Calculating Time to Reach Initial Velocity from Acceleration-Time Graph
  • Thread starter Thread starter Mandavi
    Graph Mechanics
3 replies · 2K views
Mandavi
Q-Figure shows the acceleration-time graph of a particle moving along a straight line.After what time the particle acquires its initial velocity?The graph is attached.
We know that change in velocity is equal to the area covered by an acceleration-time graph.
ie (v-u)=at
My logic is that the total change in velocity in 2 sec is 3 because (2+1/2*1*2).
So,if again initial velocity is to be reached,then the total change in velocity in negative direction should be 3.However,how should i calculate the time taken?
The velocity increases with contant acceleration. Then the velocity increases with linearly decreasing acceleration, and at some point the acceleration is actually deceleration (negative acceleration).
See - http://hyperphysics.phy-astr.gsu.edu/hbase/acons.html#c3
http://hyperphysics.phy-astr.gsu.edu/hbase/avari.html#c1
One needs to write the expression for acceleration for each period, and apply the appropriate limits to the integrals.
The period of constant acceleration is straightforward.
Velocity and displacement when acceleration is constant - http://hyperphysics.phy-astr.gsu.edu/hbase/mot.html
You can calculate like it's explained above and you can also calculate it by calculating area.
You said it yourself that the total change in velocity in negative direction should be 3.
If you have a triangle with a and b (take a look at picture I attached), the area under that triangle is 1/2*a*b=3. Compare that triangle with the one on the left in positive area to extract a (time).
It was just a matter of applying similarity.Thanks a lot method_man!:-)
