Gary King
is it possible for an atom to have no electrons?
chem_tr said:ZapperZ, I am doubtful about this. When you write the alpha particle, [itex]^{4}_{2}He[/itex], you'll see that two electrons are present as this compound is neutral and monoatomic. You'd be correct if this compound were a 2+ ion. Or is there something I don't know?
chem_tr said:\longrightarrow
chem_tr said:We understand that only small atoms can give all of their electrons; bigger atoms may be persuaded to give most of their electrons to yield unusual charges via core (nuclear) reactions, I think.
so, in my opinion, No, it is not possible for an atom to have no elections because first of all it wouldn't be uncharged (which although is not included in the definition above, needs to be true, other wise it is an ion), and second of all, it wouldn't share all the same characteristics of the element it should belong to, for example, the alpha particle above you all were talking about will not share the same properties as a helium atom will."A unit of matter, the smallest unit of an element, having all the characteristics of that element and consisting of a dense, central, positively charged nucleus surrounded by a system of electrons. The entire structure has an approximate diameter of 10-8 centimeter and characteristically remains undivided in chemical reactions except for limited removal, transfer, or exchange of certain electrons."
mrjeffy321 said:first of all it wouldn't be uncharged (which although is not included in the definition above, needs to be true, other wise it is an ion),
mrjeffy321 said:well the question was whether it was possible for an atom to have no electrons, not whether protons (and possible neutrons) could exist without electrons.
chem_tr said:However, there are not many; the other alternatives are so unstable that we can conclude these two are the only easily available. Please consider [itex]\displaystyle Li^{3+},Be^{4+},B^{5+}[/itex]. Very high amounts of energy have to be given to provide these unusual oxidation states.
altered-gravity said:Perhaps, those that you mentioned could be produced by laser ablation (firing laser directly to the solid or to a MALDI)in spectroscopy labs but i´m not sure.
altered-gravity said:Yes, we are talking about fully charged plasmas, theese species are available in high energy physics labs.
ZapperZ said:Laser ablation typically does NOT produce plasma ions. If they do, they would not be used as a technique for thin film depostion since the stoichiometry of the film may be different than the target. There are, of course, exception to this as done at the National Ignition Facility. Here, the plasma is form via extremely intense laser source.
Zz.
altered-gravity said:Really? Now I´m confused. I´ve always thougth that the ablation plume was plasma. It´s a mixture of ions, neutrals, electrons.. A college of mine worked in a Pb ionisation experiment with laser ablation mass spectrometer and we always talked about ablation plume as plasma-like. Laser source was a standard commercial pulsed Nd:YAG (freq. doubled). Of course they were not "fully charged" species, Pb2+, Pb3+, neutrals and others.
Am I wrong? If you can clarify this to me I will be grateful. Thanks
ZapperZ said:Thus you preserve the composition of the target material in the thin film that formed
Zz.
Gary King said:is it possible for an atom to have no electrons?
