2025 Award
- 17,288
- 10,748
No, you are saying that.Stephen Tashi said:You are saying that "dimensions" are identified by the SI "units of measure" - i.e. that the "unit of measure" is more fundamental than the concept of "dimension".
I am saying that dimension is fundamental to physics, but that in the everyday human world, dimension is implicit, and is hidden behind the units. I say that knowing the dimension of a numerical result should identify the appropriate SI unit for that result.
A force of 9.8 Newton has implicit dimension identified by both the term “force” = M⋅L⋅T–2, and the unit “Newton” = kg⋅m⋅s–2. That duplication can be used as a check on data inputs, and then on the integrity of the numerical computation system. To maximise the application of that integrity check requires that dimensions such as length, angle or temperature be somehow attached like a tag to the numerical data as it flows through the computational system.
I refer to simple numerical addition. In a complex number, the operator i serves to keep two numbers apart and so precludes their immediate numerical addition, even though they have the same fundamental physical dimension. They remain independent members in a set, or a data structure.Stephen Tashi said:Why make the assumption that adding different dimensions is an error
Dimensional analysis is used as one check on the integrity of physical equations. It does not however detect all errors. My aim is NOT to reduce a dimension system to a divine physical fundamental minimum. It is to identify what dimensions are needed to maximise the possibility of integrity checks in computational systems.
Alexander Pope wrote in his Essay on Criticism, “To err is human, to forgive divine”. I argue here that; if the angle dimension did not need to exist in divine physics, humans would need to invent an angle dimension to detect human error.
