Can Circular Motion Be Calculated Like Linear Motion?
  • Context: High School
  • Thread starter Thread starter clm222
    Velocity
3 replies · 2K views
clm222
Hi, quick question
I've just started to learn circular motion and i tried a basic force problem.
Imagine there is a ball on a string with a string length 'r', and a ball mass 'm'.
You apply a force 'F' for one second. Can the arc length of the ball's motion be calculated the same as linear motion? [itex]d=\frac{F{t^2}}{2m}[/itex] (replacing acceleration with F/m, vi=0)
Can I also go as far as the find the angular velocity by dividing by the radius?
[tex]ω=\frac{F{t^2}}{2mr}[/tex]
Thanks.
Where, and in which direction, do you apply the force?
If the force is always in direction of the circular motion (as forced by the string), that works. However, angular velocity after the acceleration is not the total distance divided by the radius. That is the angle, not its velocity.
oh ok,
so if i were to have the force constantly be applied perpendicular to the ball than i CAN use the distance formula?
if so, let's say the ball has initial velocity 'vi', and a force is applied, the final velocity can be calculated using [itex]{v_f}={v_i}+\frac{Ft}{m}[/itex], could i also calculate the distance travled: [itex]d={v_i}t+\frac{F{t^2}}{2m}[/itex] ?
