Can a cart powered by wind travel faster than the wind itself?
  • Level: Undergrad
  • Thread starter Thread starter swerdna
    Test Turntable
1,015 replies · 154K views
Once again, Evasive tactics are being resorted to whenever the going gets tough for the cart, talk about anything at all except the cart. Before it was ice boats, now it is torpedos1
If you want to know the undeniable truth about the cart, I am now prepared to hand you that truth. All you need to do here is follow along and pay close attention to what I am about to present to you.
Since there is no outdoor test which can demonstrate or has demonstrated, DDWFTTW with this cart or any other cart, the proponents have presented treadmill, and now turntable evidence, which they claim proves it is happening on the treadmill and turntable. The basis of that truth lies in the principle of Galilean Relativity. Anyone who challenges the evidence is immediately attacked as not accepting or understanding Galilean Relativity, even though it is one of the simplest concepts in physics and a 6-year-old can understand it. My challenge is not based on not understanding or accepting relativity, it is based on the fact that in the case of the cart, the principle is most definitely not being applied correctly.
I will explain how Galilean Relativity should be applied in pains taking detail, so you can finally understand what is actually happening, and finally understand the limitations of this cart.
I will use three machines in my explanation. One of them is entirely hypothetical. It does not exist. It in fact cannot exist or at least it cannot perform as in my explanation. The second machine is very simple and can be made by anyone within a matter of minutes. The third machine is the cart under discussion here.
Example One: In some ways this is similar to the cart under question, in that it uses two input wheels to extract power from a treadmill. The difference is, it does not have a propeller. Instead, it has two more wheels which are drive wheels and are internally linked by a 1:1 gear system to the input wheels. The concept is simple: two wheels extract power from the moving tread, and this power is used to drive the output wheels which also sit on the tread. The idea is to use the tread to power the cart AGAINST the same tread which is driving it. As I said, you can build it, but it will not work. The reason why is clear: Just to remain stationary on the moving tread, the cart would need to do as much work on the tread as the tread is doing on the cart. It would be a Unity device and we know such a thing is not possible. To go a step further, if the cart could actually advance AGAINST the tread, moving in the opposite direction to the thread, it would be an over unity device, which we all know is not possible. The key thing to note here is this cart, with all four wheels planted on the tread, is both extracting power from the tread and it is clearly working against the same tread. If it could move at all, it would be moving in the reference frame of the tread. By simply staying stationary, it would be moving at tread velocity, in the opposite direction to the tread. If it actually moved opposite to the tread, it would be going Faster Than The Tread. That would be remarkable, because it is impossible!
Example Two: You can build this in a few minutes if you have the materials. It consists of a single axle with four wheels. Two wheels will sit on the tread, and extract power from the tread. Two larger diameter wheels sit on the floor and do work on the floor. If you do actually build this be careful as it will take off like a bat out of hell in the opposite direction to the running tread! The things to note here: It extracts power from the tread. It goes in the OPPOSITE direction to the running tread (fast). It does NOT do any work on the tread, it is clearly doing work on the FLOOR. This point is crucial, so please make sure you understand it well. If you were to claim that it is doing work on the tread, you would also have to claim it is an over unity device, and we just established that an over unity device is impossible! But since it is working against the floor, it is moving in the reference frame of the floor. If you want to know the velocity of this machine you would measure it against a mark on the floor, not on the tread!
Example Three: The little cart that can’T! This cart clearly has two wheels which sit on the tread and extract energy from the tread. It also has two more wheels which sit on the tread and do basically nothing but balance the weight as a symmetrical object so it does not fall over. It also has a propeller which interfaces with THE AIR! As the tread does work on this cart, the cart does work on the AIR. It moves in the opposite direction to the tread, but it does NO work against the tread! This is VERY important for you to finally realize. Since it does move in the opposite direction to the tread, you cannot claim it is working against the tread, because you would then be claiming it is an over unity device and we have already established that such devices do not exist! Since it working against the AIR, it is moving in the reference frame of the air and not in the reference frame of the tread. If you want to measure the velocity of this infamous little cart, you could try to mark a spot in the air and measure against that. It would be MUCH easier to mark a spot on the floor, since the air and the floor are relatively stationary to each other (Galilean relativity, remember?) So you use the floor as the legitimate frame of reference to determine what this cart is doing and NOT the tread. Once that bit of enlightenment sinks in, you realize the little cart is moving rather slowly with reference to the floor, much more slowly than the tread which is driving it. N
Now, invoking the principle of Galilean Relativity, we can say if the cart is doing about 30% of tread velocity, both measured with respect to the floor, we can expect a similar result in the wind. The cart will do about 30% of wind velocity. Actually I think 30% is a bit generous. The main point is, it will NEVER reach anywhere near wind velocity, let alone FASTER Than The Wind!
If you are still in denial about this or say “Once again Schroder, you have demonstrated a poor understanding of Galilean relativity” then you are not being honest with yourself and you are doing this Physics Forum and the Physics Community in general a great disservice. It is time to admit your mistakes and clear up this matter once and for all.
I am sending a copy of this to Admin and reporting this thread. I do NOT want it closed, I want a retraction of this ridiculous claim printed right here in this thread.
Schroder
schroder said:
The test is conducted outdoors on a large flat surface (the “ground”). The treadmill is sitting on the ground and is enclosed by Plexiglas so as to shield it from the wind. The wind is cooperating by blowing at a nice steady velocity and is constant at 10 m/sec and is being constantly monitored by calibrated anemometers. The treadmill has a setting which has been carefully calibrated to run at exactly 10 m/sec exactly the same as the wind and both velocities referenced to the ground reference. The re is no need to read the cart’s actual velocity on the treadmill, only to demonstrate that it is either greater or lesser than the tread velocity all velocities referenced to the ground.
You are trolling, right ?
By video analysis, it is clearly demonstrated that the cart is moving at much less than the tread velocity. I have estimated it to be at about 30% of tread velocity at most. The actual number is not important.
The point is not that the cart is moving at "much less than the tread velocity", but rather, that it is moving *at all*. What matters is not the velocity wrt the outside ground (which is at rest in the frame of the AIR in the threadmill example), what matters is the velocity wrt the threadmill surface of course! And if it moves in the air frame (your ground frame), even the slightest bit, in the opposite direction, then OF COURSE it moves faster wrt the surface than does the air, which is NOT moving in that frame, right ? I have difficulties believing that you are being serious here. If you are, it seems that you don't even understand what the concept of "relative velocity" means (which explains at once why you have difficulties accepting a proof that is based upon galilean relativity).
DWFTTW doesn't mean that the cart is going faster than the wind in just any frame of your liking (which would be an easily disproved statement: in the frame of the cart, the velocity of it is zero, and hence smaller than any other0. DWFTTW means that the *relative velocity* of the cart and the surface on which it rides is larger than the *relative velocity* of the air and said surface. Or, differently formulated, that *in the frame of the surface on which the cart runs* the velocity of the cart is larger than that of the air (called "wind").
But I have difficulties believing you don't understand this. I think you are trolling, honestly.
From the evidence I conclude: 1) The cart on the treadmill, being driven by the treadmill, is moving much slower than the treadmill.
Again, if you acknowledge that it moves *at all* then you have your proof, because the motion of the cart (in the outside ground frame) is the *surplus* velocity over that of the wind.
2) The cart in the wind, being driven by the wind is moving much slower than the wind. All of my comparisons are with respect to one common reference and can be considered as one reference frame. I can only conclude that the evidence is overwhelmingly against the claim of DDWFTTW. In fact, I now consider the claim to be so ridiculous that I will not participate in any more discussion or debate on this matter. My findings are here presented and open to inspection to all. I consider the matter as closed.
I agree that the outdoor test videos are not conclusive at all, and that's why lab tests (turntable and threadmill tests) are much better, because the environment is much more controlled (and there's no discussion about the relative velocity of the air and the surface).
You still haven't answered my post with the train... I would like to see where you switch from yes to no ; although I guess it will be at the point when the train is moving, given what you wrote above, because visibly you don't accept the concept of relative velocity.
Read my post directly above yours and admit your error!
The reason why this doesn't work is because the power you extract from the thread with the first set of wheels is given by the force F1 which acts upon it as P1 = v1 x F1, where v1 is the relative velocity between the first set of wheels and the cart. Now, in order for you to have net traction forward, you would need to deliver a force to the second set of wheels F2, which is bigger (to overcome drag and so on), so you would need to deliver power P2 = v2 x F2. Here, v2 is the relative velocity between the second set of wheels and the surface. The problem is that because v1 = v2 here (the wheels are on a surface with which they have the same relative velocities), the power to be delivered (P2) needs to be larger than what you can extract (P1), this is impossible. In fact, if your power transmission has any losses, P2 will actually be somewhat smaller than P1, and thus F2 will be smaller than F1. In other words, the net force forward, F2 - F1, will be negative, and the overall cart will actually slow down as a function of the power losses due to dissipation.
This is the example of the ruler and the cart.
But you can do smarter things, such as put in some gearing mechanism which inverses the rolling direction of the outside wheels.
Now, the problem with a statement like "it does work on" is that this is a frame-dependent statement. After all, what is "doing work on" ? It means that you have a force, and a displacement. You have F, and you have a displacement during a time dt. The displacement is given by dt x v. So "doing work on" is given by F x v x dt.
However, the "v" is a frame-dependent quantity. It is the velocity of the object on which force F acts, in our chosen frame of reference. If F has the same sign as v, then the thing that applies force F on our object is "doing work on" the object. But if we now look upon this from a reference frame which outruns our object, v changes sign, (while forces remain unchanged under a change of inertial reference frame), and this time, our F x v x dt has changed sign. So this time, our "force-applying thing" has not DONE work on the object, but received work from it.
So there is no absolute physical meaning to "this has done work on that". It is a frame-dependent quantity. Of course, once one fixes the frame of reference, (for instance, to the object which is "applying the force") then this can get an absolute meaning. But what matters, is that one doesn't SWITCH reference frames when doing an overall energy (or power) balance. As long as one does it within one and the same frame, then (as per energy conservation) all works out. But don't use energy contributions calculated in different frames (using different frame-dependent velocities) to make up an overall energy balance, it won't work. All energy conservation says is that, *within one and the same frame* there is an energy balance. It doesn't say that the individual contributions in that balance are the same in all reference frames.
As an example of this, look at the force of gravity acting upon a stone we throw up in the air (from the ground). In the ground frame of reference, during the upward motion of the stone, the force of gravity is acting in the opposite direction as the velocity (in this frame). As such, the stone is doing work on the earth: it is LOOSING energy because of the force of gravity (in this frame). But now look upon this in a frame that goes up twice as fast as the stone. In this frame, the force of gravity (still downward) is in the same direction as the velocity (which is downward in this frame, as our frame outruns the stone). In this frame, gravity is doing work on the stone, and the stone is GAINING energy because of it. So is gravity "doing work on" the stone, or is it "extracting energy" from the stone ? The answer to that question is frame-dependent. There are some "natural" frames of reference of course, and the most natural would be in this case the center of mass system of the stone and the earth, which is very nearly the one fixed to the surface to the earth. But I have all the rights in the world to do my calculations in the upgoing frame.There are no claims of over-unity devices necessary for this.
Also, your statement "if you want to know the velocity of this device, it would be wrt the floor and not wrt the tread" seems so bizarre to me, that I'm starting to get convinced that instead of trolling, you really don't know what "relative velocity" means.
If the question is: what is the velocity of this device with respect to the tread ?, then for sure we don't want it wrt the ground, no ? And this would be a perfectly legitimate question, no ?
Again, specifying what does work on what depends on what frame you look upon things. "Doing work on" is a frame-dependent concept (just as "standing still" is).
These are, mechanically speaking, totally incoherent statements honestly. Saying that it is "moving in the reference frame of the air and not in the reference frame of the tread" is about the most erroneous statement one can make concerning relative motion.
There are no "legitimate" and "less legitimate" reference frames.
Honestly, as I said, or you are trolling, or you haven't gotten the most basic understanding of Newtonian mechanics and galilean relativity. You have now issued a large number of totally meaningless statements regarding them, at a point where I start to get lost as to where I can have a discussion with you regarding a simple mechanical problem.
First, I thought you didn't know what a galilean transformation was, or what exactly was the principle of galilean relativity. Next, it seems that you are missing what is the concept of relative velocity (and related to that, what it means "does work on"). Now, it even seems that you don't know what a reference frame is. Where do we start ?
Such a statement only re-enforces my previous idea.
Schroder
I think you might be in for a surprise.
Nothing can possibly surprise me more than your refuasl to accept the facts when you see tham in front of your eyes. I have nothing more to say here. Have a nice day!
Well, you have shown to have some strange understandings of basic Newtonian mechanics, to say the least. I still insist on you answering (y/n) my post on the train business (post 378 in this thread). It would indicate me exactly where your (first) misunderstanding resides.
A.T. said:
The fences have plenty of energy, just like the wind. They can accelerate any mass in the opposite direction of their movement, if the stick and the fences are strong enough.
Then the stick and fences analogy does not represent the downwind cart situation. In the downwind cart there comes a point where there is no longer plenty of energy.
First you have to remind yourself that "speed" is not, by itself, the whole picture. There is no such thing as "pure speed". Speed represents energy only so long as we ascribe that speed to something with mass. k = 1/2mv^2 requires that we know the mass, not just its speed.
Then, to analyze the cart's situation you have to account for the point where it reaches downwind speed, and the wind contribution plummets to 0. A cart going at the same speed as the wind sees the wind as standing still.
Here's how I put it eariler:
"If we keep our focus on this vehicle as one which harvests power from relative motion of surrounding media then we have also to contend with the fact that the relative motion of the surrounding media has two separate and distinct configurations to deal with. In the first the cart sees the wind as a tailwind and the ground as a head wind (provided the cart's in motion at all.) In the second the cart sees both the wind and the ground as headwinds. These two headwinds have energy to harvest, in principle, by virtue of the fact they are moving relative to each other at different speeds (according to MGrandin's description of the situation). However, they are still both headwinds, and will require an engineering solution specific to that situation, which must be different than the solution to the tailwind verses headwind situation.
I think it would be very useful to begin analyzing each design according to how it solves for two separate situations 1.) the Tailwind-Headwind (TH) and 2.) the Headwind-Headwind (HH). This would greatly clarify design strategies and discussions.
Personally I think that designing for the HH situation is the critical problem to solve. I would design for that and let the TH solution be direct blowing (DB) i.e. accept and allow for the startup to consist of the wind simply blowing the whole thing physically downwind. Otherwise you have to design transmissions or rotors that change configuration somehow."
schroder said:
Before it was ice boats, now it is torpedos.
Ice boats operate on a different principle, but the Brennan torpedo operates on the same principle as DWFTTW cart.
It would move backwards, in the same direction as the treadmill. It's the equivalent of pulling a string on a yo-yo as the string winds onto the yo-yo's axle from below the axle. The advance ratio is > 0, < 1, and the speed of the single axle 4 wheel device on the tread would be tread speed / (1 - ar), where ar = advance ratio = (smaller wheel diameter) / (larger wheel diameter). The wiki Brennan torpedo link refers to a similar example: Brennan was inspired to create his torpedo's unique propulsion system in 1874, when he noticed that a cotton reel, if the thread is pulled toward the operator from underneath, moves forward rather than backward.
http://en.wikipedia.org/wiki/Brennan_Torpedo
Jack Goodman's video is of a outdoor test:
http://www.youtube.com/watch?v=aJpdWHFqHm0&fmt=18
Yes, and on top of that, it depends in which frame you describe it, because "v" depends on it.
It is true that when the cart has wind velocity, the wind is (of course) at rest wrt the cart. But now the floor isn't. In this reference frame, the floor is "flowing" in the same way as a river is flowing wrt a watermill. You can tap into that.
The error resides (as I said already a few times) in thinking that it is "the wind which brings in energy, and not the steady floor" ; which is a correct, but frame-dependent statement. It is correct in the frame of the floor.
Imagine, out there in space, an iron windtunnel, a cart with magnetized wheels (to stick to the surface - there's no gravity!). Then it is not so simple to say that it is only the wind that "can provide for energy". The energy comes in fact from the velocity difference between the floor and the air, but how much you attribute to each is dependent on the frame in which you are working. In the frame of the floor, yes, your only source of energy is the moving wind. But in the frame of the wind, the only source is the moving floor. And in another frame, it depends.
Yup, but in that frame, you have a moving surface from which you can tap.
I see what you mean. You would like to say that somehow one needs to "change gears" exactly at the point of overtaking the wind. Probably this comes about because the faster the cart is moving wrt the ground, the larger the force that is applied by the propeller in the forward direction. In other words, the propeller doesn't have a fixed gearing ratio wrt displacements or velocities (as in the case of a ruler), but only as a force.
So at low velocities (wrt to the floor) the propeller "doesn't do much" and acts at best as a sail. The larger the velocity, the harder it starts to turn, and the larger the force is it exerts on the air (by having a larger and larger momentum transfer).
The cart driving wheels exerts a forward force against the tread. This force is exerted over a distance on the tread over a period of time, and the work done in this period of time is force times distance. The motor driving the treadmill at a specific speed has to use more power to drive the treadmill with the cart on the treadmill, than it does to drive the treadmill without the cart on the treadmill.
We could mark a spot in the air with a bubble, indoors or outdoors.
The goal is to achieve speed faster than wind, not the tread. Restated the goal of a DDWFTTW cart is to achieve:
|cart speed - ground speed| > |wind speed - ground speed|
Note that this inequality is independent of frame of reference.
The cart's prop generates upwind thrust. The wind's contribution is to apply a forwards force onto the air acclerated upwind by the propeller. The affect air transfers the forward thrust from the wind onto the prop. When the cart is as wind speed, the thrust from the propeller is still well below wind speed, so the wind has the air from the prop wash to interact with.
TH versus HH
Spork and swerdna's carts are self starting (T0 situation) with a fixed pitch prop and achieve HH speed, so they are good enough. A variable pitch prop would allow for a better acceleration rate (with a low or negative pitcth) while in TH mode, and then switch increasing positive pitch for HH mode to maximize speed. Since the goal here is any speed above wind speed as opposed to maximum speed, the fixed pitch prop carts are good enough.
swerdna said:
If you think that theory is more robust evidence than an actual, practical physical demonstration then I respectfully suggest that perhaps you should get out into the real world more often. :wink:
As I said earlier, stored energy was my main concern before I did testing for over 10 minutes on my turntable 10 minutes is a lot longer than the one or two you suggest. I also did a turntable test to show how the kinetic energy of a marble lasts a long time on a turntable - http://nz.youtube.com/watch?v=kc88SrMG5fA
I repeat A.T’s question - “How did the Brennan Torpedo maintain itself in this situation for 2000 yards? Stored momentum? Under water?”
And ask you the same as I asked Schroder - “If myself or someone else built a cart and provided a video of it clearly beating bubbles floating in an outside wind would you accept this as proof? If not, what you accept as proof?”
If it does not work on paper, but works in real life then two possible situations might exist:
1.) There was a problem with the math. The wrong formula was used, someone put the wrong number into the formula.
or:
2.) The demonstrations aren't what they look like.
None of you has disputed my formula, because its the formula you taught me to apply. But when that leads to the realization that the cart comes to a point in the directly downwind scenario where it has only its stored energy, you all abandon the need for it to work on paper and take refuge in demonstrations that "seem" to work.
I am more inclined to suppose those demonstrations aren't what they look like.
It often happens that things are claimed to be operating by a certain interaction of forces, when it turns out they are operating by a different interaction of forces. Demonstrations demonstrate something, yes, but it isn't always what has been claimed they demonstrate. Crooke's Radiometer:
http://en.wikipedia.org/wiki/Crookes_radiometer
Called the "Light Mill". Reputed to work by pressure exerted directly on the vanes by photons:
They come in various forms, such as the one pictured, and are often used in science museums to illustrate "radiation pressure" – a scientific principle that they do not in fact demonstrate.
The cart is running off of energy stored in the cart's system here.
I am persuaded there's an excellent possibility the cart will make it into the HH situation under these circumstances, but only on stored energy. It cannot sustain this. Once it expends enough of its stored energy it will slow back down to where energy is being added by the tailwind.
At this point in the discussion, your post #378 is irrelevant. It is clear to me that you are religiously clinging to a theory of DWFTTW which I have disproven using the Fundamentals of Physics. If a non-staff member of this forum engaged in this practice, he would be banned as a crackpot. I do not accuse you of crack pottery, but by clinging to a belief when the fundamentals of physics have been shown to go overwhelmingly against that belief, is just unacceptable. I am sorry this has come down to a personal duel. My only objective here is the truth of the matter. You cannot reasonably claim the cart is working against the tread without also claiming it is over unity because it is getting all of its energy from the tread. That is an inescapable fact which you refuse to acknowledge. Once you acknowledge that the cart is in fact working against the air, you must also acknowledge that it is moving in the reference frame of the air. And once you do that, you see that the velocity is measured wrt the air (or floor which is easier) and certainly not wrt the tread. Then it is clear it is NOT moving faster than the tread and by the proper application of Galilean relativity it is not moving faster than the wind. This entire matter could have been cleared up by a simple outdoor test with the most primitive of equipment but no one sees fit to do it because the outcome will destroy this myth which at this point is a hoax. Release the cart downwind and after a head start release one of Nature’s own tumbleweeds and see what happens! The tumbleweed will pass that cart faster than you can say “Faster than the Wind”. And, tumbleweeds do Not exceed wind velocity. I do not wish to damage your reputation or your ego, but you are wrong about this and I just wonder if you will be man enough to admit it. If I am wrong I would expect to be thrown off this forum as a crackpot. But if I am right, and you ban me for being right, that would be a very serious crack in the prestige of this forum.
It isn't. But even if it were, why do you refuse to consider it ?
You have not demonstrated any thing of the kind. You have stated a large number of erroneous statements concerning basic classical mechanics, reference frames and things as simple as relative velocity. As I said already a few times before, without at least a sound basic understanding of these concepts, and the principle of galilean relativity, it is indeed impossible to understand the relevance of the demonstration of the treadmill or turntable experiments, and without its understanding, it is of course also impossible to accept it as a proof of the matter.
There could have been valid ways to attack these demonstrations. For instance on the turntable, there is the fact that the reference frame is not 100% inertial, and that there is also an extra force on the cart due to the arm. You could have considered these things. On the treadmill experiment, you could argue that steady state has not been reached, or something else. All these would be interesting points. But you miss the basic point, which is a transformation of coordinates.
Except that no such thing is happening, and that what you consider as a proof against it is an incoherent babble full of elementary mistakes. It is not because I write that 100 - 200 is greater than zero that I have demonstrated in any way that negative numbers don't exist. Your "proof" amounts logically to a similar set of statements.
I explained already at least 5 times why this reasoning is false (once again, because "getting energy from" is a frame-dependent concept).
This is the kind of nonsensical derivation I pointed to, which you consider as "proof".
Sure, but that's not the matter. If this happens, there is a serious problem in the application of galilean relativity. It would be almost as surprising as finding out that the test works in the Mid-West, but not in London, because of the distance to Big Ben.
It is not a matter of crackpottery, it is a matter of not understanding the basic concepts of Newtonian mechanics. I'm not interested in DDWFTTW per se, I'm interested in the nice demonstration this is using transformations of frames in Galilean relativity. It could very well be that it is not possible for some or other technical reason to make a DDWFTTW cart, but given the demonstrations, the practical proof is there if you understand how frame transformations work. It is also true that DWFTTW doesn't violate any basic principle, such as "over unity" or the conservation of energy of momentum - that's easily established too.
Yes, I completely agree with this. It is essential to know what frame you are analyzing.
Indeed you do! Just because the wind velocity is now 0 and is not contributing does not mean the cart is without an energy source, because in the cart's frame, the ground is moving! The ground is moving backward underneath the cart, and represents an energy source.
I think you are following my reasoning: among other considerations there is a purely mechanical, engineering problem to solve, which arises from the shift in direction of the motion of the two surrounding media. The propeller must somehow change configurations when the TH switches to HH to take the greatest advantage of both the TH situation and the HH situation.
swerdna said:
I’ve designed a “Brennan Boat” that uses the same principal as his torpedo except it uses the flow of water as the power source instead of pulling the cables.
That is something the torpedo can do too. It is just not the standard operating scenario.
swerdna said:
[PLAIN]http://www.accommodationz.co.nz/images/brennanboat.bmp[/QUOTE][/URL]
Why do you need two cables? The torpedo needs two for steering, but for a minimal design I would recommend using just one.
Zoob, could you maybe consider my post #378 and answer the y/n questions ?
https://www.physicsforums.com/showpost.php?p=2036877&postcount=378
It is interesting to see where there's something that's bothering you.
As I told people here already several times, energetic considerations "in the wild" are ERRONEOUS APPLICATIONS of the principle of conservation of energy, so they do not hold if they use energies in different frames.
This means: blue fence(=air) is at rest, but brown fence(=ground) behind it is still moving left, from your perspective. The stick will still accelerate you to the right so you soon see both fences moving left, at different speed. From brown fence(=ground)-perspective you are then moving faster than the blue fence(=air) in the same direction. -> DWFTTW
Sorry, I don't see any problem extracting energy from the fences when just one of them is at rest to you. This is exactly the situation when the cart travels at wind speed.
zoobyshoe said:
g
I'm not entirely sure about this, but as I said, I think it comes down to the fact that we have, in the case of a propeller, a force which is a function of velocity (which isn't the case in the ruler-based system). Mathematically, this gives you an "extra integration" to perform.
Let us analyze this in more detail. I'm discovering this myself as I'm typing...
The force a propeller generates is by the change in momentum it causes to the air mass. That is to say, if a propeller has an effective "outgoing" section S (which might be different to its geometrical section, and is equivalent to an idealized situation where a "cylinder of air" is uniformly accelerated by the propeller, and outside of it, nothing is done, which is clearly not what happens in reality, where there will be a gradient in velocities).
We work in the frame of the cart.
Now, in a time dt, the propeller will give to a volume V_out = S x dt x v_out, which has initially a velocity v_in, a final velocity v_out.
Assuming a non-compressible flow, the "in" surface has to be larger than the "out" surface (to keep the volume right) and will depend on the incoming velocity.
The momentum gained is the mass of the air times the velocity change:
dp = V_out x rho_air x (v_out - v_in). The momentum transfer per unit of time is dp/dt is the force:
F = rho_air x S x v_out x (v_out - v_in)
I suppose we can say that v_out is entirely fixed by the properties of the propeller and its rotation speed (but maybe there's an influence of the incoming velocity, I don't know). So we take it that v_out = K x v_cart (K includes the wheel and the gearing ratio and all that).
So we get:
F = rho_air x S x K x v_cart x (K x v_cart - v_in)
This is the force which the propeller exerts on the air.
Let us think about the signs. I took the positive direction in the direction of the tail of the cart. That means: v_in positive is "headwind", v_in negative is "tailwind" (which is the starting condition). v_cart however, is taken in the positive direction of the motion of the cart wrt the floor. So from the moment the cart is moving downwind, v_cart is positive.
F is positive if the propeller pulls the cart in the forward direction.
Through the gearing mechanims, F_wheels is the force exerted on the wheels.
The energy balance is the following. The energy given to the air by the propeller is given by (in the cart ref. frame):
rho_air x V_out x 1/2 x (v_out^2 - v_in^2)
(gain in kinetic energy = 1/2 mass x v^2)
This can be written as:
rho_air x S x K x v_cart x (K^2 x v_cart^2 - v_in^2)
The energy taken from the wheels is v_cart x F_wheels. In the lossless case, we have that:
rho_air x V_out x 1/2 x (v_out^2 - v_in^2) = v_cart x F_wheels
From this, F_wheels can be calculated, and hence the total force on the cart (without drag):
F = F - F_wheels.
I completely agree with you. There is no problem extracting energy from the fences, but only so long as we assume the moving fence has more than enough speed and mass to move you.
There is an important difference, and this difference is the problem.
In the gound/air/cart scenario, what represents the fence that is still moving when the wind speed = 0 with respect to the cart?
So we get:
F = F - F_wheels.
Now, in the above, v_in is of course (v_wind - v_cart).
So what happens at low speeds ? (v_cart << v_wind)
F is negative:
Indeed, for small v_cart, we have that the term in parentheses reduces to:
( (K+1) x v_cart - v_wind ) and if v_wind is larger than (K+1) x v_cart, we see that the propeller actually acts as a sail.
At the point where there is an equality, v_wind = (K+1) x v_cart, we see that there is no force on the propeller: the propeller smoothly "follows" the air without any force.
But the cart is still running at a velocity smaller than that of the wind. From the moment that v_cart becomes larger than v_wind / (K+1), we have that the propeller starts to act as a propeller, and the "power flow" reverses in the cart.
BTW the "turning over" point (K+1) x v_cart = v_wind is actually that when the "out" velocity of the air equals exactly the apparent incoming wind velocity: so indeed, the velocity of the air doesn't change when going through the propeller. This happens when the cart is running at a lower-than wind speed.PS: I'm a bit puzzled by K+1. I expected K-1. I will look for sign errors...
EDIT: indeed, I made a sign error. See post #477.
I've actually given up thinking about this for the moment, because I'm the sort of person to whom even a wheel rolling without slipping on flat ground is counterintuitive. But just to explain what I hope to study when I get the time. Not bothering me: yes, DDWFTTW is possible in principle because of the simple models; yes; there is no obvious problem with the energy and momentum conservation laws; yes a straightline treadmill test is in principle good; yes, the models do seem to instantiate DDWFTTW. What's bothering me: the tests are not perfect, even in a straight line test, how do we know the air is really stationary? how do we know the velocity of the treadmill is really constant? These caveats are even worse in the turntable test. Some theory is needed to interpret what we observe. Nonviolation of conservation laws doesn't mean that dynamics exist to actually instantiate a particular phenomenon. So a clear dynamical model, like the one you are trying here (and before in #214, but Jeff Reid seemed to have some problem with it), for the non-simplified cases that have actually been built is what would really help those of us without mechanical intuition.
We can assume that. The moving brown fence being the ground has enough mass. And "enough speed" is just a matter of leverage: total stick length vs. distance between the fences.
The ground. Read what I wrote in the brackets.
Yes, you are right (actually my first attempt at a model seems to be flawed as there is clearly no first-order term present, and only a second-order term in the velocities). This is why some discussions here are a bit sad, in that they miss the essence. There *are* points to be risen in the presented tests, as you point out. So first having a crude model in which one can trace out all one's elementary objections is a good start.
Since DDWFTTW is possible without taking the "greatest advantage', the prop doesn't need to change configurations, as evidenced by the operating fixed pitch prop carts.
This never happens at below wind speed. The velocity of the air is always slowed down (accelerated upwind) by the prop, regardless of how much the prop is acting as a blunt body (sail) or acting as a thrust generating device (prop) at below wind speed.
The cart speed at which the velocity of the air doesn't change when going through the prop occurs when (cart speed) - (prop pitch speed (relative to cart)) = (wind speed), or restated in terms of advance ratio, when (cart speed) = (wind speed)/(1 - ar), where ar = advance ratio = (prop pitch speed (relative to cart)) / (cart speed). Using the ratios from swerdna's cart, and a 10 mph tailwind, this occurs when cart speed = 23.33 mph. Cart speed = 23.33 mph, prop pitch speed = (6 /10.5) x 23.33 mph = 13.33 mph. Prop pitch speed is 13.33 mph upwind of the cart moving downwind at 23.33 mph, so zero change in the velocity of a 10 mph tailwind.
Ok, where's my error ? I feel a bit unsecure about the signs of some contributions. I should check it.
EDIT: right, I found it. I took v_in as the incoming wind direction as seen from the propeller, and then this is given by v_cart - v_wind and not vice versa.
So I have to take back what I wrote in post #472, and correct it:Now, in the above, v_in is of course (- v_wind + v_cart).
F is negative:
( (K-1) x v_cart + v_wind ) and we see that if K > 1, this never acts as a sail.
And there is no turning-over point, as Jeff pointed out.
vanesch said:
Ok, where's my error?
I suppose we can say that v_out is entirely fixed by the properties of the propeller and its rotation speed (but maybe there's an influence of the incoming velocity).
The incoming velocity does effect the thrust. Compare the thrust when apparent headwind = 0 to when the apparent headwind = prop pitch speed (thrust is zero in this second case). Even if thrust isn't greater if the apparent headwind is negative, the thrust is still non-zero. I'm not sure what the thrust to apparent heawind curve looks like, other than it's approaches infinity as apparent headwind approaches negative infinity, and approaches zero as apparent headwind approaches prop pitch speed, transitioning to negative thrust when apparent headwind is greater than prop pitch speed.
I think the sub-wind case you're considering is when the true wind speed is slowed to 0 mph by the propeller, which does occur when the cart speed is sub-wind.
There is a turning over point, but this occurs when cart speed is well above wind speed (v_cart >> v_wind). I did the math in my last post.
Regardless of v_cart, can't this be simplied as you mentioned:
F = rho_air x S x K x v_cart x (K x v_cart - (vcart-v_wind))
F = rho_air x S x K x v_cart x ((K-1) x v_cart + v_wind)
now I'm having trouble with this equation, since F = 0 at some (v_cart >> v_wind).
update - just realized that K > 0 but < 1. Relative to cart, v_out = K x v_cart. K is what I've been calling advance ratio. Except now we need to fix the equation so F is positive at slow speeds (assuming you want F to be positive for downwind acceleration of the cart). Setting the last term = 0
(K-1) x v_cart + v_wind = 0
(K-1) x v_cart = -v_wind
(1-K) x v_cart = v_wind
v_cart = v_wind / (1 - K)
which matches my equation for when F = 0.
The incoming velocity has an effect on the thrust, but does it have a big effect on the outgoing velocity ? I would think that pitch x turning ratio determines more or less the outgoing velocity (yes, it will be affected a bit: even at zero turning speed, some air will "blow through" the propeller ; this would be much less the case with a turbine for instance, which would essentially "shield" the wind).
The thrust is affected by the incoming velocity because it is given by the amount of displaced mass times the velocity difference per unit of time.
I'm still trying to figure out the meaning of the K-value. I first thought it had to be larger than 1, but I think you're right, and that it is between 0 and 1.
What is interesting is that at v_cart = 0, we have according to my
that F = 0.
So initially (and that's trivial!) when the cart is at rest (wrt the floor) the propeller is not giving any thrust either.
So here we need a little bit of drag by the wind on the rest of the cart (or even on the propeller, but this has not been taken into account in the model).
So we need to add a term F_drag = W x (v_wind - v_cart)
Now, this will probably even be: F_drag = W x (v_wind - v_cart)^3.
Note that this term flips sign when the cart overtakes the wind. Initially it works as a sail, and afterwards, it works as an aerobrake.
So the total aerodynamic force is rather:
F_aero = F + F_drag = rho_air x S x K x v_cart x ((K-1) x v_cart + v_wind) + W x (v_wind - v_cart)^3
We have on the other hand the reaction force, which we can estimate from the power balance:
From rho_air x V_out x 1/2 x (v_out^2 - v_in^2) = v_cart x F_wheels
we have: F_wheels = rho_air x S x K x v_cart x (K^2 x v_cart^2 - (v_cart - v_wind)^2) / v_cart
or: F_wheels = rho_air x S x K x (K^2 x v_cart^2 - v_cart^2 + 2 x v_cart x v_wind - v_wind^2)
We now have the total force on the cart:
F_tot = rho_air x S x K x v_cart x ((K-1) x v_cart + v_wind) + W x (v_wind - v_cart)^3 - ...
... rho_air x S x K x ( (K^2-1) x v_cart^2 + 2 x v_cart x v_wind - v_wind^2)
Special cases:
v_cart = 0, we have:
F_tot = W x v_wind^3 + rho_air x S x K x v_wind^2
So this is the force that sets the cart in motion, and indeed in the forward direction.
v_cart = v_wind, we have:
F_tot = rho_air x S x K^2 x v_cart^2 -
... rho_air x S x K x ( (K^2) x v_cart^2)
= rho_air x S x K^2 x (1-K) x v_cart^2
Now, if K < 1, indeed, we see that we have a forward force, while if K > 1, we have a negative force (You were right, Jeff).
