How Do You Calculate Luminous Flux for Different Wavelengths?
  • Thread starter Thread starter Amith2006
    Calculation Flux
The luminous flux for a radiant flux of 3 watts at a wavelength of 6000 Angstrom is calculated to be 1403.565 lumens using the formula: Total luminous flux = (radiant flux) x (Relative luminosity) x (Peak value of luminous efficacy in a photopic vision curve). The relative luminosity for 6000 Angstrom is 0.685, and the peak luminous efficacy is 683 lumen/watt. An alternative calculation suggests using 667 lumen/watt based on the conversion of one lumen to 1.5 x 10^(-3) watts for monochromatic light at 5550 Angstrom.
  • Understanding of luminous flux and radiant flux concepts
  • Knowledge of photopic vision and relative luminosity
  • Familiarity with the photometric unit lumen
  • Basic mathematical skills for calculations involving units and conversions
  • Research the calculation of luminous efficacy for different wavelengths
  • Learn about the photopic vision curve and its implications on luminous flux
  • Explore the relationship between radiant flux and luminous flux in various lighting conditions
  • Investigate the effects of different wavelengths on human perception of brightness
Optical engineers, lighting designers, physicists, and anyone involved in photometry or the study of light and its effects on human vision.
Amith2006
Please help me with this problem.
# A screen receives 3 watts of radiant flux of wavelength 6000 Angstrom. One lumen is equivalent to 1.5 x 10^(-3) watts of monochromatic light of wavelength 5550 Angstrom. If the relative luminosity for 6000 Angstrom is 0.685 while that for 5550 Angstrom is 1, then what is the luminous flux of the source?
I solved it in the following way:
Here radiant flux = 3 watts, Relative luminosity at 6000 Angstrom = 0.685, Peak value of luminous efficacy in a photopic vision curve = 683 lumen/watt
= 3 x 0.685 x 683
= 1403.565 lumens
Is it right?
Since you are given
perhaps you are meant to use 1/(1.5 x 10^(-3)) =667 lumen/W, not 683.
  • · Replies 25 ·
15K
