Calculus Problem - Properties of a Function
2 replies · 1K views
Joschua_S
Hello
I have a mathematical problem that I could not solve. Could you please give me some hints how to solve it?
Let [itex]f: [0,1] \rightarrow \mathbb{R}[/itex] be a continuous and on [itex](0,1)[/itex] a differentiable function with following properties:
a) [itex]f(0) = 0[/itex]
b) there exists a [itex]M>0[/itex] with [itex]|f'(x)| \leq M |f(x)|[/itex] for all [itex]x \in (0,1)[/itex]
Now the problem is: Show that [itex]f(x) = 0[/itex] is true for all [itex]x \in [0,1][/itex]
There is a hint given but it doesn't help me The hint is: Consider the set [itex]D = \{ x \in [0,1]: ~ f(t) =0[/itex] for [itex]t \in [0,x] \}[/itex] and show that the the supremum of this set is [itex]1[/itex].
Thanks for help
Greetings
What if we look at the interval ##I = [0, \frac{1}{2M}]## or ##I = [0, 1]##, whichever is smaller. This ensures that any point in ##I## will be no larger than ##\frac{1}{2M}##.
As ##f## is continuous on ##I##, so is ##|f|##, so ##|f|## achieves a maximum at some point ##x \in I##. If ##x = 0## then we're done. Otherwise, we can apply the mean value theorem to ##f## on ##[0,x]## and, with a bit of work, derive a contradiction.
P.S. The above will show that under the given hypotheses, we will have ##f(x) = 0## for all ##x \in I##. If ##I = [0,1]## then we're done. Otherwise, this shows that ##f(x) = 0## for all ##0 \leq x \leq \frac{1}{2M}##. In that case, you can repeat the argument for ##[\frac{1}{2M}, \frac{2}{2M}]## and so forth until you have covered all of ##[0,1]##.
