Can Pure Water Fluoresce Under UV Light?
The discussion centers on whether pure water can fluoresce when illuminated by specific frequencies of ultraviolet (UV) light, exploring the conditions under which this might occur and the nature of the emitted radiation.
  • Exploratory, Debate/contested, Conceptual clarification
  • One participant inquires if pure water can fluoresce under UV light without any chemicals added.
  • Another participant suggests that while UV light may not be effective, microwaves can excite water molecules, leading to the emission of infrared radiation.
  • Some participants propose that UV light with a wavelength around 10 nm could lead to absorption and subsequent emission of blackbody radiation, though they express uncertainty about whether this constitutes fluorescence.
  • A question is raised about whether Cherenkov radiation should be considered a form of fluorescence.
  • There is a clarification regarding the classification of 10 nm light as Extreme Ultraviolet (EUV), with some participants expressing surprise at the dual classification of this wavelength range as both UV and X-rays.
Participants express differing views on the ability of pure water to fluoresce under UV light, with some supporting the possibility under specific conditions while others challenge the definitions and implications of fluorescence versus other forms of radiation.
There are unresolved questions regarding the definitions of fluorescence and blackbody radiation, as well as the specific conditions under which water may emit radiation when exposed to UV light.
B0b-A
Can pure* water be made to fluoresce if illuminated by some particular frequency of Ultra-Violet light ?
[* No chemicals added ]
Sort of.
Not UV, but microwaves efficiently excite water molecules which then emit higher frequency electromagnetism (infra red)
I think it can. If incident UV light has wavelength about 10 nm. The majority of the materials absorbs this wavelength and translate it to heat, then they emit blackbody radiation. But I think blackbody radiation can't be fluorescent radiation .
Do you count Cherenkov radiation as fluorescing?
And is 10nm in the UV range ? This question was specifically about incident UV radiation
Yes it is. EM wave with wavelength about 10 nm is called Extreme Ultra Violet.
Interesting. I've always thought of that stuff down there as X-rays. They ARE, but you are right that they are also called EUV (I was sure they were not UV). Weird that they have both defintions, but anyway, thanks for pointing that out to me.
  • · Replies 25 ·
  • · Replies 22 ·
