Calculating Work Done by Gravity on Thrown Ball
The discussion focuses on calculating the total work done by gravity on a 0.113-kg ball thrown vertically from a height of 2.07 m with an initial speed of 7.6 m/s. The key equations utilized include the work-energy principle, where the total work done is equal to the change in kinetic energy. The gravitational force acting on the ball is defined as 9.81 m/s², and the total work done by gravity during the ball's descent to the ground is calculated to be 2.29 Joules. The discussion clarifies that while the ball is in motion, the work done by gravity is determined by the vertical displacement from the initial height to the ground.
  • Understanding of Newton's laws of motion
  • Familiarity with the work-energy theorem
  • Basic knowledge of gravitational force calculations
  • Ability to apply kinematic equations
  • Study the work-energy theorem in detail
  • Learn about gravitational potential energy calculations
  • Explore kinematic equations for projectile motion
  • Investigate the effects of air resistance on falling objects
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of work done by gravity in real-world scenarios.
BuBbLeS01
A 0.113-kg ball is thrown straight up from 2.07 m above the ground. It's initial vertical speed is 7.6 m/s. A short time later, it hits the ground. Calculate the total work done by the force of gravity during that time.
can I use...
1/2mv^2 = mgh
1/2v^2 - gh = W
Think of the problem like this:
What is the initial energy of the ball? (When it is thrown)
What is the final energy of the ball? (When it lands)
If you know those two quantities, you should be able to find the work.
Work done = Force x Displacement. What is gravitational force acting on the ball? What is the displacement (not distance travelled) between the initial position and final positions of the ball?
W=Fd
gravitational force = g
displacement = 2.07m
Okay so I am not understanding this problem. Apparently from 2.07m and above there is no work done but I don't know why?? And I get...
W = Fd
Ug = mgh
K = 1/2mv^2
Wtot = mgh = 2.29J
I was trying to do W = Change in K + change in Ug...why is this not the case?
The total work done on the ball is given by the ball's overall change in kinetic energy. When the ball goes up from its initial height, and reaches the top of its path, its kinetic energy has decreased. When it comes down from the top and back to that same initial height, its kinetic energy has increased. The decrease and increase in kinetic energy will add to zero, because we're ignoring air resistance. You want to find the change in the ball's kineteic energy from 2.07m to the ground. Does that help?
Oh okay...thank you that makes sense!
  • · Replies 29 ·
11K
  • · Replies 19 ·
  • · Replies 38 ·
