Calculus area between two curves
The discussion revolves around finding the area between two curves defined by the equations y = x^2 and y = (x-2)^(1/2), along with the vertical line x = 0. Participants are exploring how to determine the common points of intersection and the limits for integration to calculate the area of the shaded region depicted in an image.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss methods for finding the intersection points of the curves and the appropriate limits for integration. There are suggestions to split the area into simpler parts for calculation and considerations of using horizontal versus vertical slices for integration.
The discussion is active, with various approaches being proposed. Some participants have offered guidance on how to set up the integrals, while others are questioning the best method to find the limits for evaluation. There is no explicit consensus on a single approach, but multiple interpretations and methods are being explored.
Participants are navigating the constraints of the problem, including the need to understand multivariable calculus concepts for double integrals and the implications of using different integration methods. There is also mention of an external image that is referenced for context.
dako
How to Find the area of ​​the shaded region in the image below:
http://i47.tinypic.com/263ed5d.jpg (without space)Hi, please help me with this:
How to find the common points in between the curves? and the area??
y= x^2
y= (x-2)^(1/2)
x = 0
I try to find the common point doing:
x^2 = (x-2)^(1/2) but I can't do it...
Simple. Split it into two halves, each of which you can calculate with a simple integral.
dako, you can simply edit your post and attach your picture directly without having to use an external image host. I've made the attachment in this post.
There is no need to split the region, as the latter is horizontally simple.
[tex]\int \int \,dxdy[/tex]
Hi..! thanks! but how may I find the limits to evaluate the integrals?
Describe the region:
For y fixed, x varies from x= to x=
y varies from y= to y=
If you want to use a double integral, I suggest you learn a bit about multivariable calculus. Basically, if I'm understanding correctly, what sharks is saying is (in singlevariable students' terms), is that if we integrate x with respect to y, we'll get the same result. That is, take horizontal slices instead of vertical ones in the "infinite rectangles" definition of the Integral.
Set the lines equal to each other to find the point of intersection. Then, integrate from 0 to that point plus from that point to the x-intercept of sqrt(2-x).
This is the solution:
Using horizontal
1 Doing x= f(y)
When y=√(2-x) , x=2-y^2
When y= x^2 , x =√y
The point in common is (1,1), we must evaluate from 0 to 1 this integral:
∫ 2-y^2 - √y dy
It must be 1.
Thanks!
  • · Replies 24 ·
