Calculus 3 Multi-Integration (volume)
23 replies · 3K views
IAmGroot48
In this particular question the following is stated.
Find the volume of the region below z=4(x²+y²), above z=0, and between the two cylinders x²+y²=1² and x²+y²=3².
This question doesn't necessarily say if the two cylinders are intersecting each other, so I'm not 100% clear how to go on about this question. If I could get an Idea on how to set this up or solve it. I'd be able to figure out the rest.
Pending
:welcome:
I'm not sure where the ambiguity is. The cylinders are concentric and the volume in question lies between them.
  • Skeptical
I feel like I may be over thinking this--I have ADHD so sometimes I have to read things over and over again to imagine what I am trying to do. Am I suppose to use triple integration for this or is this something double integration can do. What throws me off is the cylinder within the cylinder and then the region below z=4(x²+y²). I can't grasp where I am suppose to begin.
Initially I would think you could just do a single integration along z because of the symmetry of the surfaces. Can you try making a couple sketches to help you understand the geometry? Do one sketch from the side (say, looking down the x-axis with the y-axis to the right and z upward), and do one sketch in a perspective view looking at an angle down from the side (like along the line x=y=z)...
EDIT -- Mark mentions a double integral below, so I could be wrong about the simplification to a single integration...
Can you sketch a graph of the surface ##z = 4(x^2 + y^2)##? It's a paraboloid with its vertex at the origin, its axis along the z-axis, and opening upward. The two cylinders also have their axes along the z-axis.
The volume of the enclosed region can be calculated with a double integral.
This is what I am getting as far as the sketch. The paraboloid does indeed touch the origin, and then the surface z=0 is shown as a plane at well z=0. so from z=0 to z=4(x²+y²) is the first integration? In other words does the set up look like 4(x²+y²) dydx? and the first integration is from x²+y²=1² (bottom) to x²+y²=3² (top)?
Just Fyi: I am not the type of person who just wants the answer. I want to be able to find the answer myself for the most part but I want to understand why or how.
Was this rhetorical?
Parabolic!
  • Haha
I apologize I'm not sure what you're meaning when you only say parabolic.
Only that it's a parabolic question, rather than a rhetorical one.
I feel there was a funny thrown in there, but its almost got me thinking...slightly sparked an ember...
I suggest you look at cylindrical coordinates and figure our the range for ##r## or ##\rho##, whichever you use, for each value of ##z##.
Wow, nice sketch! What software package did you use to do that?
IAmGroot48 said:
View attachment 293873|
Normally I use autocad. But this is a simple piece of software you can easily get for free. You can get it on Microsoft Store and it's called Graphing Calculator 3, there's a free version and a pro version.
Ill show you the work I've done so far. I think it finally clicked. "I think"
Also...I am a firm believer every single website should have a Dark Mode from this point on 2022 and above. The bright white colors just murder my eyes...😵
-A Computer Engineer Major
We used to have different skins that you could choose from. Let me do a little searching...
I spoke with the Admin, and he will look at adding a Dark Mode in the 2022 updates. :smile:
Oh you rock! Thats awesome! I truly believe all websits should have that option. We're moving into a technological generation where a huge majority of our hardware is being ran by software so i feel we need to have dark mode to lessen the health concerns to our eyes. Sounds insane but a huge help to our optical system. Thank you.
As for this question. This is what I came up with.
My computers have an option to turn down the brightness. Have you tried that?Personally, I really dislike dark mode, as I find it harder to read, but hey, different strokes for different folks.
Yeah I am on the computer almost all day, so I need to take breaks from time to time. So even when I am learning to code I put my whole visual studio on a dark type format. I also use a software called Rainmeter to control all of my computers setting. Its an overlay for your whole desktop setting.
