Calculation of the net force on a test charge
19 replies · 3K views
Quanta
[itex]\overrightarrow{F} = \frac{1}{4\pi\epsilon_0}\frac{qQ}{r^2}\hat{r}[/itex]
I found to hard summarizing all forces directly adding each to other.
The solution of this problem is only matter of drawing the 13-sided polygon and forces acting on a test charge and summarizing them or there is something else ?
I think there is a trick to solve this...
Quite so. Unfortunately it is hard to give a hint that does not equate to being the solution.
Maybe think of it from the perspective of different q charges. Why would Q move towards one rather than towards another?
It seems, I have come to the right answer. If I take one particular [itex]q[/itex] charge, all other charges are placed in the same way as if another [itex]q[/itex] charge was chosen, because the 13-sided polygon has a symmetry. So net force on a test [itex]Q[/itex] charge will be zero. am I right ?
Right. kuruman's approach is good too.
But there is another problem that relates to this. Here is :
In this case charges are not symmetrically placed as in previous example. But we have one symmetry if we draw a line from the [itex]Q[/itex] charge to the missing [itex]q[/itex] charge.
I have an answer :
Why towards the missing [itex]q[/itex] ? Why exactly [itex]\frac{1}{4\pi\epsilon_0}\frac{qQ}{r^2}[/itex] ?
I have an answer :
Why towards the missing [itex]q[/itex] not opposite to it ? Why exactly [itex]\frac{1}{4\pi\epsilon_0}\frac{qQ}{r^2}[/itex] ?
Can you think of some other simple change that would have been equivalent to removing one charge q?
I tried with 5 sided regular polygon, removing one charge in the corner and adding graphically all force vectors I got net force vector directed toward missing charge. The same must be applied with 13 sided regular polygon without adding all vectors, from the figure we see that there is a symmetry represented by blue axis, forces from left and right sides cancel each other, so [itex]Q[/itex] should move toward the missing charge, because of gap between charges (and because of the more dense placement on the south side ?). The magnitude of force on [itex]Q[/itex] is [itex]\frac{1}{4\pi\epsilon_0}\frac{qQ}{r^2}[/itex] where [itex]r = r_1 + r_2 + ... + r_{12}[/itex]. Is everything ok ? Any corrections ?
I already know answer from the solution manual :
I want to get this answer with the help of logical reasoning without using any geometric properties of adding all vectors.
I have an explanation. When 13 charges were present the system was balanced, the applied force on [itex]Q[/itex] from any charge is [itex]\frac{1}{4\pi\epsilon_0}\frac{qQ}{r^2}[/itex] this is a force to maintain equilibrium, after removing charge system becomes unbalanced, so the net force points toward the missing charge and is [itex]\frac{1}{4\pi\epsilon_0}\frac{qQ}{r^2}[/itex].
haruspex said:
What, equivalently, could you add?
add charge(s)... but where ? I'm interesting where you're pointing me.
haruspex said:
If you have a charge q at point P, what charge could you add which is electrically equivalent to removing the charge q?
Opposite to it.
haruspex said:
We know that the q charges balance each other at the centre, so what is the effect there of adding the -q charge?
System will become unbalanced and ##Q## will move toward the ##-q##.
haruspex said:
But what is the magnitude of the force?
##Q ## and ##-q## have different signs, there will be attraction force between them with magnitude of ##\frac{1}{4\pi\epsilon_0}\frac{qQ}{r^2}##.
Yes, except that you cannot say what the signs of Q and -q are. It could be that Q is positive and q is negative. Then Q and -q will have the same sign. However, you can write that there will be a force of attraction of ##\frac{1}{4\pi\epsilon_0}\frac{qQ}{r^2}##. If Q and q have the same sign then Q and -q will have opposite sign, so it is indeed attraction; if Q and q have opposite sign then the force will be a repulsion, but that's ok because now ##\frac{1}{4\pi\epsilon_0}\frac{qQ}{r^2}## will be negative, and saying an attraction of ##\frac{1}{4\pi\epsilon_0}\frac{qQ}{r^2}## is the same as saying a repulsion of |##\frac{1}{4\pi\epsilon_0}\frac{qQ}{r^2}##|.
haruspex said:
Yes, except that you cannot say what the signs of Q and -q are...
I have no problems with signs, but thank you anyway. I appreciate your help.
Well, you wrote
Quanta said:
Q and −q have different signs
which suggests to me you do have a misunderstanding. If Q is +e and q is -e then Q and -q have the same sign: they are both +e.
