Can Angles be Assigned a Dimension? - Comments
105 replies · 14K views
Stephen Tashi said:
We don't "evaluate" 3x + 4y unless we are give numerical values for x and y. Likewise we don't evaluate 6xy unless we are given numerical values for x and y.
If x was the unit metres and y was the unit seconds, what would you do then?
Mathematics news on Phys.org
Are you trying to formulate an argument that says "We can't add unlike dimensions because we can't add unlike dimensions"?
As I said, I'm not advocating adding unlike dimensions. I'm investigating what justification we can give for declaring that adding 3 meters and 2 seconds to obtain a composite unit of 5 meters+seconds can never be done ( or should never be done) - no matter what interpretation we give to "meters+seconds".
Declaring "we can't add 3 meters to 2 seconds" or saying "adding 3 meters to 2 seconds doesn't make sense" isn't an explanation. If we want to demonstrate that there is no way to do something, then issuing the challenge "Somebody show me how to do it" isn't a demonstration. For example, "Show me some positive integers ##a,b,c## such such that ##a^3 + b^3 = c^3##" isn't a proof of Fermat's theorem.
Stephen Tashi said:
Dimensional analysis does not say that a physical unit can take a values corresponding to any given real number. So I see nothing wrong with your analogy.
I'd put it this way: Changing the units in a product and "knowing how to convert" the result (using conversion factors in the standard manner" introduces no new ambiguity in the description of the physical situation.
We "know how to convert" because we know to use conversion factors. But the conventions of using conversion factors doesn't explain why those conventions are physically useful. In my opinion, it is just an empirical fact that the ambiguity in knowing the product of dimensions, but not knowing the individual factors often doesn't detract from the usefulness our knowledge in making physical predictions.
That depends on what you mean by "equivalent". Perhaps you mean we have no obvious rules to convert it to a unique number of different units. For example, the conversion 4 apples+oranges to units of half_apples+oranges in a naive fashion is ambiguous because it might be done by converting 4 apples+oranges as (3 apples + 1 oranges) which is converted to (6 half_apples + 1 oranges) = 7 half_apples+oranges. Or it might be converted from (1 apples + 3 oranges) as ( 2 half_apples + 3 oranges) = 5 half_apples+oranges. So , if there is an empirical difference between the physical situation producing the measurement 7 half_apples+oranges and the situation producing the measurement 5 half_apples+oranges, this is a argument that converting units in such a manner introduces a harmful ambiguity.
Maybe something along these lines...
We have two systems characterised by vectors of attributes, S=(x1, x2, ..) , S'=(x1', x2', ...). We can invent measures of attributes, i.e. maps to reals, m1, m2,... We believe (and this is the physics) that the attributes have an additive property such that in some sense we can partition an attribute and recover the whole by summing its parts. This being so, we require our measures to be linear in this sense.
Given two measures, m1 and n1 for X1, if one is linear and there is a nonzero constant μ such that n1(x)=μm1(x) for all x, then clearly theother is linear. [Can we show that for two linear measures such a ratio exists?]
Anyway, if we want the product of measures of two attributes, we may choose m1(x1)m2(x2) or n1(x1)n2(x2). Armed with the knowledge of the measure ratios, μ, ν, we can compute the measure ratio μν for the measure products.
If we try to do the same summing two measures, there is no constant ratio that can convert one sum of linear measures to another.
This is much the same as I wrote before, but highlighting the dependence on an essential additivity in the underlying attributes, and the consequent requirement of linearity in the measures.
I think that's a fundamental idea in dimensional analysis - but it's a concept that's hard to state only using terms from arithmetic. The notion that the whole attribute "can be recovered" from the "sum" of its parts isn't quite the same notion as the concept that the whole numerical value of something is equal to the arithmetic sum of its "parts".
One attempt to express the physics is that "the presence of an attribute x_1" has the same effect as the simultaneous presence of the mutually exclusive "parts" of the attribute. (That uses "has the same effect" instead of the arithmetic relation "equal" and "simultaneous presence" instead of the arithmetic sense of "sum".)
Alternatively, we could state the concept by embedding it in the definition of the "parts" of an attribute. For example "x_a and x_b are each "half" of attribute x_1" shall mean the following are satisfied: 1) The simultaneous presence of x_a and x_b has the same effect (in whatever phenomenon we are studying) as the presence of x_1 alone - and 2) The presence of x_a alone has the same effect as the presence of x_b alone.
Taking that approach, we could argue that is is useful to make an "isomorphism" between the physical language and mathematical language. i.e. "same effect" maps to "equal". "simultaneous presence" maps to "sum", "half of" in the physical sense maps to "half of" in the arithmetic sense.
As I understand what you are doing with a measure ratio, you are assuming the attribute x_1 is a numerical value at the outset.
I agree that the use of ratios (i.e. conversion factors) for individual attributes doesn't define how to convert a sum of different dimensions measured in one set of units to a unique sum of the same dimensions measured in a different set of units. When people ask why we "can't" add different dimensions together, I think this inability is a good explanation of why we "don't" add different dimensions.
However, the statement that "it is impossible to add different dimensions" is claim that goes beyond what is convenient or inconvenient. Are we saying that no matter what scheme you make up for adding different dimensions, it won't work? What would it mean for a scheme (which may not be based on conversion factors) to work or not to work?
The general situation as I see it:
The product of xy of units x, y with unlike dimensions omits the information about the individual magnitudes of x and y. There are many physical situations where knowing the product xy is useful even though we don't know the individual values of x and y. (e.g. When a result of interest can be expressed as a function of one variable p = xy instead of function of two variables (x,y).) There are also physical situations where the knowledge of xy is not as useful as knowing the individual values of x and y. For example, if x is the diameter of your coffee cup in cm and y is the length of your cat's tail in cm then the product xy doesn't summarize the situation as well as knowing the individual values of x and y.
By contrast, empirically, there are few situations in physics where knowing the sum x + y of units of different dimensions is useful.
Can we go even further to say "Any physical situation where the result is expressed as a function of the sum of units of different dimensions can be rewritten as a different function of the same variables that does not involve the sum of units of different dimensions"?
Stephen Tashi said:
In general, changing units changes equations by multiplying one or both sides of the equation by constant factors.
So the prohibition against adding unlike units can't be explained by the invariance of equations. We have to explain why a particular type of variation is the only permissible kind.
Yes, I agree. Admissible invariances seems to be those which involves solely a scale factor.
Can you please give examples of those few situations in physics.
@Stephen Tashi , @Baluncore :
I am pleased to have engendered such an interesting debate, but it does seem to have wandered a long way from my original article. How would you feel about having it moved to a different thread?
Meanwhile, you might be interested in http://nvlpubs.nist.gov/nistpubs/jres/65B/jresv65Bn4p227_A1b.pdf. Seems like much of my endeavour is a rediscovery of Page's work. See p 231 and Appendices 2 and 3. He did miss the trick of giving i angular dimension, and did not discuss Planck's constants. The rest of his article might be relevant to your own discussion.
If this thread is getting too long to be readable for new contributors then the discussion should be restarted in another thread. What would the topic of the new thread be?
It interests me to discuss the general foundations of dimensional analysis. I'm not particularly interested in debating the narrower issue of whether angles should be assigned a dimension until the big picture is clear. However, perhaps others would be interested in a new thread restricted to the topic of angles.
The discussion about whether angles should or shouldn't be assigned a dimension just meanders around because the reasons underlie dimensional analysis haven't been established. Some people just repeat the mantra "Angles are dimensionless" because it is a convention of standard dimensional analysis. More liberal participants say that angles can be assigned a dimension because such-and-such an aspect works out to be pleasing and others counter by saying that a different aspect of the situation isn't pleasing. Until the significance of the various aspects is clear, the importance of satisfying them is just a matter of individual tastes.
Discussions about whether angles may be assigned dimensions can become to similar to discussions about other "notorious" topics such as "Is 0.9999... = 1" or "Are dy and dx numbers?", "Can we divide by infinity?". Such discussions tempt us to ignore the arbitrary nature of definitions. We tend to assume that words and notations like "angles", "0.9999...", "dx", "infinity" are particular things that exist independently of anyone's definition of them. Then we use our intuitive concept of these pre-existing things in debating what their properties "are" instead of what we may define those properties to be.
Sorry about being off topic, I plead a little bit guilty. Go ahead and split or fork the thread.
We need more discussion about those interesting bundles of {numbers, units and dimensions}.
I think this is an important topic. What is more basic to physics than how we measure things?
In SI units the angle is not a base quantity. We state the angle in radians, which is a ratio of two lengths, namely the length of the subtended arc to the length of the radius, giving a dimensional ratio of L/L = 1. So we say the angle is dimensionless.
Some people have argued for making the angle a base quantity. See for example https://arxiv.org/ftp/arxiv/papers/1604/1604.02373.pdf.
It may be more convenient to keep angles dimensionless. Consider two similar triangles. Perhaps they are both 30-60-90 triangles but the hypotenuse of triangle #1 is twice the length of that of triangle #2. The corresponding angles are equal, but the corresponding sides are not. I suppose it's fair to ask why this is more convenient.
I think this question is related, at least subjectively, to time. The ancients came up with 360 degrees because it corresponds to a 360-day year in some ancient calendar. You can associate a point moving around on the circumference of a circle with the passage of time. We don't care how long that circumference is. We just want to know how many units of time have passed. We can associate units of time with degrees around a circle.
For example, consider our standard analog clock. It may be a wristwatch or Big Ben. In either case, we know that when the little hand is at a certain angle from straight up, it means 20 minutes past the hour.
In physics, in general, the study of periodic motion is an enormously important topic. Therefore, we want our system to be convenient for the mathematics of periodic motion.
I plan to read the above paper and think about this some more. It would also be a good time to review Bridgman's Dimensional Analysis.
haruspex said:
It's your topic. Maybe "why does dimensional analysis work?"
My question is "What do we mean when we say an particular convention of dimensional analysis 'works'?". For example, what criteria are we using to say that assigning angles a dimension "works" or "doesn't work" ?
My criterion is quite simple: can a dimension be assigned in a way which is consistent and has the power to detect blunders? I believe I have shown that the answer is yes.
But from your posts in the thread, I thought you were focused on the more fundamental question of why DA works at all. E.g., your observation regarding products versus sums.
Interesting concept. One thing I noticed was: in cases where you multiply (or divide) by 2pi, the article suggests that pi has the dimension of Angle. Since there are 2pi radians in a full circle (or full cycle of oscillation), then shouldn't it be 2pi containing the dimension, rather than just pi?
I do like the fact that this way puts a direction in as a dimension, when quantities are vectors.
Interesting concept. I'm not sure if I am ready to adopt it, but it gives some things to think about. You have certainly put a lot of thought into how to handle various situations. In your section 3.6 discussing Planck's Constant. You show hbar to have dimension of ML2T^−1Θ, but I think you should have ML2T^−1Θ^-1, to reflect π in the denominator, and to cancel out the ω.
Θ2=1, so Θ and Θ-1 are the same.
