Jiggy-Ninja
- Messages
- 309
- Reaction score
- 1
I'm messing around with an 8051 microcontroller (DS89C450 if it makes a difference) and I'm trying to get a handle on how interrupts work, and what they can and can't do.
I'm working with Assembly right now, not C.
The program I made has a few songs in it's memory (very simple ones like "We Three Kings" and "Star-Spangled Banner"), and will start playing one at start up. Which one it plays depends on how a couple switches are set.
What I want to do is hook a pair of push buttons to the interrupt pins on P3; INT0 will reset and repeat the current song from the beginning regardless of the switch settings, and INT1 will reset and reload a new song.
Details aside, the essence of what I want to do is to make the interrupts cause a permanent branch to a specific location, at which point the interrupt ends and the program keeps running from that point. I don't want it to pick up where it left off after the interrupt is done.
So far, the only way I can think of doing this is something rather kludgy, like this:
* Song is a label in the code.
Needs to be modified a bit to protect the original value of DPTR, but you should get the basic concept.
For the record, I understand that polling the buttons might be a better solution,and would be trivially easy to do in my program. I already have a main loop that polls the timers (Though I might change one of them to an interrupt), so adding two more polls isn't much of a hassle. I'm not trying to do this for the most efficient or workable program, I'm trying to do this in order to understand interrupts better.
Code:
mov DPTR, #Song
pop R1
pop R1 ; Popping the original return address from stack
push DPH ; Push the new address onto the stack
push DPL ; or whatever order these two need to be in
reti
