Can an electron exist at many places at the same time?
Electrons do not exist at a single point but rather in a "cloud" of probabilities around the nucleus, meaning they can be found in multiple locations until measured. The concept of an electron being in many places at once is debated, with some arguing that it reflects uncertainty rather than actual multiple locations. The Gaussian surface concept is criticized as a classical interpretation that doesn't apply to quantum mechanics, where precise localization is required for measurement. According to the Born interpretation of the wavefunction, the electron's position is probabilistic, and once localized, it can only be found in one place at a time. Ultimately, the discussion highlights the complexities of quantum mechanics and the limitations of classical analogies in understanding electron behavior.
Godparicle
Michio Kaku said:
Because of uncertainty, the electron does not exist at any single
point, but exists in all possible points around the nucleus. This
electron “cloud” surrounding the nucleus represents the electron being
If I am not wrong, the Michio says that an electron (not the parts of an electron) can be found in many places at the same time. Is that right?
If that is the case, consider a gaussian surface enclosing the electron at many places at the same time, then the charge inside the surface will be integral multiple of e (i.e ne, where n>1). But, we know that charge on electron is just e.
This doesn't seem to allow electron to exist in many places at the same time. So, can an electron really exist in many places at the same time?
I think your yes / no question is a false dichotomy and you are unlikely to get many people to commit themselves either way. Fact is that the electron can sometimes be accurately located and sometimes it can't. You only know it's there if you detect it but you cannot say where it is without looking. You can chose or not whether that means it's in several places at once - before you find it. We are in the same neck of the woods as Schroedinger's cat here.
Your gaussian surface is a classical concept so I don't think you can validly come to the conclusion you have done.
Kaku is better at science than at explaining science. We spend a fair amount of time here unconfusing people who have been confused by his oversimplified explanations.
There are a bunch of threads over in the quantum mechanics forum about what that electron "cloud" does and does not mean. Roughly speaking, it does not mean that the electron is in many places at once, it means that the electron is nowhere until we precisely measure its position - and obviously you cannot draw a Gaussian surface around it until you have localized it to inside the volume enclosed by that surface. But once you have localized it to that volume, even though it still doesn't have a position more definite than "100% of the cloud is confined within the volume" we do know that there's exactly one electron's worth of charge inside that volume.
Are you familiar with the Born interpretation of the wavefunction? The wavefunction does not say that the electron is everywhere at once. It gives you the probability of finding the electron at anyone location in a quantum measurement. If you find it in one place, then you won't find it in any other place using the same measurement. (Future measurements, of course, have an new probability of finding the electron in various places.)
If you apply the Born interpretation to a Gaussian surface, you can calculate the probability of measuring the electron inside that surface, so the total enclosed charge is either 0 or 1 (units of -e).
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
