calculating Time Constant and Effective Resistance for a Parallel RC Circuit
The discussion revolves around calculating the time constant and effective resistance in a parallel RC circuit, specifically involving a resistor R1 connected to a capacitor C and another resistor R2. Participants express frustration over the lack of clear resources and formulas related to the time-dependent behavior of capacitors in DC circuits.
  • Participants explore the concept of effective resistance in a parallel configuration, questioning how to define it for a capacitor. There are attempts to analyze the circuit using current division and Thevenin/Norton equivalents. Some participants express confusion over the application of Kirchhoff's laws and seek resources for setting up differential equations.
The discussion is ongoing, with participants sharing their attempts to understand the circuit dynamics. Some guidance has been offered regarding the use of Kirchhoff's laws and simplification techniques, but there is no consensus on the definitions or formulas needed for the time constants.
Participants note the challenge of finding relevant resources for a specific circuit configuration involving two resistors and one capacitor, as well as the frustration with existing materials that focus on simpler or more complex scenarios.
galoisien
I am trying obtain some equations for an RC circuit that has a resistor R1 after a battery, which then splits into a capacitor C and a resistor R2 (the circuit closes after this point).
When I try to seek help online, the resources are quite unhelpful. I cannot seem for example, obtain any formulas for the time constant for a capacitor connected in parallel to a resistor. When I try to look up the effective resistance of a capacitor I get resources that talk about alternating current circuits!
I know that capacitors start at zero resistance in the beginning and increase in resistance later. I cannot for the life of me however seem to plot the effective resistance (reactance) of a capacitor.
At tau/2, what is the resistance of a capacitor? How would I obtain RC constants?
The reactance of a capacitor is a function of frequency. That's why you're finding all the discussions involving AC circuits. A step-function input, which is what I assume you have here as you're talking about a time constant, is comprised of an infinite combination of frequencies; there is no single number describing the reactance of a capacitor.
One thing you can do is use Thevenin and Norton equivalents to simplify the circuit to a basic RC circuit with only one resistor. If you're not familiar with these, just write down the loop equations, i.e. apply Kirchoff's laws, and solve them. It's pretty straightforward.
There has to be a value describing the resistance of a capacitor in a DC circuit, because if it's connected in parallel to a resistor, that resistance describes how much current is flowing through the resistor (as opposed to charging the capacitor).
I'm trying to analyse it as a current divider. The lack of any formulas is really annoying! What is the time-dependent resistance of a capacitor?
"If you're not familiar with these, just write down the loop equations, i.e. apply Kirchoff's laws, and solve them. It's pretty straightforward."
I can't figure out the time constants for this circuit... I need values as a function of time.
Okay every time they talk about Kirchoff's law for an RC circuit, I only see the example for a single resistor in series with a capacitor -- much too simple
OR multiple capacitors with multiple batteries and inductors and everything with a whole mess of equations -- much too complex.
where are some resources where I can get help for a two-resistor, one-capacitor, two-loop, one-battery circuit? I don't know where to start to set up a differential equation.
The problem is, your approach won't work because there is no such thing as a "time-dependent resistance of a capacitor."
The basic relationship between the voltage v across a capacitor and the current i into the capacitor C is
[tex]i = C\frac{dv}{dt}[/tex]
If I am trying to figure out how much current will pass through a capacitor given a resistor in parallel for some particular point in time.
I know, and I've already told you how to analyze this type of problem. If you're just going to ignore the suggestion, there's not much more I can say.
