Can Kinetic Energy in Electromagnetic Waves Explain Their Speed in a Vacuum?
Kinetic energy in electromagnetic radiation, such as light, travels at the speed of light in a vacuum because it does not require a medium for propagation, unlike sound waves which need a medium to travel. Photons, the particles of light, do not possess mass but carry energy and momentum, which can be demonstrated through phenomena like the photoelectric effect. The discussion highlights that while sound waves require a medium, light's ability to travel through a vacuum is a fundamental characteristic. Additionally, when a laser is directed at a suspended metal surface, it can cause the surface to rotate due to radiation pressure, which is influenced by the light's absorption and reflection. The conversation also touches on the need for accurate formulas to describe solar radiation pressure.
David Burke
Does anyone have an explanation for why kinetic energy carried by electromagnetic radiation travels at the speed of light?
My understanding of the speed of sound is that the denser the medium, the faster the wave velocity. Since this is just kinetic energy propagating through a medium, how is it different when applied to electromagnetic radiation? If it is no different, does that mean that a vacuum has infinite density?
you seem to have confusion between sound waves and light waves. when you say electromagnetic radiation, you are talking about light wave. light can travel in vacuum. sound cannot travel in vacuum, it needs medium to propagate.
True, sound waves (kinetic energy dispersing through a medium) requires something to travel through. So how can photons transfer kinetic energy (and at such velocity) without a medium. Correct me if I am wrong (very possible) but photons carry kinetic energy as shown by the photo electric effect and the fact that they have mass when not in a rest state. Also, if a laser is directerd onto a suspended metal surface the surface will rotate?
That's just one of the wild things about light, it requires no medium to travel through.
Photons do not have mass, but they do have an energy and momentum (they simply are not given by KE = {{1}\over{2}}mv^2 and p = mv).
You might have been confused. Sound propagate in vacuum but light can(300,000m/s)
Yes, it will. There's something called radiation pressure.
This pressure of light will be doubled for all angles of incidence if the light is both absorbed and reflected.
However, I think the formula of solar radiation pressure on that page is wrong.It should be F= -p(c+1)Ar
where p is the force per unit area,
c is the coefficient of reflectivity
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
