Calculating Voltage Drop in an AC Circuit with a High Power Supply and Motor
To calculate the voltage drop in an AC circuit with a 1200 V power supply and a 100 W motor, the current is determined using the formula I = P/V, resulting in 0.083 A. The voltage drop across the wires, calculated using V = IR with a resistance of 7.0 ohms, is 0.58 V. It is important to use RMS values for current and voltage in AC circuits, as they reflect the effective values under load. The voltage at the motor should be calculated as the supply voltage minus the voltage drop across the wires, leading to a voltage of 1200 V - 0.58 V. Understanding the circuit as a voltage divider with the motor's impedance is crucial for accurate calculations.
Sarah88
Now suppose the power supply is 1200 V, and the motor is rated at 100 W at this higher voltage. If the wires have a resistance of 7.0 ohms, what is the voltage drop across the wires? The voltage at the motor?
Power= Irms*Vrms
V=IR
In terms of the voltage drop across the wires I did: V= IR, I= 100W/1200V= .083 A therefore V= .083A*7.0 ohms = .58 V. However, why is Irms instead of maximum current used to calculate the voltage drop? Also, should the voltage at the motor simply be 1200V, or should it be 1200V-IR (from the resistor)? Thank you!
Unless otherwise stated, usually the circuit voltages, currents, and ratings for components like motors assume RMS values.
The rating for a component like a motor assumes ideal conditions (no resistance in the wires from the power source). Your circuit conditions are not ideal, since the wires have resistance. I would suggest first determining an equivalent impedance for the motor from the rating information, and then drawing the circuit. The impedance of the wire and the impedance of the motor will form a voltage divider.
Perfect, thanks!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
