Calculating Time for a Mass to Hit the Floor on a Pulley System
  • Thread starter Thread starter Havenater23
    Pulley Sliding
The discussion revolves around a physics problem involving a pulley system with two masses: a 10.0 g mass suspended above the floor and a 500.0 g mass resting on a table. The objective is to determine the time it takes for the 10.0 g mass to hit the floor from a height of 1.50 m. Participants express concerns about the lack of information regarding forces such as tension and friction, which complicates the setup of the problem.
  • Participants discuss isolating each mass and drawing free-body diagrams to analyze forces. There is a focus on determining the acceleration in terms of tension and the implications of assuming no friction. Questions arise about how to proceed with calculations once certain forces are identified.
The discussion is active, with participants attempting to clarify their understanding of the forces involved and how they relate to the motion of the masses. Some have made attempts to calculate acceleration and time, while others seek confirmation of their reasoning and calculations. There is no explicit consensus, but several productive lines of inquiry are being explored.
Participants note the absence of information about the force of friction, which is critical for calculating acceleration. The discussion also reflects on the assumption that friction could be negligible, which changes the dynamics of the problem.
Havenater23
A 10.0 g mass is tied to a string. The string is attached to a 500.0 g mass and stretched over a pulley , leaving the 10.0 g mass suspended above the floor. Determine the time it will take the 10.0 g mass to hit the floor if it starts out 1.50m above the floor.
I've set up the problem, but it seems almost impossible. There's just simply not enough info to solve it. You are missing : Force tension , Force Friction , and the overall acceleration.
My attempt isn't correct.
If someone could just tell me how to set it up in a simple way that would be great thanks
Could you please show a picture of the arrangement of the masses and pulley? Is the bigger mass on a horizontal table?
ehild
Isolate each mass and draw a free-body force diagram. Write the acceleration of each in terms of the tension in the string (an unknown force at this point).
Now, since they are connected by the (assumedly light, inextensible) string, the accelerations must be equal in magnitude. Solve for the tension.
What can you do once you've got the tension?
I honestly don't know, I was going to use the acceleration to find the time. In order to find the acceleration you need Force of friction; which I don't know how to find.
This is what I have once it is simplified :
Massb*g - Ff = a(Mass b + Mass A)
Which to find acceleration I need to know Ff. Once I know that I can plug the acceleration
into Vf^2 = Vi^2 + 2ad
Once I have found the Final Velocity I then can find time
Vf=Vi +at
Vf=Vi +at
So what happens if Ff = 0?
Then it would be unbalanced and accelerate based on the force of tension
Isn't that what is expected?
Hmm, true, I guess I didn't think about that, so if Ff = o then I can solve it like the way I have above ?
I'm going to make another attempt at it, when ever I'm done could you check my answer?
Well, to be fair you didn't show your work as to how you arrived at the acceleration expression, but the expression itself looked okay.
Alright, well I got 4 secs technically 3.9 . If you could check it I would really appreciate it.
Can you show your work? In particular, show the final expression and value you obtained for the acceleration, and your calculation of the time.
For Mass A aka 500G
the equation what setup like this :
Ft=MassA * a
(Orginally Ft-Ff=MassA * a ; til I knew to just forget friction)
Mass B was set up like so :
Mass B * G - Ft =Mass B * a
Substituting Mass A for Ft : Mass B * G - Mass A * a = Mass B * a
Arranged all acclamations on one side and all Gravity's on one side :
Mass B * G = Mass B * a + Mass A * a
Then factored
Mass B*G = a(Mass B + Mass A)
Found the acceleration and did the following :
Massb*g = a(Mass b + Mass A)into Vf^2 = Vi^2 + 2ad
Vf=Vi +at
Sorry, I'm not seeing your final value for the acceleration. Can you give me a number?
Taking the Mass B * G = A(Mass B + Mass A)Mass B = 10g = 0.01 kg
Mass A = 500G = 0.5 kg
0.01*9.8 = A ( 0.01 + 0.5)
0.098 = A 0.51
A = 0.19 m/s^2
Vf^2 = Vi^2 + 2 ad
Vf^2 = o^2 + 2 0.19(1.50)
Vf = 0.76
Then use this formula
Vf = Vi + a T
0.76= 0+ 0.19(t)
T= 4 seconds
Okay.
You can get to the time a bit quicker by going via d = (1/2)*a*t2, so that
[tex]t = \sqrt{\frac{2d}{a}}[/tex]
  • · Replies 18 ·
  • · Replies 40 ·
  • · Replies 29 ·
