Why Can't I Derive the Euler-Lagrange Equation from Local Gradients in F?
MadRocketSci2
I have a question about calculus of variations that is driving me absolutely nuts right now:
I have followed the standard derivation of differential equations from the extrimization of a functional S = ∫(F(x,dx/dt,t)dt)
By doing some manipulation involving an arbitrary perturbation to your function, you end up with the folowing differential equation which has to be zero
dF/dx - d/dt(dF/d(dx/dt)) = 0;
I can sort of follow this, but I want to be able to derive this from the local properties of the function being integrated.
If the path taken is independent of the interval over which the functional is integrated (and it better be!) then there should be a way to arrive at the differential equation from nothing but the local gradients in F.
I have been trying to do this, and have encountered no end of trouble. My current line of reasoning is as follows:
dS/dt = F; We want to extremize dS/dt at every point t in order to extremize S overall.
d (dS/dt) over a specific interval dt = 0;
d (dS/dt) = dF/dx*dx + dF/d(dx/dt) * d(dx/dt) = 0;
The task then is choosing d(dx/dt) over the interval such that d (dS/dt) = 0;
dx over the interval must be dx/dt*dt or some combination of the derivatives of x in time.
d(dx/dt) is the acceleration d^2x/dt^2 * dt;
divide the time interval out.
dF/dx * xdot = dF/dxdot * xdotdot;
The strange thing about this is that it works for some specific problems, but does not yield equivalent results in general. I am getting the same answers for the principle of least action and the brachistochrone problem that I should be getting. But in other more general problems, the hypothetically minimized functions are slightly off for some reason.
Also, I am getting mysterious sign changes in certain terms (such as in the brachistochrone problem derivation).
Does anyone know where I might be going wrong? Do you see what I am trying to do?
Right at the start when you're considering dS/dt, this isn't valid because S isn't a function of time. Functions map numbers to numbers but S is a functional i.e. it maps functions to numbers. So basically, you can't differentiate S with respect to time as it doesn't depend on time (your integral should have limits!)
I hope this makes sense, I'm happy to explain further.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
