Can Solenoids Enhance Railgun Performance?
  • Context: Undergrad
  • Thread starter Thread starter Waterfox
    Railgun Solenoid
4 replies · 6K views
Waterfox
I haven't seen any discussion or any mention what so ever of this before so excuse me if it's that's because it's a crazy idea.
What would be the pros and cons of using solenoids as the rails and projectile of a railgun?
Would the stronger magnetic field of the solenoids allow a stronger force to be applied to projectile or is it a simple case of you get the same amount put out than you do put in regardless of being a rail or coil.
I just tried building simple one connected to a battery and it worked, both with a solenoid projectile and ball bearing. (I took vids if you'd like me to post them)
Discussion?
Was your projectile inside the solenoid.
No, the rails were replaced with solenoids.
Here are the videos to help you understand:
https://www.youtube.com/watch?v=fRZd9-OlZ68
https://www.youtube.com/watch?v=9GYGwN9zHD0
Here is a copy of the description for the first video:
Trying out the idea of using solenoids instead of rails. The side rails and the projectile are both solenoids. I used enameled wire wrapped around some bolts then sanded the outsides to ensure a connection. The battery is a 2S LiPo, I made sure to constantly check it's temperature and it barely got warm.
Some info:
The projectile was attracted to the "rails", this helped to keep the connection.
Adding to this, rails (solenoids) and the projectile (also a solenoid) were all attracted to each other rather than being repelled (I believe this is how a traditional railgun behaves).
Im trying to figure out how this works Because the B field outside the solenoid is zero.
There is a pretty small fringing field. Is this DC current, it looks like it from the video.
It's connected to a 7.4v Lithium Polymer battery so it's DC.
Here's how I imagined the magnetic poles, green is the rails, blue is the projectile.
[PLAIN]http://img690.imageshack.us/img690/5193/railgunq.jpg
