Can a monkey outrun a bullet and still save her litter?
  • Thread starter Thread starter powergirl
456 replies · 347K views
It is given that there are two sets of real numbers A={a1, a2,..., a100} and B={b1, b2,..., b50}. If there is a mapping f from A to B such that every element in B has an inverse image and
f(a1) ≤ f(a2) ≤...≤ f(a100)
Then the number of such mapping is...
A) C50100
B) C5099
C) C4950
D) C4999
Rogerio said:
9 degrees.
In fact, atan(sqrt(3)/11).
:smile:
why? what was your logic?
I hope it is enough.
Wow. What a brilliant way of solving it.
Hi everyone. I saw this problem in a logic textbook I had in a class many years ago:
Two friends meet after having been out of contact with one another for some
years. They have the the following conversation:
A: I have three sons.
B: What are their ages?
A: The product of their ages is 36.
B: That is not enough information.
A: The sum of their ages is the same as the the number on the building across the street.
B: Give me a minute to work it out with pencil and paper.
B: I've almost got it but I need one more clue.
A: The oldest one has red hair.
B: I've got it.
What are the ages of the three sons?
B: I've got it.
Well, it is a classic puzzle, and I've seen it a couple of times, right in this forum...
https://www.physicsforums.com/showthread.php?t=50813"
:smile:
Rogerio said:
Thanks, Dave!
:smile:
I still don't get it, could you explain your diagram a little please?
Just try to follow the ray, using geometry.
The figure shows the first reflection.
Note the first mirror surface (blue line) , its normal (yellow line) , the reflected ray (pink line) , and the simmetrical points (cyan).
After the first reflection you have to follow the pink line. However, everything goes as you were at the second hexagon following the red line, and so on.
Just follow the ray, and you'll understand!
:smile:
:smile:
There's a puzzle out there that involves figuring out how long a diagonal line you can draw on a cylinder (a toilet paper roll). It's easily resolved by unrolling the toilet paper into its "net" and drawing a straight line across it. I haven't been able to find it.
The closest I've come is the fly-on-a-wall problem, here called Sneaking Spider:
http://www.puzzle.dse.nl/math/index_us.html#sneaking_spider
The trick is that you can lay the surfaces out in a way that allows for much easier geometry. In the laser&mirror problem, you're doing the same thing.
powergirl said:
NOt right;
Can anyone answer this?
2) A murderer is condemned to death. He has to choose between three rooms: The first is full of raging fires, the second is full of assassins with loaded guns, and the third is full of lions that haven't eaten in 3 years. Which room is safest for him?
The lions that haven't eaten for 3 years duhh they are DEAD!
for a riddle posed 4 months and 8 days ago...
you are 4 months, 7 days and 22 hours late - it was answered within 2 hours. :wink:
powergirl said:
Exactly how many slices of 1.5 cm each can you cut from a whole bread which is 22.5 cm long?
The key is the word WHOLE BREAD.
So you can cut only 1 slice, and then the bread is no longer a WHOLE BREAD.
1) A detective was called on a murder scene at 3:00 in the morning .. he found the dead body lying on the sidewalk .. he took the phone of the deceased and dialed the last called number .. his brother answers the call .. the detective said " Your brother is dead quickly come to the spot " .. his brother quickly turned up to the crime scene and the detective arrested him ...
Why did the detective arrested him ?
(i am not an English speaker so there might be mistakes, just ignore them)
2) A mother of two sisters died, at her funeral one sister saw a men and fell in love with him , but he ignored and left . She was disappointed and wanted to see him again , but there was no sign of him , she searched her entire family but he was no where to be found . Other sister says that you won't find him , the first says yes i will and stabs the other sister and she finally found her man ... HOW ??(i am not an English speaker so there might be mistakes, just ignore them)
cause he knew where 'the spot' was. lol stupid brother.
He shows up at her funeral.
Hei guys I'm new to the thread.
I got a mind boggling one for you. (at least i think so)
Tom and an elderly lady got on bus number 56. There are no seats available and both of them have to stand on the bus. Tom reaches up and holds on to the overhead bar for stability.
The elderly lady is unable to reach the overhead bar to stabilize herself thus she reaches out and pinches Tom on his forearm, using it as a handhold.
What can Tom do to make the elderly person let go of his hand, without making it obvious to her that he doesn't want her pinching his arm?
There is going to be tonnes of answers i expect. But only one solution is the most elegant. (a matter of opinion)
1) Fall over
2) Pinch her arm
3) Wipe his snotty nose all over his opposing sleeve
4) Pretend to have minor muscle spasms
5) Put his arm around her as if to come on to her
6) Sit down on the floor
7) Start singing an aria, getting progressively louder
8) Etc.
DaveE
well not too much activity here eh.
here is my answer. better if you re-enact the scene on the bus with someone. (i.e. you are tom and your friend, the old lady)
Old lady: pinches Tom's forearm.
Tom: pinches the other side of his forearm.
Old lady:loses grip on Tom's forearm.
mvp112 said:
2) A mother of two sisters died, at her funeral one sister saw a man and fell in love with him , but he ignored and left . She was disappointed and wanted to see him again , but there was no sign of him , she searched her entire family but he was no where to be found . Other sister says that you won't find him , the first says yes i will and stabs the other sister and she finally found her man ... HOW ??
(i am not an English speaker so there might be mistakes, just ignore them)[/
QUOTE]
Believing that because the man showed up to her mother's funeral the sister who fell in love with the man was a sick psycho-sociopath. She concluded - in her sick mind - that the man had to have paid respects to the mother so by knowing the family - he would show up to a funeral of the mother's family if there were another death. She kills her sister to create a funeral that the man would attend!
Methodical solution required:
You have a thick glass wine bottle that is empty. You have the original cork that was in the bottle. The cork is completely intact and there are no cracks or holes in the bottle - this is NOT a trick question.
Someone forces the cork - and it is very hard to push in with their thumb so they actually may need a blunt object like the heel of a knife - completely into the bottle.
The cork can be seen bouncing around inside the bottle if it is shaken or moved.
How can you get the cork out of the bottle without breaking the bottle or damaging - i.e. cutting or mutilating - the cork?
I have done this in bars and restaurants. In one Chinese buffet restaurant, I showed some of the staff and they couldn't believe it! They ran around telling all their fellow staff members showing them how to do it. They even gave me a green tea gift set!
Fill the bottle with water and freeze it.
powergirl said:
NOt right;
the third becaus elion not eating for 3years are dead
Jimmy, I don't know if I could disprove this but I would suggest that this may not force the cork to exit.
Lets add that you want the cork out now - within 5 minutes - and we don't have any "exotic" liquid gasses or such around!
I'm trying to respond without alluding to your answer thus ruining it for others who don't want to peek at the "spoiler."
Awe inspiring physics/bar trick:
There are a number of ways this could be asked, but the principle is the same. I traded this puzzle/answer for the wine bottle/cork puzzle many years ago!
This is a practical puzzle that can be performed for visual effect - much the same as the wine bottle puzzle.
There is a plate - say 8" to 10" in diameter. It has a slightly curved edge so you could poor perhaps a couple of cups of water into it and the water would measure about 1/4" deep in the middle. The plate is "filled" with water so that it is about 1/2" from the rim all the way around.
The plate is set on a level table or desktop. Approximately 2" from the inside edge of the plate is a quarter. It is thus submerged. You have a "rock glass" or similar - not too thick of a rim and about 2" in diameter at the entrance. The glass is around 5" tall. You have a seedless - Maraschino cherry. You have a pack of matches.
You cannot move the plate. You cannot tip it or slide it etc. You can use any of - and only - the items given. You cannot push or splash - or the likes - the water from the plate. You must get access to the quarter and get it off of the plate with ONLY your finger without putting your finger into the water - basically without getting your finger wet - other than for the fact that the quarter may be a little damp or have a few drops of water on it.
How can you do this? I know of only one way and it is demostratable, not in any way a bizarre notion like waiting for a hurricane etc. etc. etc.
http://www.metacafe.com/watch/455316/the_cork_out_of_the_bottle_trick/
