Can ml be converted to grams in Heat Capacity and Specific Heat problems?
This discussion addresses the conversion of milliliters (ml) to grams in heat capacity and specific heat problems, specifically in the context of a stainless steel piece immersed in water. The density of water is established as 1 g/ml, allowing for straightforward conversion from volume to mass. The specific heat of stainless steel is noted as 0.50 J g-1 °C-1. Participants emphasize the importance of accounting for heat loss in non-calorimeter setups, impacting the accuracy of mass determination.
  • Understanding of specific heat capacity and heat transfer principles
  • Familiarity with the formula q = m x SH x ΔT
  • Knowledge of water density (1 g/ml) for volume-to-mass conversion
  • Basic algebra for solving equations involving heat transfer
  • Study the concept of calorimetry and its applications in thermal physics
  • Learn about the calculation of heat transfer in different materials
  • Explore the effects of heat loss in experimental setups
  • Investigate the specific heat capacities of various materials beyond water and stainless steel
Students in physics or chemistry courses, educators teaching thermodynamics, and anyone involved in experimental heat transfer analysis will benefit from this discussion.
Knight226
Is it possible to convert ml to grams for a Heat Capacity and Specific Heat type of problem? The problems that I have done so far did not use ml at all. I am stuck with the following problem:
A piece of stainless steel (specific heat = 0.50 J g-1 oC-1 ) is taken from an over at 178 oC and immersed in 225 ml of water at 25.9 oC. The water temperature rises to 42.4 oC. What is the mass of the piece of steel? How precise is this method of mass determination? Explain.
q = m x SH x Delta T
Step 1: Calculate q of water.
qwater = m * SH * Delta T
qwater = m * 4.18 * (42.4 - 25.9)
Problem: the m is not stated in the give. Water is given in ml. I tried to search and some people say 1 ml = 1 g. I don't know if that is correct. So I hesitated in continuing this problem until I find out the correct way in converting ml to g.
If I can get pass that step, then I will do qsteel.
My answer for the 2nd question is that it is not accurate since it is not a calorimeter and thus there will be heat loss?
Please help. Thank you very much in advance.
To convert a volume of water to the mass of water, you need to know the density of water. You can look it up in a book for verification, but the density of water is basically 1 g/mL.
Thank you! :D
Hello guys, am a new member here, and i'd love to share with you..
i've faced the same problem before, and I've tried to find any related formula, but
the only one i got is the one that is mentioned by Ygggdrasil..it's mentoined here in
Tippens Physics book that the mass of 100-mL of water is 100 gram, so am using
this to make a cross multiplication between two fractions whenever I've to convert
any other volume of water (i don't know if the expression is correct because my
english is not that good)...
Would you please guys tell me how can i post a questio...see if you can help me
with this:
a 30.14-g stainless steel ball bearing at 117.82 c is placed in a constant-pressure calorimeter containing 120.0 mL of water at 18.44 C.if the specific heat of the ball bearing is 0.474 J/g.c, calculate the final temperature of the water.assume the
calorimeter to have negligible heat capacity.
