Can rotation wt, lift leverage wt
  • Context: Undergrad
  • Thread starter Thread starter Newtons-law
    Lift Rotation
The discussion revolves around the mechanics of using rotational weight and leverage to lift other weights, specifically examining scenarios involving a wheel with weights and a teeter-totter setup, as well as the behavior of a ball rolling down a sloped tube. The scope includes theoretical mechanics and practical applications of levers and rotational dynamics.
  • One participant questions whether a bar attached to a rotating wheel can exert enough force to lift a 15 lb weight on a teeter-totter when a 50 lb weight is applied on the other side.
  • Another participant suggests that if the moment created by the bar exceeds that of the 15 lb weight, lifting is possible, likening the setup to a cam shaft.
  • A different participant expresses uncertainty about the scenario and requests clarification, but agrees that a lever could potentially lift the 15 lb weight with the 50 lb weight.
  • A new scenario is introduced involving a 10 lb ball rolling down a 45-degree sloped tube and whether it will slide forward when impacted by a weight pressing down on the tube.
  • One participant confirms the slope of the tube is 45 degrees, but does not provide further analysis on the ball's behavior.
Participants generally agree that leverage can be used to lift weights, but there is uncertainty about the specific mechanics involved in both the teeter-totter and the sloped tube scenarios. The discussion remains unresolved regarding the exact outcomes of these setups.
Some assumptions about the mechanics of the lever and the effects of rotational dynamics are not fully explored. The impact of the 40 lbs of pressure on the ball's motion in the tube is also not clearly defined, leaving open questions about the conditions necessary for sliding.
Individuals interested in mechanical physics, lever mechanics, and rotational dynamics may find this discussion relevant.
Newtons-law
Question: On one side of a wheel there is 50 lbs of weight, if the wheel is released the weights would rotate with the wheel until the weights where at the bottom and stop. Let's say this wheel has a shaft in the middle of the wheel that turns as the wheel does, if you put weights on one side of the wheel, when the wheel is released the the wheel and shaft turns until the weights stop at the bottom. Ok on the shaft there is bar welded to it, a long enough bar to use for leverage as the wheel turns {like a fan blade attached to its shaft}. Now let's say we have a balance scale or a teeter totter with 15 lbs at one end. If 50 lbs of weight in rotation on a wheel is pushing down with the attached bar, could the bar push down on the other end of the teeter totter that has no weight and lift the 15 lbs of weight on the other end of the teeter totter?
Certainly if the bar provides a moment sufficient to exceed the moment applied by the 15 lb weight. Basically shaft through the wheel and the bar behave likd a cam shaft.
I'm not completely sure I understand your scenario (a picture would help), but yes, you can use a lever to lift a 15 lb weight with a 50 lb weight.
Ok let's say we have a ball weight or round weight of 10 pounds and roll it down a tube or half tube that is 5 ft long and at a 45% slope and at the end of the tube there is a stopping point. The end of the tube or the place where the ball stops is attached only by bearings that slide forward and after 2 inch's a metal lip will stop the forward motion of the small portion of the tube that slides. If there is 40 lbs of pressure an inch wide on top of the tube and the 10 lbs ball hits the end of the tube that can slide forward, {will it slide}.
45 degree slope
  • · Replies 22 ·
  • · Replies 26 ·
  • · Replies 25 ·
  • · Replies 116 ·
13K
  • · Replies 69 ·
18K
