Calculus Rocket Problem (Derivatives)
The discussion focuses on a calculus problem involving a model rocket's height as a function of time, given by the equation y = 192t - 16t^2. The first derivative, representing instantaneous velocity, is calculated as y' = 192 - 32t, while the second derivative, indicating acceleration, is found to be y'' = -32. This negative acceleration suggests that the rocket is in free fall after its initial launch, which raises questions about the physical implications of the model. The maximum height of the rocket is determined to be 576 feet, reached after 6 seconds. The participants clarify that the negative acceleration is indeed correct, reflecting the effects of gravity acting on the rocket.
frumdogg
A model rocket is launched vertically upward. If it's position (height) y above the ground in feet as a function of time t in seconds is given by:
y = f(t) = 192t - 16t^2
1. Find the instantaneous velocity and acceleration at any time t.
Now this is my first calculus course on my long academic journey, but velocity is the first derivative and acceleration is the second.
Velocity -
y' = 192-32t
That was easy, but it is the second derivative (acceleration) that is stumping me:
y'' = -32
How is that possible.. negative acceleration the entire time?
Thank you for your assistance.
That's not much of a rocket! If y= 192t- 16t2, then the "rocket" provides an (instantaneious!) initial 192 ft/sec speed and then shuts down. The only force acting on it is that due to gravity. Are you sure that the y= 192t- 16t2 isn't from thepoint at which the rocket shuts off?
That is the equation, verbatim from the homework problem.
One of the other questions is (and I have done the work for it):
2. How high will the rocket reach?
192 - 32t = 0
-32t = -192
-32 = -32
total time = 6 seconds
192(6) - 16(36) = 576 feet
That's the correct approach. Plug your critical point back into your equation, and you find the Y_max!
Thanks roco, but is the second derivative (acceleration) correct at -32? It just does not seem logical to me.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 47 ·
  • · Replies 17 ·
