Calculating Volume of Solid Using Triple Integral
physics&math
1. Use a triple integral to find the volume of the given solid.
The solid enclosed by the cylinder x^2 + z^2 = 4 and the planes y = -1 and y + z = 4
This looked like a cylindrical coordinate system to me, except for the fact that it is not cylindrical around the z-axis but the y-axis. I tried to fix this problem by "rotating" my coordinate axes so that my old z-axis would be my new x-axis, x would become y, and y would become z. I'm not sure if this is a valid approach or not.
It makes no difference mathematically how we name the coordinate axes. The coordinate system ##(r,\theta,y)##, with
##x=rcos\theta##
##z=rsin\theta##,
is as valid a cylindrical coordinate system as the usual ##(r,\theta,z)##.
Now the volume element is ##dxdydz=rdrd\theta dy##. Note that because of the plane ##y+z=4## all of the integration limits in the volume calculation are not constants, one of them is a function of ##r## and ##\theta##.
Hilbert1 is absolutely correct. However, if you lack his sophistication, you can just rewrite the problem switching the y and z. They are just symbols, right?
Thank you both so much!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
