Can a robot be called as Living thing?
  • Thread starter Thread starter scienceisbest
    Robot
106 replies · 48K views · last reply
Pythagorean said:
1) We can test the light objectively to see it's not the same color.
I'm sorry, but no you can't. What you can do (and this is actually how XYZ color space was established) is to test the reaction of the brain to some light in some specific condition. If, from that experiment, you conclude that color is a property of light, then you'll come to make wrong predictions.
Pythagorean said:
it's difficult for somebody with all the properly functioning visual processors and receptors to mistake blue for red.
For anyone with all the usual proprely functionning visual processors and receptors, it's very easy to see the very same light as http://www.colorcube.com/illusions/chrmadptb.htm" . Blue instead of red can be done the same way.
Pythagorean said:
2) We might understand why it is that we see like this by objectively understanding evolution.
Sure. The fact that the properties of the light is not enough to know the color doesn't mean this escape physical laws. This just mean that what you really need to define color is to know how the brain construct this perception.
Biology news on Phys.org
Of course you can. The key word was "objective", as in: not subject to the whims of the brain's interpretation.
The most obvious way of doing it is to use an instrument, such as a color densitometer.
But you could still do it (at least roughly) with your eye the same way you do any objective test: isolate the subject from background noise and other interfering variables. You could physically cut the two swatches away from their background and hold thenm side-by-side and see that they are the same (within your limits of perception).
Point of order (clarification): 'what colour is the swatch?' was proposed as analagous to: 'is it alive'. We are on a tangent, discussing whether or not the two questions are analogous. The first can be determined objectively, the second is still under debate.
If we accept that a defining characteristic of living things is being composed of cells, then there is no debate. Robots are not, and most likely will never be made of cells (at least not entirely in the biological sense). This whole thread is meaningless (or trivial) unless we view living systems in the larger context of systems generally and define what the special characteristics of living systems are in reference to systems in general.
So you're predicting that, assuming the same background, two identical lights will always be perceived as the same color.
Ring of ten magenta blurred dots of equal size evenly spaced around a small black plus sign at the center, on a grey background.
Out of random curiosity, how many wrong prediction do you need before considering seriously that the physicalist point-of view you adopt lack soundness?
Sire, I don't want to be rude in anyway, but the fact is... I'm not trying to argue, I'm trying to explain. :wink:
Sure. Still there would be at least one debate: is it a sound definition?
You're missing the point. There's an objective measurement of light that we call "color" based on its frequency. Not arguable. This is what I mean by objective color.
Human perception of color can be related directly to it by (for example) the cone sensitivity functions.
Thus, we have a bridge between objective definitions of light and human perception of light.
Do you recognize the contradiction here? You're talking about light objectively. You're saying "somebody can see blue as red". That only makes sense if blue is objectively blue. Otherwise you may as well just claim solipsism.
But I concede that you can construct experiments where we see red and blue; your demonstration of this has proved by main point, though.
Which we already have a good start on understanding (I mentioned the cone sensitivity functions. Understanding the processing is still under way and has been productive).
I promise I perfectly see your point, which is that we can objectively test the spectral properties of the light and call that objective color. All what I'm saying is that you'd better call that spectral properties. Because if you put color in the name, you will soon confound it with color, which is not the same, and that will soon make you doing wrong predictions -as the two I evidenced above.
Of course we have -in some specific conditions. What you would need to say, if you want to remain both objective and right while talking about color, is the following:
Given the spectral properties of this light, it's color match a specific combination of three monochromatic lights adjusted in brightness, assuming both are presented to an average quiete human on each side of his/her visual field by using two circular split screens 2 degrees in size with a black background.
This would be absolutly true, not arguable, and color. Now each time you go outside of these specific experimental conditions, you need to question if your colorimeter is still well calibrated in regard to color -of course this won't be necessary if what interests you is the spectral properties of the light.
What I meant was you can see the very same light as blue or red. I think you stretching my sentence here. However, I recognize that the physicalist point-of-view is very easy to take. So maybe you'll notice some occasion on which I'll do the mistake, but that's not to say it's not a mistake ;-)
Of course we have! How do you think I was able to find the evidences above if not from knowledge about color perception?
BTW... if I need to develop the idea again and again, then obviously the metaphor was of no help. I suggest we either stop here or continue the discussion in another thread. ;)
I was actually thinking about this question the other day. But I came at it from a different view. If we lived in space on a space ship, would that spaceship not be apart of us just as much as cells are apart of us? With out this ship we will die, and it is this relationship that makes it alive. If this ship one day became self aware it would see us building it and taken care of it. Just like we see our cells doing for us. I heard somewhere that everytime we use a tool our brain does not know the difference between the tool and your hand.
If we lived on Mars and had to wear space suits, those space suits are as real as our skin. I know this is a crack pot idea but I think our idea of what is alive and what is not is a lot more blurry than we think. The fact that our technology seems to mirror so much of our biology could mean that it is still our cells that are in charge and we (humans) are just one step in a grand machine. We are just a gap between biological and mechanical.
That does not make it alive.
"Real" or no, they are not part of our biological system.
Yes. No.
You are making the mistake of thinking a metaphorical similarity (a space suit is a skin) is equivalent to two things being the same (the Moon is a baleful eye).
DaveC426913 said:
The basis of the definition of life is:
- it eats and excretes
- respirates
- grows
- reproduces
- reacts to stimuli
There's all sorts of nuancing but it starts with those.
Ok, I know this is going to ask you to stretch here, but.
Data on star treck was an android
who could eat and excrete.
could breath (movement to simulate)
breath deep and read on.
It would be wrong of us to ONLY look for life as we know it and suspect something that is not like us, is not alive.
There are by percentage alone to many stars in the milky way alone that could "have life" and then when you consider each galaxy and the sheer number of them.
It becomes obvious that man would be totally arrogant to assume that his form alone is the only possible option. we have found life at the bottom of the ocean that feed off the thermal heat that would crispy critter us.
I understand your definition of life, its very humanist of you. but remember, we are 1. creation: made after our maker. 2. evolved: due to the stimuli of our environment.
what we are today, and will be in the future.
Grimstone said:
http://gizmodo.com/5704158/nasa-finds-new-life
so I'm not just spouting my thoughts.
I do agree with your view, and I have advocate why. But please don't put this in support of it: the probability of ******** is one the highest I saw published in a peer-review paper.
Yes. According to our definition, Data (on Star Trek ) is not alive.
Also, I'm not sure if he eats and excretes for real, or if he only simulates these activities.
Also, he does not grow (except mentally).
And most importantly, he cannot reproduce. Data is an artifact; he was constructed and there is no method for making a reproduction of himself (not even his creator - though he could (and did) manually reconstruct another).
Data is a machine - a very life-like one - but a machine nonetheless.
Note that "looking for Datas" on distant planets would be equivalent to looking for alien technology like buildings or spaceships on distant planets. What we want to find is Data's creators - that's seeking life.
Grimstone said:
sorry forgot this.
What a sensationalist article.
"...unlike anything currently living in planet Earth..." :rolleyes:
"...a bacteria whose DNA is completely alien to what we know today, working differently than the rest of the organisms in the planet..." :rolleyes:
"...Instead of using phosphorus, the newly discovered microorganism ... uses the poisonous arsenic for its building blocks..." :rolleyes: :rolleyes:
"... this breaks our ideas on how life can be created ..." :rolleyes:
This is typical of reporting. I guess its a lesson not to take news seriously all the time (except maybe for the weather). I saw this on a another thread " PATIENT CURED OF HIV". when we go into the details, its not as one would have expected.
Maybe. But, at least for this time, it's not fair to complain about reporters.
http://www.sciencemag.org/content/early/2010/12/01/science.1197258.abstract
I'm not saying we should not complain. :rolleyes:
The finding of arsenic based life is not a radical shift from what is known by biologists. The study is just that life is able to adapt even in hostile conditions. This does not in anyway change the definition or what we call life. In fact life is complex chemistry. But there are restrictions for what type of complex chemistry it can be.
I strongly disagree. Arsenic is clearly not something you could have expect to integrate DNA. This would implicates profound changes in the metabolism and even worst, in the genomic stability. So no there is no way to qualify this tentative finding as expected. The fact that this finding was not proven and is probably wrong does not make it standard.
I do agree we this interpretation. The fact is: we already knew it. :rolleyes:
Lievo said:
Arsenic is clearly not something you could have expect to integrate DNA. . .
I Don,t have access to the entire article . Its not exactly sure what type of molecules have substituted phosphate for arsenate.
which substitutes arsenic for phosphorus to sustain its growth. Our data show evidence for arsenate in macromolecules that normally contain phosphate, most notably nucleic acids and proteins. Exchange of one of the major bioelements may have profound evolutionary and geochemical significance.
The finding only proves to show that there can be substitutes for what was thought to be the norm (rest of the chemistry remains the same like carbon, hydrogen , oxygen, nitrogen) i.e. phosphate.In fact there has been an idea by biologists that carbon can be substituted for silicon.
Nucleic acids refers to DNA (Desoxyribo- Nucleic Acid). It could have referred to RNA too (Ribo Nucleic Acid) but in this paper this is about DNA.
For proteins, we could imagine that things would remain as usual even if some arsenate was included in some protein, for exemple the way hemoglobin includes iron. This would be new proteins, and maybe someone will find some applications so as to become richer than Bill Gate. Boring.
But not for DNA, where the arsenate would have to replace phosphate. Arsenate does not have exactly the same chemical properties as phosphate (in fact, that why it's toxic). So if you destabilize the DNA by putting arsenate instead of phosphate at some places, you can expect that will change the genomic expression: instead of a given standard mRNA, this will produce several chains or a shorter one, leading to different amino acid chains, then different proteins, and most likely no functionnal ones.
To prevent this (so that the cell survives), you have to imagine a yet completely unknown mechanism by which either the arsenate always go on non functionnnal DNA, or a mechanism able to repair these problems. In both cases, this would implicate a completely different mechanism as the ones we know, and that's why it would have been a striking result: you can't find new mechanisms regarding DNA and expect it to be boring.
This would necessitate a completely different form of life. We can imagine, but chemists are skeptical that silicon can lead to a biochemistry as rich as carbon do. Most would however agree that this statement is valid for our conditions of pressure and temperature. For an other range of pressure and temperature, let's recognize our quite complete ignorance.
Archosaur said:
Here's a sort of thought experiment:
If a person has a prosthetic leg, is he still human? Of course!
What if he has two prosthetic legs?
Two prosthetic legs and an artificial heart?
What if every organ is replaced with a mechanical substitute, even the brain, the contents of which are "downloaded" into a network with transistors instead of neurons?
After which gradual step is he suddenly no longer human?
the questions WAS, Life.
now the question becomes human?
once the brain is replaced. that thing is n o longer a human. it could be programed to act as human as it can but it is not human.
is it alive? debatable.
So we have 6 pages of highly intelligent humans talking together to come to a mutual conclusion of a question.
and the answer is?
and the answer is?
Yeah, "?" sounds about right. Let's come to a consensus about whether or not a virus is alive before we start tackling absurdly complex constructions.
...What did you expect?
This question belongs in the philosophy forum, not biology. language follows reality, not the other way around.
I disagree. While this is a philosophical question, I'd rather hear what biologists have to say than philosophers.
Biologists can discuss this in the philosophy forum just as philosophical questions re physics are discussed in the "new improved" philosophy forum now. In any case, it's for the mentors to decide. I'm just giving my opinion.
As I said, language follows reality. The reality for biologists is described by the language of biology. It's not clear to me that this language describes robots or the human-robot distinction. Until such time as this is part of biological science, it should not be a subject of discussion in this forum IMO. We've already had over 80 posts and gotten nowhere.
in theory they could, in practice they don't
me too
that's because the biologists answer is "we don't know". Philosophy forum won't be any more productive. To speak in generalities, experimental biologists can articulate the question into falsifiable experiments, which is stimulating to theoretical biologists.
It's already been hinted at that we still have trouble with defining life when it comes to a known candidate: viruses.
I would think a more general, abstract framework (such as information theory) might have something to say about defining life, too.
I don't believe we can AFFORD to believe that these are questions only for philosophers, or they're going to be alone in this thinking when scientists are called to testify and help make these determinations.
"What is life" is philosophical, but how to define a machine with as much or greater complexity than its builders strikes me as something that could be practical.
And no... I'm not saying we're on the brink of "Judgement Day", just that the same reasoning is going to be applied to cloning and other issue.
It's called: "Bio-ethics", and I'd say this falls into the biology side if we stick with the OP.
Who said these type of questions are only for philosophers? I didn't. I said this was a philosophical question. The scientific answer to the OP's question is "no". The biological definition of life is narrow and focused: RNA, DNA based replicating organisms including viruses. Prions are borderline, but are studied by biologists because they are replicating proteins and interact with living systems. Beyond this we get into opinions and speculation.
The ethical questions that might arise with intelligent robots certainly are important philosophical questions deserving serious discussion. Should a science forum deal with ethics (other than perhaps the ethics of practicing science)? I don't think so, but that doesn't mean scientists shouldn't get involved.
You're illustrating a point I made earlier that the scientific definition may change if we face a robot that our brain will obviously consider alive. I was answered that the biological definition of life is narrow and focused. And excluded viruses. :redface:
