Can airfoils generate lift when inverted without extra thrust?
45 replies · 18K views · last reply
DaveC426913
2025 Award
Recently, I was discussing airfoils with a friend. I thought I was being clever and said "No, Bernoulli's Law isn't what's keeping it in the air - that's a fallacy. If it were Bernoulli's Law keeping it in the air, then airplanes would not be able to fly upside down. What keeps a plane in the air when flying upside down is the angle of attack."
He came back with "No, what keeps a plane in the air when flying upside down is the fact that planes that fly upside down are so overpowered that simply pointing the thrust in the desired direction (say, up) will cause the plane to go whereever the engine takes it, wings or no - and despite Bernoulli's Principle."
I had to concede right then and there.
So: can a plane fly upside down using airfoil-generated lift, as opposed to thrust-lift? Evidence?
A symmetric air foil would be a good example of one that can fly upside down or right side up without a degradation of it's properties. For non-symmetric air foil, all it takes is a small adjustment of the ailerons to give it lift in the upside down direction.
If the plane's lift were all thrust generated, it would be pointing straight up! Angle of attack, ailerons etc. can all explain it however.
There's an old thread about this as well: https://www.physicsforums.com/showthread.php?t=130414
...or just some angle of attack!
Bernoulli's law is an important part of how airplanes fly - it isn't a fallacy. The fallacy is the 'equal transit time' argument, which in a double-fallacy is often fallaciously connected to Bernoulli's principle. The two are not connected to each other.
A cambered airfoil that is upside down can still produce lift as long as it is at a positive angle of attack. It will likely need a higher angle of attack and will produce more drag but it will still generate lift.
Well firstly, are all aircraft that can fly upside down "overpowered"?
Secondly, whether it's through thrust or aerofoil, AoA is the key. Level flight, with all the thrust possible and no aerofoil just isn't possible - there's a b*tch called gravity that kicks in - think bullet.
That is the question I'm asking, yes.
Um. Thrust can oppose gravity. Think rocket.
'tis. One of the tricks they do at airshows is having an F-15 stand on its tail.
Actually, a more on-point question is this: on an airplane flying upsidedown, does the lift from angle of attack significantly* exceed the downward force generated by the camber of the wing?
If so, AoA is a dominant lifting factor.
If not, then overthrusting is the dominant factor that keeps the plane aloft.
* I'm sure that, at a high enough AoA, the low pressure above the wing will likely exceed the pressure under the wing despite any camber. The question is: is there enough to lift the plane, or is it only enough to help?
Um. If all thrust is directly horizontal, there is nothing providing lift so no, it isn't possible. (Well I suppose if we start talking orbital velocity and rockets... but I don't know if aircraft count in that domain.)
Is that considered level flight? I'd think the attitude indicator and artificial horizon would disagree and say you've got one hell of an angle of attack. But that's up to you.
Perhaps I should have been clearer. When I said "level flight" I was referring to a trajectory with 0 AoA (just to make sure I'm perfectly clear here, AoA in relation to the horizontal).
This is easily answered by checking if there's an aircraft that can fly upside down that isn't overpowered (I'm having a look).
Well what does that even mean? What does one thing have to do with the other? The F-16 has a ridiculously high thrust to weight ratio - does that make it "overpowered"? That ridiculously thrust to weight ratio has nothing at all to do with what makes it good at inverted flight: what makes it good at inverted flight is its symmetrical airfoil.
An airplane with a cambered airfoil will perform worse upside-down than right-side-up. How much worse depends on the plane. How big of an impact the engine thrust has, both on the ability to overcome the higher drag of the higher angle of attack and its direct contribution to the lift depends on the plane. But only fighter jets, stunt planes and models are capable of getting the vast majority of their lift from their engines and standing on their tails.
That's a nonsensical question: a wing either produces positive lift or negative lift, not both at the same time. Trying to separate what the top and bottom surface of the wing does is pointless because even in normal level flight, the bottom surface typically doesn't make a positive contribution to the lift unless the angle of attack is very high and/or the airfoil very cambered.
What actually matters is lift to drag ratio. An inverted cambered airfoil needs a higher angle of attack than a symmetrical airfoil (or an upright cambered airfoil) in order to produce lift and with that higher angle of attack comes higher drag. Higher thrust is required to counter that higher drag and keep the plane moving forward.
But again, that's still different than saying that the engine itself is supporting the plane. I'd say that in neither case (even in the "overpowered" case) is the engine itself providing a substantial fraction of the lift. An F-16 can stand on its tail with a 90 degree angle of attack, but at a 20 degree angle of attack (inverted), the engine isn't providing anywhere close to enough lift to keep the plane in the air (roughly 1/3 of what is required), but it flies just fine. The wings provide the lift. Your friend is still wrong.
For most planes flying upside-down at moderate angle of attack, the wings provide the vast majority of the lift to make them fly. I'd even say that a plane standing on its tail strains the definition of "fly" for an airplane - as you said, a rocket stands on its tail. Right: not an airplane.
I've actually been considering that. My first thought was when supplying something with 'excessive thrust'. But then, what is excessive? Those aircraft are designed with it so it's not excessive, it's perfectly normal.
A possibly even bigger and again separate issue is other design features that may prevent inverted flight such as fuel flow control and structural integrity. I remember from flying WWII flight simulators that some of the airplanes would fly just fine inverted...until the engine cut out after a few seconds due to failure of the fuel supply!
Dave's friend seems to define "excessive" as the engine providing amost all of the thrust required for inverted flight. That's what's required for an engine to take an object where-ever it wants, wings or not.
DaveC426913 said:
He came back with "No, what keeps a plane in the air when flying upside down is the fact that planes that fly upside down are so overpowered that simply pointing the thrust in the desired direction (say, up) will cause the plane to go whereever the engine takes it, wings or no ...
That doesn't make sense. Draw a freebody diagram of the plane. In order for this to be true, the weight of the aircraft (assuming wings are not contributing to upward force) has to be balanced by the vertical component of thrust produced by the engine. When I see aircraft flying upside down, the angle of attack is relatively slight, say much less than 45o from horizontal, probably more like 10 to 25 degrees. So now you can calculate the thrust the engine must produce by assuming the vertical thrust is equal to the weight.
Te = Fv / sin (A)
Where
Te = engine thrust or force produced by the engine in the direction the aircraft is heading
Fv = vertical force produced by the engine's thrust and is equal to the aircraft weight assuming the wings don't produce any upward force
sin(A) is the angle from horizontal that the aircraft's axis of thrust is pointed, say on the order of 10 to 45 degrees.
If we have a 5000 pound aircraft flying inverted at an angle of 15 degrees to the horizontal, the thrust produced by the engine has to be a whopping 19,300 pounds! This aircraft could easily accelerate straight up like a rocket. In that case, you'd be pinned to your seat with nearly 4 G's of force flying straight up. So no, there MUST be some upward force produced by the wings in any aircraft flying inverted.
Q_Goest said:
Te = Fv / sin (A)
Where
Seen this topic at lunch and didn't get a chance to respond. . . this is what I was planning on typing though.
I didn't say anything about thrust being horizontal. All of this is based on your addition of that factor.
It's prefectly sensical. The contribution of the components can be separated for the purpose of comparing what is doing the contributing, even if it's abstract. If I have a single wing where 3/4ths of it has a +ive AoA, and 1/4 of the wing has a -ive AoA, I can certainly break its components out to see how they contribute to the overall lift.
Thus, overpowered.
OK, so you're saying that
1] if we were to remove the wings from the plane, in order for the plane to remain in the air at a 15 degree angle from horizontal, it would have to have so much thrust that, should it turn vertical, that much thrust could accelerate vertically at 4gs.
2] Since no plane can do 4gs straight up, that means no plane could keep itself in horizontal motion simply with thrust angled up at 15 degees.
3] Since real planes do maintain horizontal motion while angled only 15 degrees up, the only way this is possible is if the (inverted) wings are providing the bulk of the lift.
Hm.
I said "level flight". I was trying to imply the aircraft was horizontal with the thrust directly horizontal. I obviously wasn't clear on that and clarified it later (a lot). I do apologise for my hazy description.
Why break it down though? It's either producing lift in the required direction or it's not. If it's not, then the engine is obviously the supporting device.
Thus, overpowered.
Only overpowered if it isn't designed to have that much power. If I design an aircraft to put out that much thrust, for some reason, then it isn't overpowered.
Because the claim is that an inverted wing is producing lift. I wanted to examine the components to see what's doing that.
I am not using a strict definition of overpowered. I am simply saying the plane will go where the engine pulls it, wings or no.
An inverted wing can produce enough lift to lift an aircraft. It just won't be as efficient.
Please back up your claim. I can't very well claim that I've made my case because some random guy said so. :wink:
DaveC426913 said:
Recently, I was discussing airfoils with a friend. I thought I was being clever and said "No, Bernoulli's Law isn't what's keeping it in the air - that's a fallacy."
I suspect you are both misunderstanding what "Bernoulli's Law" actually is. Certainly your friend is misunderstanding it.
It is misleading to call it a "law" or even a "principle". Bernoulli's EQUATION is simply a re-statement of Newton's third law of motion for a fluid, using pressure and density as variables instead of force and mass. The is no new "principle" involved in it. It's doesn't say anything specifically about airfioils.
Just take him to an airshow and listen to some propellor driven planes flying straight, level, at constant speed, and inverted. The engine will be making the same amount of noise as when they fly straight, level, at constant speed, and non-inverted. So the engine power is about the same either way up.
Even better, watch a sailplane doing aerobatics. They can fly inverted just as well as non-inverted, with no engine at all.
Here's a good example of the same airfoil being utilized right-side up and upside-down at the same time. Looks to me like airfoil's generating lift in both directions (small aileron and AoA changes), so the OP question has been answered. Thrust is definitely not the only thing keeping these planes in the air.
Hm.
Yes. But the 15 degrees is just an example. Plug the numbers into the equation and you find that to maximize the amount of vertical force produced by the engine, the aircraft has to be turned vertical. The vertical component of "lift" produced by the engine alone (without wings) is a function of the sine of the angle. Knowing that only military aircraft have a thrust that might exceed the weight, and that typical acrobatic aircraft have a thrust that is far less than the weight, it is impossible for any aircraft that doesn't have a thrust to weight ratio greater than 1 to fly inverted without a wing. For military aircraft with a thrust to weight ratio of slightly more than 1, such as the http://en.wikipedia.org/wiki/Thrust-to-weight_ratio" , that aircraft couldn't fly at less than a 66o angle from horizontal without having some contribution of lift from the wings. We've all seen F-16's at air shows such as shown in the photo above, flying aproximately level. Therefore, one can rest assured that the math is telling us that the vast majority of the lift is being produced by the wings.
Here's a lift calculator you can play with, Dave: http://www.grc.nasa.gov/WWW/K-12/airplane/foil3.html
The graph at the lower right shows the pressure profiles along the upper and lower surfaces, though it doesn't integrate for lift per surface, just total lift.
Try these values (all others default):
Camber: 5.0
Thickness: 12.5
Then picking a few AoA values yeilds the following:
AoA: ... Lift: ... Drag:... L/D
-10.1 .. -1506 .. 166 ... -9.0
-10 ... -1484 .. 163 ... -9.1
-8 ... -902 ... 86 .. -10.4
-6 ... -298 ... 43 ... -6.9
-4 ... 324 ... 35 ... 9.0
-2 ... 928 ... 63 ... 14.6
0 ... 1508 ... 122 ... 12.3
2 ... 2065 ... 209 ... 9.9
4 ... 2601 ... 319 ... 8.1
Lets say your aircraft weighs 1508 lb (this is all arbitrary, of course). At 0 degrees AoA, it can fly straight and level at whatever speed that applet is using, providing lift equal to its weight. It also produces 122lb of drag, for an L/D ratio of 12.3:1. To fly straight and level, inverted, requires -10.1 degrees of angle of attack and produces 166lb of drag (36% more) for a ratio of 9.0:1. So that's a pretty substantial difference in angle of attack required for inverted vs upright flight and somewhat substantial difference in drag, but at 10 degrees, the engine still doesn't contribute much to the lift and at 36% more drag, no plane would have trouble maintaining speed (otherwise it would never be able to fly with it's gear down!).
Typing Bernoulli into Google autocompletes with Bernoulli's Principle, the first hit of which is the Wiki page of the same name, sooo... take it up with google and Wiki. :wink:
Well, if that were true, and if it were easy to confirm all those parameters - including engine speed - I'd agree. But I am very dubious about how reliable this is as a test. Too dubious to consider it a valid experiment.
Camber: 5.0
Thickness: 12.5
I haven't downloaded the app to run it but those numbers confuse me - probably because I don't really know a lot about aerodynamics.
Why would an AoA of zero allow a plane to fly straight and level? I thought AoA always had to be +ive. Is that lift just due to the camber?
Also, why does L/D go +ive while AoA is still -5, and why does L/D max out when AoA is still -ive?
I think I see. Because the wing has camber, it means that lift can begin increasing before drag does (since it's at AoA = 0).
Seems to me, the conclusion to be had is that, to get the best L/D ratio, a plane's wings should actual have a slight negative AoA.
Finally, I still see how to the chart helps undetrstand inverted flight.
Maybe if I play with the app...
DaveC426913 said:
Typing Bernoulli into Google autocompletes with Bernoulli's Principle, the first hit of which is the wiki page of the same name.
Wikipedia has a lot of dumb crap on it. It isn't really a valid source all the time. Still, I would contend that Bernoulli's Principle is a perfectly valid way to describe it, but it is not common to see it referred to that way in text or by aerodynamicists as it is misleading; in some ways, it really is a misnomer. Most aerodynamicists just call it Bernoulli's equation since it is, after all, just an equation relating pressure and velocity for incompressible, steady flows.
The reality is that Bernoulli's Principle is not what governs lift in any case, per se. It is just a mathematical tool that can be used to show the differential pressure on the top and bottom of the airfoil, which is the most simple way to explain lift. Of course, these differing pressures are related to differing velocities by Bernoulli.
The different velocities themselves are a much more complicated issue and arise from a combination of camber, angle of attack and a sharp trailing edge. The sharp trailing edge is quite important, as there is a mathematical and physical singularity at that point if certain conditions are not met. That condition, known as the Kutta condition, is that the trailing edge stagnation point (also a misnomer) is always at that sharp trailing edge, otherwise an infinite (or near infinite) velocity would be required.
So, with the rear velocity fixed in such a way, as you increase angle of attack up until the point of separation, the upper air moves faster to satisfy the governing equations while still maintaining that same trailing edge stagnation point. In this way, you can fly upside down with certain airfoils and, with a combination of aileron and angle of attack, counteract any of the negative lift you would be getting through the shape of the airfoil. Of course, as mentioned before, this comes with serious drag penalties and performance issues, which is why you only see it in air shows.
This pic is actually pretty much impossible to refute. Because we can see both craft, we know the inverted one is indeed in virtually level flight, and its thrust is also virtually level. No amount of overpowering from that engine could possibly keep that jet flying parallel with the lower jet.
The craft must be getting lift via its wings.
Mech_Engineer said:
