Can a skateboarder ride faster by holding a water bottle?
  • Context: High School
  • Thread starter Thread starter Devin-M
The discussion explores whether a skateboarder can achieve greater speed by holding a water bottle, considering factors such as balance, biomechanics, and the effects of added mass. Participants examine the implications of holding a bottle during skating, including potential benefits and drawbacks related to stability and performance.
  • Some participants suggest that holding a water bottle could counterbalance the torque induced by ground kicks, potentially allowing for more powerful kicks without toppling.
  • Others argue that the biomechanical efficiency of the rider is complex and question how a bottle could achieve balance improvements that could not be accomplished by adjusting body posture.
  • A few participants propose that while the added mass of the bottle might not increase speed, it could help with balance and cornering, drawing analogies to animal biomechanics.
  • Some participants express skepticism about the effectiveness of a relatively light bottle compared to the rider's mass, questioning whether it could significantly impact performance.
  • There are discussions about the mechanics of balance, including the role of weight distribution and how it relates to the rider's center of mass.
  • Several participants introduce hypothetical scenarios involving pendulums and robotic arms, exploring the dynamics of balance and torque in relation to the water bottle's position.
  • One participant shares personal experience, suggesting that holding a bottle could complicate balance and performance due to asymmetry and increased difficulty in maintaining stability.
Participants do not reach a consensus on whether holding a water bottle would enable a skateboarder to ride faster. Multiple competing views remain regarding the effects of added mass, balance, and biomechanics.
Discussions include various assumptions about rider posture, the complexity of biomechanical efficiency, and the relevance of weight distribution, which remain unresolved.
Devin-M
Sorry for the ridiculous title but this is actually a serious question.
Suppose we have a skateboard rider, right foot forward, left foot kicking. In one case the rider extends their arm directly forward holding a water bottle, in the other case they don’t. If the solution is limited not by the average output power of the kicks, but by the rider staying in balance, can the rider go faster holding the bottle and faster still if the bottle is heavier?
If the answer is yes, I suspect the bottle counterbalances the torque on the rider’s body induced by the ground kicks, so the heavier bottle enables more powerful ground kicks without the rider toppling.
This is way too vauge. How would the bottle achieve anything in terms of balance that cannot be achieved by changing the body pose? Biomechanic efficiency is very complex.
Physically, you could use the bottle to store additional momentum by accelerating it forward when the foot is pushing off, and backwards when the foot is off the ground.
Could use it to get deeper digs when slaloming... but then there's the increased overall mass.
I don't see how adding an extra mass could allow the rider could go faster, but I can see how it might allow them to balance and corner better. The water bottle is functionally comparable to a counterbalancing big tail on a squirrel or cheetah.
(Although I question how effective a 355g mass is to a 70,000g person.)
Doesn’t the rider need some weight forward to prevent the kicks toppling them backward? For example a one wheel electric board, the more the rider leans forwards the faster the constant speed. For example gravity trying to topple the rider forward while the force from the wheel prevents this.
Well, his whole body is going to balance that out. It's about 200x more massive than the bottle.
On a one wheel electric board, if the only change was putting the bottle forward would it be faster?
No amount of added mass will make any rider/vehicle faster**.
However, as A.T. points out, biomechanical efficiency is very complex, and it is certainly plausible that a rider might use a small mass on the end of his arm to help him balance a little better - again - like a cheetah uses their massive tail as a counter-balance when cornering.
I'd say performance on such vehicles is certainly a matter of practice, skill and a lot of personal style. Some certain number of riders might feel a counter-weight helps them perform a fraction better, but I think that's on a case-by-case basis - by that I mean I doubt one could prove that, objectively, a rider carrying a bottle could outperform a rider without a bottle - all other things being equal.
But I am neither a biophysicist, nor a board-rider, so I speak from ignorance.** excepting, perhaps, parachutes and the like
Consider an inverted pendulum fixed to a segway or one wheel board that has a robotic arm able to lift a water bottle forward. With the bottle lowered the pendulum is balanced and segway/one wheel board is stationary but with the bottle raised forward the pendulum is out of balance, leans forward and the segway / one wheel board begins to move in the direction the water bottle was lifted.
The idea is silly.
A Segway or one wheel board is going to be limited by motor torque and wind resistance. And, of course, the speed limiter. Once you've disabled that and paid up your life insurance, you would want to attain the maximum stable forward lean angle in a crouch to reduce wind resistance and tilt the mechanism to maximize forward thrust.
Manipulating a water bottle is a clumsy way to mimic adjusting your lean angle.
Would it take more torque from the wheel to counteract the torque of the leaning pendulum if the pendulum began telescoping so it was longer (weight concentrated at the end of pendulum)? Suppose the pendulum is already leaning as far forward as possible without touching the ground (or 90 degrees from vertical).
The height of the pendulum is irrelevant to the torque balance. Only the angle to the mass center matters.
Wouldn’t a longer pendulum act like a longer lever on the fulcrum at the hub, generating more torque?
I don't understand the significance of the pendulum and segway example. What does this have to do with a person riding a skateboard?
A segway has a tilt sensor coupled to its motor electronically so that the speed is computer-controlled by the tilt. That has nothing to do with a human-powered skateboard.
:oops: Are you swinging the water bottle in a circle?
Do you accept that these skaters are both balanced and neither will go faster than the other?
  • Haha
I suspect the 2nd rider may have kicked harder to retain balance as the longer arm acts like a telescoping inverted pendulum.
People don't hold their arms out front when kicking in the first place, so we're already starting off with a situation that people aren't really used to. Instead, they lean forward and bend their knee slightly, holding their arms down and out to the side, which keeps their center of mass both centered over the board and lowers it closer to the ground, making it more difficult for the person to topple over. See below image.
While it is certainly possible to hold a water bottle (or another object) in your hand while skateboarding, my own experience with various physical activities similar to this leads me to believe that it would actually make balancing and using the skateboard more difficult. Especially since a single water bottle introduces an asymmetry and probably makes it more difficult to balance left/right. Increasing someone's weight and making the load asymmetrical tends to make things harder, not easier.
I'd think the asymmetry would be too small to make a difference, its not like we have trouble walking carrying a bottle.
On the other hand, regardless of which hand its in, having a weight on the end of an appendage would allow for some balance leverage, a little like a tightrope walker with a pole.
Sure, but the point is, it doesn't contribute to going faster.
Are you saying if they kicked harder it didn’t make them go faster?
  • Skeptical
Of course it would - either of them would go faster if they kicked harder.
The water bottle and extended arm is irrelevant.
Im curious why it seems to work for inverted pendulum on segway but not skateboard? Once the inverted pendulum is horizontal, and the wheel is outputting enough torque to keep it at that angle, the only way to go faster at constant speed seems to telescope the pendulum as that requires greater counter-torque from wheel to maintain angle.
Looks to me like skateboarders have to shift their cog backwards to counteract the counter-clockwise torque of the foot-pedaling force (which is mostly up, not forward).
But this thread is really weird. Such a bizarre and seemingly pointless question.
"go faster at constant speed" You mean go faster at constant angle?
Yes won’t telescoping the inverted pendulum allow faster speed at constant angle?
You mean increasing the length (telescoping could go either way). Seems like it would to me.
My skateboarding experience is too limited to say much in this thread. But it seems to me the idea is that the waterbottle increases the angular inertia of the rider, thus allowing stronger strokes.
Again: A segway has a tilt sensor coupled to its motor electronically so that the speed is computer-controlled by the tilt. It's programmed to do that. (If it did it naturally, it wouldn't need a computer to coordinate it.)
Yes, but the farther the inverted pendulum length extends (assume pendulum constant angle parallel to ground), the motor in the wheel needs to generate more torque to maintain the constant angle, leading to acceleration until the wind drag balances with increased torque at greater constant speed as the pendulum length increases.
Returning to the opening question:
Devin-M said:
... can the rider go faster holding the bottle and faster still if the bottle is heavier?
No.
  • · Replies 38 ·
  • · Replies 26 ·
10K
9K
