Can a Radio Wave Camera Be Used to Track Wildlife in the Field?
A radio wave camera for tracking wildlife could theoretically visualize radio signals, but practical limitations exist. The discussion highlights that radar technology is similar, requiring radio waves to bounce off objects for imaging, which may not be feasible with point sources like radio-tagged animals. The size of the antenna is crucial for resolution; larger antennas yield better localization but are less practical in the field. The user currently employs an H-antenna at frequencies around 218 MHz, but achieving usable resolution would necessitate a significantly larger antenna. Creating a portable radar screen with a collapsible antenna could be challenging and potentially costly.
peteypete
I work in wildlife science. I track radio tagged animals, and am wondering if it's possible to make a radio wave camera, that can detect and visualize radio waves on a screen. I could use this camera to see the source of a radio signal (i.e. which bush or tree an animal is hiding in). This would be much easier than trying to guess based on my directional antenna and radio receiver, which only gives me a general direction. I'm guessing that I would need a very wide "lens" for radio waves, but I'm just curious if this idea makes any sense at all. I'm obviously not very savvy on this topic.
thanks
Science news on Phys.org
Sure, that is what radar is.
In order to get an idea of what is possible or practical could you tell us the frequency, manufacturer of your equipment or at least the length of the driven element of your antenna? I presume you're using a single yagi antenna (a series of vertical elements along a beam) and look for the strongest received signal strength. Is this correct?
It sounds to me what you're asking for is a small video screen, perhaps showing the scenery using a video camera with a radio image overlaid on top of it. While I don't think this is impossible, one consideration you should be aware of is the more you want to localize the source, the larger your antenna or antennas have to be. You can reduce the size of the antennas by going to a higher frequency, but the higher the frequency, the poorer it penetrates foliage and the more it is blocked by intervening objects.
Welcome to PF.
You're describing RADAR. But you need radio waves to be bouncing off of objects in order to create a picture. You don't have that - all you have is point sources. So your picture would only be a small handful of dots.
Also, the longer the wavelength you're trying to observe, the larger your "resolving angle", which is essentially how "smeared out" an image is. In order to get a decent picture, you'd need something much bigger than a conventional camera.
Something, say, this big:
[PLAIN]http://learn.uci.edu/media/OC08/11004/OC0811004_RadioTelescope.jpg
Thanks for the replies!
Skeptic2, that's exactly what i had in mind. I do use an H-antenna, it's about 65cm from end to end, and the frequencies are around 218 MHz (some are at ~160 MHz, but those use slightly different sized yagi). I had a feeling that Archosaur's radio telescope is what I'd need. Obviously not very practical in the field. I don't need any imagery of the surrounding area -- I would be fine with just a dot, but it sounds I'd need a huge antenna to get usable resolution.
Out of curiosity's sake, if I managed to make some kind of big collapsible antenna, would the rest of my portable radar screen contraption be difficult/expensive to make?
thanks again!
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
