Automotive Calculation of the efficiency of an engine
Efficiency in an engine, particularly in the Otto cycle, is defined as the ratio of useful work output to heat input. The correct formula for thermal efficiency is (W_e - W_c)/Q_h, where W_e is the work of expansion, W_c is the work of compression, and Q_h is the heat input from fuel. It is important to note that work output does not include compression energy, making it incorrect to subtract it twice from the heat input. The discussion emphasizes that efficiency is a measure defined by human standards of usefulness, rather than purely a physical quantity. Ultimately, understanding efficiency requires distinguishing between work and heat as different forms of energy.
vroy
We know efficiency (η) = Woutput/Winput
Now in any cycle, for instance, the Otto cycle, let the total work output be WO, total heat added be WH & the total work done on the gas to compress it be WC.
Then, will efficiency be equal to (η) = (WO-WC)/WH ?
Or will it be equal to (η) = WO/(WH+WC) ?
There are lots of internal things that happen in an engine. Compression is one. Friction is another.
The only useful definition of efficiency is useful work out divided by work in. Out and in refer to things external to the engine. Useful is also necessary, because for example heat leaves the engine and warms up the environment. That's energy out, but it is not useful.
In other words, efficiency is a human measure that you define to be useful for your purposes. In that respect, it is less about physics, and more about your opinions.
It's neither. Work output already does not include the compression energy. You are subtracting it twice.
Defining the input power in the case of a liquid or gas fuel is not always straight forward. Here in the UK we have gas home heating boilers that are more than 100% efficient because of the way the input power was defined historically.
For an Otto cycle, there is no work input. There is heat input (Q_h) from the fuel. Work and heat are thermodynamically different forms of energy.
Taking the work of compression as W_c and the work of expansion as W_e the thermal efficiency is (W_e - W_c)/Q_h.
In words, it is the net output work divided by the heat input.
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
  • · Replies 50 ·
