The discussion revolves around the safety and feasibility of using compressed air to pressurize gasoline in a sealed container for a starting system in a racing context. Participants explore concerns related to auto-ignition, pressure levels, material compatibility, and potential hazards associated with the design.
- Exploratory
- Technical explanation
- Debate/contested
- Experimental/applied
- CharlieP expresses concern about the potential for auto-ignition of gasoline when pressurized to 120 psi, noting the auto-ignition temperature of gasoline is around 500°F.
- Some participants suggest that 120 psi is excessively high for gasoline, with one mentioning that 5 psi is considered high for natural gas.
- Another participant shares their experience with compressors, indicating that normal compression to 120 psi typically does not generate temperatures that would reach auto-ignition levels.
- Concerns are raised about the compatibility of gasoline with rubber seals, although CharlieP states that Viton seals are being used, which are compatible with gasoline.
- There is a suggestion to limit the air fill fitting to slow the pressurization process, which could help manage temperature increases.
- CharlieP clarifies that the system is not a toy but is intended for a racing application, where gasoline is used to assist starting engines that primarily run on methanol.
- One participant emphasizes the importance of conducting a hazard analysis and considering potential ignition sources, suggesting the use of nitrogen instead of air to avoid mixing an oxidizer with fuel.
- CharlieP describes the construction of the system, including the materials used and the method of delivering gasoline to the engine.
- There are discussions about the potential use of CO2 for pressurization, with mixed opinions on its suitability and effects on gasoline.
- Another participant warns against relying solely on advice from online sources without fully understanding the design and safety principles involved.
Participants express a range of views on the safety and practicality of the proposed system, with no consensus reached on the appropriateness of the pressure levels or the best practices for implementation. Concerns about safety and material compatibility remain contested.
Participants highlight various assumptions regarding pressure safety, material compatibility, and the potential for ignition, but these aspects are not fully resolved. The discussion includes references to specific pressures and temperatures, as well as the implications of using different gases for pressurization.
This discussion may be of interest to individuals involved in racing, engineering design, or those exploring the safety of pressurized systems involving flammable liquids.
