Can hot objects become charged?
Hot objects, such as heated metals, can potentially become charged due to the ejection of electrons from their surfaces, a process known as thermionic emission. When heated sufficiently, the kinetic energy of atoms can lead to electron release, although grounding may prevent a net charge. This principle is similar to how vacuum tubes operate, where heated cathodes emit electrons to create flow. The discussion highlights the relationship between temperature and electron behavior, particularly in devices like cathode ray tubes. Overall, while heat can influence charge, the net effect depends on the object's grounding and conditions.
lonely_nucleus
Because a hot object like a hot metal has a lot of heat flowing through them are they charged? What are some ways to charge objects.
Shuffle your feet on carpeting on a dry day
Likes lonely_nucleus
I can't say whether the object would be charged however with a lot of heat then electrons could be ejected from the surface but I think if it were grounded then it still wouldn't have a net charge.
Vacuum tubes work on the same kind of principle of heating a cathode to get electron flow from cathode to anode:
http://en.wikipedia.org/wiki/Vacuum_tube
basically the process of thermionic emission:
http://en.wikipedia.org/wiki/Thermionic_emission
I was wondering this because I know that when cathode ray tubes are heated they eject electrons. I was postulating that if the internal KE of an object gets hot enough the atoms can collide with so much energy that the object would emit electrons, it looks like you were thinking the same thing as well. I am going to cover thermiomic emission as the last chapter in my AARL electronics book but thank you for telling me what it is. Friend thank you for the reply.
Another great reply from you. I am honored to have you respond to my thread :nb)
Likes Greg Bernhardt
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
