Calculating Voltage Across Capacitor Using Node Method and Phasors
  • Thread starter Thread starter magnifik
    Capacitor Voltage
2 replies · 3K views
magnifik
i am trying to find va in the circuit below
i am using the node method via phasors and am wondering is va = (v1 - v2)/Zc??
where v1 is the node voltage between the 1/2 F capacitors on the left and v2 is the node voltage between the 1/2 F capacitors on the right
or is it just equal to v1 - v2?
thanx
magnifik said:
i am trying to find va in the circuit below (it is kind of blurry, but va is the voltage between the terminals in the middle 1/2 F capacitor)
thanx
You are guessing.
Make a full attempt, otherwise you won't learn anything.
Label each of the two nodes above the inductors (say, node L and node R) and preform the nodal analysis. (i.e. KCL combined with Ohm's law)
Also, write an equation describing Va in terms of these node voltages.
Show us your equations/work.
Note that the units for (v1 - v2)/Zc are amperes... this should answer your question.
