zoobyshoe
- 6,514
- 1,255
Whoops!A.T. said:The moving brown fence being the ground has enough mass.
How much mass does the ground have here?
vanesch said:Zoob, could you maybe consider my post #378 and answer the y/n questions ?
https://www.physicsforums.com/showpost.php?p=2036877&postcount=378
It is interesting to see where there's something that's bothering you.
As I told people here already several times, energetic considerations "in the wild" are ERRONEOUS APPLICATIONS of the principle of conservation of energy, so they do not hold if they use energies in different frames.
schroder said:Your claim is that on the treadmill, the velocity of the cart is measured wrt to moving tread. You are using the frame of the cart to come this conclusion and what you have is relative velocity between the cart and the tread, and that relative velocity is faster than the tread, So you claim that is evidence that the cart can go faster than the wind, (at least in principle) Is that correct?
I reject that claim. I claim that when the cart is running on the tread, being powered by the tread, it is working into the air and doing no work on the tread.
Therefore, I claim that the proper frame of reference for the cart and the tread is the reference frame of the air, or floor as the air and floor are relatively stationary to each other.
Now, based on the usage of that reference, I can measure the speed of the cart relative to appoint on the floor in one direction and the relative speed of the tread measured from the same point in the opposite direction and compare them.
It is without any question that the tread is moving much faster than the cart when the velocities are compared.
My conclusion from that is that when placed in the wind, the cart will also be moving much slower than the wind. You reject what I am saying.
Ok. Now when the cart is running down wind, how do you measure its velocity? How do you determine how fast the cart is going? Do you measure the velocity of the cart relative to the wind or relative to the ground?
I would assume you would measure it relative to the floor Am I right? You would do this because if you measured it relative to the wind, you would get ridiculous answers such as it is moving with a negative velocity a sub wind speeds. And a zero velocity at wind speed and you would only get a positive velocity for the cart if it should ever go over the wind speed. Obviously these numbers are wrong, as you can see the cart moving with a positive velocity the second it starts moving. The reason the result is wrong is because you have chosen the wrong reference frame, the wind, when you should have chosen the ground.
You should have chosen the reference frame of the medium the cart is working into, not the medium that is doing work on the cart!
In the case of the treadmill, the tread is doing the work on the cart and the cart is working into the air.
In so far as you are working on the side of Good and trying to squelch the notion this thing can work I applaud and support you, but I have to tell you I do not believe there is actually a "proper" frame. Any frame you both agree to analyze it from will give accurate results. The important thing is never to mix frames: don't start out in one frame then suddenly pull in information from another.schroder said:Therefore, I claim that the proper frame of reference for the cart and the tread is the reference frame of the air, or floor as the air and floor are relatively stationary to each other.
vanesch said:And, BTW, you still didn't answer my post #378 with the train...
Ok, so now we have a flat train, running at 30 km/h through the fields, with a 100 m track on it, and a cart doing the test. Let us say that instead of having a straight track, we make a circular track and have the train run on a circle of say, 2 km diameter. This won't change much, so can you still accept the test with the flat train running on this track at 30 km/h ?
cristo said:Everyone seems to be ignoring this post, but I think it's quite an interesting post in this discussion. Personally, I'm not too keen on this step of your process of 'transforming' the experiment:
You're moving from an inertial frame to a non-inertial frame so it's not entirely clear, on first glance, that the two are equivalent. Of course, I've not read the whole thread, so apologies if this has been touched upon (and I've not done any calculations so don't know whether this will make all that much difference).
A.T. said:Cart at wind speed means: blue fence(=air) is at rest, but brown fence(=ground) behind it is still moving left, from your perspective. The stick will still accelerate you to the right so you soon see both fences moving left, at different speed. From brown fence(=ground)-perspective you are then moving faster than the blue fence(=air) in the same direction. -> DWFTTW
Where 'here'?zoobyshoe said:Whoops!
I know.Jeff Reid said:Since DDWFTTW is possible without taking the "greatest advantage', the prop doesn't need to change configurations, as evidenced by the operating fixed pitch prop carts.
zoobyshoe said:In so far as you are working on the side of Good and trying to squelch the notion this thing can work I applaud and support you, but I have to tell you I do not believe there is actually a "proper" frame. Any frame you both agree to analyze it from will give accurate results. The important thing is never to mix frames: don't start out in one frame then suddenly pull in information from another.
"Here" means in the situation we're discussing: we have a cart going, say, 10 mph over the ground. Wind speed is 0 with respect to the cart. Ground speed is 10 mph with respect to the cart.A.T. said:Where 'here'?
Fence scenario: Both fences are very long and have a huge mass, compared to you+stick.
DWFTTW scenario: Both Earth & atmosphere have a huge mass compared to the cart.
I look at the speedometer.schroder said:It is also important not to invert the way you apply the frames. When you are sitting in your car and the engine is driving the wheels to turn against the road and you want to know how fast your car is going. Do you measure the velocity between the center point of the engine and the centerline of the wheels? Or do you measure the velocity between the centerline of the wheels and a centerline drawn on the road? Of course you measure it between the wheels and the road. If you measured between the wheels and the engine it of course is always constant and you get a wrong result. When the cart is being driven by the wind as the engine and is running on the road, you measure the velocity between the wheel and the road, not between the wheels and the engine (the wind). When the cart is being driven on the tread as the engine and driving into the air with the propeller. You measure between the centerline of the propeller and a centerline in the air. You do not measure between the centerline of the wheels and the centerline of the engine (the tread). You must be consistent in both frames. By using the wheels and the tread to take the measurement on the treadmill you are inverting from the down wind frame and that is giving you the ridiculous result of faster than the tread hence faster than the wind. Be consistent in both frames. Do not invert things!
vanesch said:You're right of course, this is the part which is disputable. However, the idea is that the effect of the rotation will be smaller when the radius of curvature is bigger. It was indeed the caveat I made in the beginning.
schroder said:I actually read that post and found one question is missing; the first one, which should be “Are you willing to accept that a cart being driven by the wind can go DDWFTTW?” My answer is NO and that makes all the other questions irrelevant!
But without that first crucial question, I would have answered Yes to all.
cristo said:I must have missed that caveat but, yes, I can accept that as a plausible approximation.
Good. So you agree that the turntable test is equivalent the true outdoor test? Thus, since the OP shows a video of the turntable test giving a positive result, then you agree the true outdoor test will give a positive result, also? So, we're done!
zoobyshoe said:"Here" means in the situation we're discussing: we have a cart going, say, 10 mph over the ground. Wind speed is 0 with respect to the cart. Ground speed is 10 mph with respect to the cart.
What amount of mass should we plug into formula: K=1/2mv^2 to find out how much energy is available to the cart from the ground?
You are quite right that the energy is harvested from the difference in the relative velocity of the ground and air! The ground speed and difference between air and ground speed just happen to be exactly the same thing at this point, because the cart and wind are going the same speed in the same direction.A.T. said:The energy is not available from the ground. It is available from the speed difference between ground and air.
schroder said:Nice Try! Sure they are equivalent and since the TT test clearly shows the cart is moving slower than the TT then I conclude it will also move slower in the wind!
zoobyshoe said:You are quite right that the energy is harvested from the difference in the relative velocity of the ground and air! The ground speed and difference between air and ground speed just happen to be exactly the same thing at this point, because the cart and wind are going the same speed in the same direction.
That being the case, what number for mass should we plug into K=1/2mv^2? The ground speed is 10mph, what amount of mass does it represent with respect to the cart?
vanesch said:You are claiming that the velocity of the cart *wrt the turntable* is smaller than the velocity of the *air* wrt to the turntable ? Or are you claiming that the velocity of the cart *wrt the ground* is smaller (and opposite) to the velocity of the turntable (wrt the ground) ?
Because the equivalence we are after is the FIRST, not the SECOND set of velocities.
This is so terribly trivial that I think you're trolling, honestly.
A.T. said:What exactly is K and how is it relevant to examine if the cart could accelerate further? Again: What matters for acceleration are forces, not kinetic energies calculated in some arbitrary reference frame. When you have computed the acceleration of the cart using forces, you can use the formula above to compute the gain in KE of the cart. Then you plug the cart's mass into the formula.
schroder said:I don’t know what trolling is. I am seriously trying to establish the truth here about this cart.
If you have two cars passing each other on a two way road and all you wanted to know is the relative velocity of the cars, relative to each other, you could pick either car to be the reference for the frame and get the correct result.
But suppose two cars are passing each other and you wanted to know the difference between their velocities. Picking either car as your reference will always give you the sum.
To get the difference you need to pick some other reference, in this case the road. Now you can measure the velocity of each car independently with respect to the road and compare them to get the difference.
In the down wind frame, you want to know the velocity of the cart with respect to the road, not the wind, so you pick the road as your reference frame.
Even though there is also velocity between the wind and the cart in that frame, you ignore this in calculating your velocity because it is obviously not of interest to you. You could pick the wind as your reference but your numbers would not make sense unless you applied a correction factor to convert them into road velocity which is what you want to know.
That one is obvious. In the treadmill test, it is not so obvious and you are picking the tread because you see the cart is moving wrt the tread. It is a little harder to see it moving wrt the wind, but that is what you really should be interested in!
All you really need to do is look at the nature of the beast. On the tread, it is using wheels for input from the tread, and a propeller for output in the air. It is working into the air and it is moving with respect to that medium. Sure, there is motion between the cart and the tread but that is about as interesting as the motion between the cart and the wind in the wind frame. That is the motion between the cart and what is driving it. That is not of interest. You want to know how fast the cart is going in the medium it is driving into, not the medium which is driving it.
You really want the velocity into the wind that is what the cart is driving into. I know this is a bit hard to see but you need to clarify this in your own mind. Once you adopt the wind or floor as the reference frame in the treadmill test, you get believable numbers, but unfortunately they are much less than the tread velocity.
But that is exactly in accordance with any machine which has losses between input and output. If you use the tread as your reference you get these fantastic numbers which are greater than tread velocity.
The cart's frame is not inertial if the cart's speed varies. So it is easier to consider ground's frame.zoobyshoe said:As Vanesch will confirm you have to be in a frame, and any frame you pick is OK as long as you stay with that frame. Thus far I have been speaking about the cart's frame. We can analyze from another frame if you want, but whatever frame we pick we have to stick to that frame.
What do you mean by "the energy the cart has available"? The carts current kinetic energy?zoobyshoe said:The reason I am asking about energy is because earlier I asserted that the cart is in a situation where it no longer has any energy available to it outside the energy represented by it's own momentum.
zoobyshoe said:You have asserted that the speed difference between the ground and air represents "plenty" of energy. If that is the case, then we ought to be able to get a ballpark figure pretty easily by determining what mass should be plugged into the formula.
A.T. said:That is something the torpedo can do too. It is just not the standard operating scenario.
Why do you need two cables? The torpedo needs two for steering, but for a minimal design I would recommend using just one.
Yes, I just wanted to point out, that it is exactly the same mechanism.swerdna said:Wouldn’t that require the torpedo to be used in a river or at least strong sea current?
It could be messy with two cables potentially twisting around each other. One cable coming out at the center rear of the boat scould stabilize it just fine.swerdna said:Yes one cable would be fine. Not even sure why I drew two. Perhaps because the torpedo has two or some intuitive balance maybe.
Sure I didn’t mean to present it as anything substantially new except instead of moving cables pulling against stationary water, moving water (or air) is pulling against stationary cables.A.T. said:Yes, I just wanted to point out, that it is exactly the same mechanism.
DOH!A.T. said:And don't forget to attach the end of the cable at the reel, so you can recover your boat.![]()
The number for mass is the mass of the air affected by the prop. The force is equal to that the mass of the affected air times the affected air's rate of acceleration (or the integral sum of all the components of affected air).zoobyshoe said:That being the case, what number for mass?
That's not what is claimed. There are no claims about cart speed versus tread speed, only cart speed versus wind speed, or better stated that cart speed relative to the tread is greater than wind speed relative to the tread. I've already stated this in a mathematical form that is independent of frame of reference, and you have yet to respond to this. I'll repeat the claim again:schroder said:Your claim is that on the treadmill, the velocity of the cart is measured wrt to moving tread. You are using the frame of the cart to come this conclusion and what you have is relative velocity between the cart and the tread, and that relative velocity is faster than the tread.
Rodger that. The only air that matters is that which directly impinges on the cart, or upon which the cart impinges. Vanesch referred to this as an air column or air section.Jeff Reid said:The number for mass is the mass of the air affected by the prop. The force is equal to that the mass of the affected air times the affected air's rate of acceleration (or the integral sum of all the components of affected air).
This is the prop as "bluff body" you mentioned before, right? It's very apparent in that video of the large cart with the tell tale. The prop is quite different than the usual airplane prop.The carts are designed so when moving downwind at the speed of the wind, the forward force of the air onto the prop is greater than opposing backwards force of the ground onto the driving wheels (plus the backwards force from the ground related to rolling resistance).
Rodger that. The point I was trying to make is that if you're coasting over the ground in the carts frame looking at the ground as a source of power, that huge amount of mass going by at 10 mph isn't the ginormous power source it looks like at all. The power you could obtain from it by virtue of relative motion is only equal to the power it could obtain from you. Likewise, the force it could exert on you is only equal to the force you could exert on it.The ground can be considered to have a huge amount of mass, any work done on the "ground" results in only a tiny change in velocity.
Unfortunately for the cart when it reaches wind = 0 it becomes inert. There is no force from the wind or ground acting on it other than friction.A.T. said:Can the cart accelerate further, when already traveling at wind speed?
acceleration_cart = (force_propeller - wheel force) / mass_cart
therefore:
if force_propeller > wheel force then acceleration_cart > 0 and the transmission makes sure that force_propeller > wheel force
therefore:
Yes, the cart can accelerate further, when already traveling at wind speed!
Here's one train of thought that might help convince that the "treadmill in still air" situation is a least feasible.
Imagine for a moment that the rotating a propeller was replaced by a long “cork screw” (or similar). That is, the wheels were coupled through a suitable drive train to turn this long “cork screw”.
Now imagine that the corkscrew is started into a large block of soft foam (representing the air) attached to the front of the treadmill. If the treadmill is run then the wheels turn and the corkscrew turns and the vehicle will move forward as the corkscrew screws into the foam.
Think of the propeller in a similar way as "screwing" itself forward into the stationary air.
Here’s another little thought experiment that might help convince you. In the spirit of de-bunking perpetual motion devices you can usually assume frictionless ideal operation of most components and of course they still fail to achieve "over unity" operation. So in this spirit let's assume that we have an ideal lossless drive train (wheels, belts and gearing) and further that we can adjust the gearing ratio from the wheels to propeller to any desired ratio. Let's just concentrate on non-ideal lift/drag of the propeller.
First we note that the turning of the wheels is driving the prop, so the inevitable blade drag will mean we require constant torque to keep the prop turning at a constant rate and this torque must be provided by the wheels, giving a retarding force on the vehicle.
Second we note that the lift generated by the prop is providing a forward directed force. So we now have two forces in opposition, the lift on the prop giving a forward force and the rotational drag on the prop which, through the drive train, ultimately results in a retarding force at the wheels.
Since at first sight this thing looks like an “over unity” device our first instinct is to think that perhaps the lift force must be less than the retarding force. However the retarding force at the wheels is dependent on the gear ratio, that is, if we gear it so that the prop turns fewer times for each rev of the wheels then the ratio of retarding force at the wheels to blade drag to is also reduced.
So let's play devils advocate and assume that we set this thing up on a treadmill and hold it until it’s at steady state (wheels and prop up to speed) and we find that the retarding force is indeed larger than the propeller lift and our vehicle goes backwards.
No problems, let's just reduce the gear ratio so that the prop turns less times per wheel rev, and this will reduce the retarding force at the wheels. Arh but you say, this will also reduce the prop speed and so reduce it’s lift. Again no problems, just increase the treadmill speed until the prop turns at the same speed as it did before! Now you can't argue with this, the prop is at the same speed so the lift is identical to before, and the drag at the blades (torque required to spin the prop) is also the same as before, but due to the modified gearing the retarding force at the wheels is now lower than before. Can you see that in principle there is no limit to how much we repeat this procedure so eventually it has to work!
