Can [A,B^n] always equal 0 if [A,B] equals 0?
  • Context: Undergrad
  • Thread starter Thread starter cdot
    Commutator Identity
The discussion revolves around the mathematical relationship between two operators, A and B, specifically exploring whether the commutation relation [A,B]=0 implies that [A,B^n]=0 for any positive integer n. The scope includes theoretical reasoning and proof techniques, particularly proof by induction.
  • Exploratory, Technical explanation, Debate/contested
  • One participant expresses difficulty in proving that if [A,B]=0, then [A,B^n]=0 for all positive integers n, despite finding it intuitive for small values of n.
  • Another participant suggests using proof by induction to establish the general case, noting that if A and B commute, then [A,B^n]=nB^(n-1)[A,B].
  • A participant walks through a proof by induction, indicating that if A commutes with B, it must also commute with higher powers of B.
  • Some participants discuss the implications of commutation, stating that if A and B commute, the order of multiplication does not affect the result.
  • One participant questions whether their understanding constitutes a valid proof and seeks clarification on formatting mathematical expressions.
There is no clear consensus on the proof's validity, as some participants feel confident in their reasoning while others express uncertainty about applying induction correctly. Multiple viewpoints on the proof's clarity and completeness remain present.
Participants mention the need for a rigorous proof and the challenges of applying proof by induction, indicating a potential gap in experience with formal mathematical arguments.
Students and individuals interested in operator theory, mathematical proofs, and the properties of commutation in linear algebra may find this discussion beneficial.
cdot
This is not a homework problem. It was stated in a textbook as trivial but I cannot prove it myself in general. If [A,B]=0 then [A,B^n] = 0 where n is a positive integer. This seems rather intuitive and I can easily see it to be true when I plug in n=2, n=3, n=4, etc. However, I cannot prove it in the general case and this really bothers me. Here's what I got so far:
[A,B^n] = [A,BB^n-1] = [A,B]B^n-1 + B[A,B^n-1] = 0 + B[A,B^n-1]
Not sure where to go from here?
Thanks so much.
Thanks so much.
Hint: ##[A, B] = 0## means that ##A## and ##B## commute.
Hint #2: do you know how to do proof by induction?
So I realize that [A,B] = 0 means AB = BA and I actually just walked myself through a case of proof by induction to show that if two linear operators A and B both commute with their commutator ( I understand what this means ) then [A,B^n]=nB^n-1[A,B]. I don't have that much experience with proof by induction (I'm just an undergrad) and even though I felt like I understood the worked out proof,I'm having a hard time applying it to this example and it's driving me crazy.
So do you still have a problem or not?
You stated yourself that ##\left[A,\,B\right]=0##
It then follows that ##\left[A, B^2\right]=B\left[A, B\right]+\left[A, B\right]B=0##
But then it follows that ##[A, B^3]=B[A, B^2]+[A, B]B^2=0##
This can be repeated for all positive integer powers, so the general result follows.
If ##A## commutes with ##B## then it must commute with ##B^2## and ##B^3## etc.
Another way to look at it is that if we have ##X_1, X_2 \dots X_n## and they all commute with each other, then we can write the product of the ##X's## in any order.
In this case we have ##A, B, \dots B## that all commute with each other, so we can write the product in any order. I.e.
##AB^n = BAB^{n-1} = B^2AB^{n-2} = \dots = B^{n-1}AB = B^nA##
If you look at it this way, the result could be said to be obvious.
PeroK that makes a lot of sense. What Cryo did above also makes perfect sense. That's what I originally did, I just wasn't sure that constituted an actual proof. Also, how do you get your superscripts/subscripts to look nice on here. It doesn't seem to be working for me? Ex. x^2
Nevermind got it! Thanks for your help
  • · Replies 31 ·
  • · Replies 17 ·
