Can someone explain how to find stuff with 2 Voltmeters?
  • Thread starter Thread starter doublea500
    Explain
7 replies · 2K views
doublea500
Need help finding Current on one resistor when there are 2 batteries
Find Current in the 3 ohm resistor
Sorry it didnt come out right. ill explain what it is. 12V meter on the left, + on top - on bottom. then if you go counter-clockwise you will hit a 6ohm resistor, keep going and you will hit a 1 ohm resistor. on the right there's a 6v +top - bottom. in the middle between the 6ohm and 1 ohm there's a 3 ohm separating it coming out.
Imma take a picture
V=IR... and others
I Tried using kirchhoffs law and i kinda got lost. i was trying to do the 2 boxes separately like 3I+6I=12V so I1=12/9 (1.3333) and 3I+1I=6V so 41=6v so I2=6/4. (1.5). i got stuck there because i didnt know what to do next
The answer for this is 1.8
can someone answer how to do this and tell me the basic rules when there are 2 voltmeters? because the 2 voltmeters really confuses me.
Those aren't voltmeters, but rather batteries--sources of electric potential.
You need to use Kirchoff's loop and junction rules, [tex]\textstyle \sum \Delta V = 0[/tex] and [tex]\textstyle \sum i = 0[/tex] (at a junction).
You know the potentials of the batteries and the resistances of the resistors. How can you use Ohm's law and Kirchoff's laws to create a set of equations in terms of voltage? Note that the current changes at the junctions.
eh, not sure but is it 3I1+6I2=12V and 3I1+I3=6v?
Thats for [tex]\textstyle \sum \Delta V = 0[/tex] how can i get the [tex]\textstyle \sum i = 0[/tex] part though? and I am not sure what you mean by the the sum of I is 0 at a junction
Look at the "T" shaped part of wire above the 3 Ohm resistor. If current i is flowing in, and two different currents (say, i1 and i2) flow out, if the sum has to be zero, what does this say about the relationship between the three currents?
(This requirement derives from conservation of charge.)
so 3I1=6I2+1I3?
i keep using the loop rule but i am getting nowhere
Also, should i be using the same I or different Is like I've been doing?
ok, how bout I1=I2+I3 whereas I1 is amp for 3 ohm resistor, I2 is amp for 6 ohm resistor, i3 is amp for 1 ohm resistorSo here's the formulas i have so far.
12=3I1+6I2
6=3I1+I3
I1=I2+I3
Ahh i got it... here's what i did, tell me if there's a simpler way. i combined these formulas. and used subsitution first to get rid of I3, made I2=2-.5I1 in the first equation then subsitute that into the second equation then i got the I1 value on one side and everything else on the side. (4.5I1=8V) then solved for I1 and got 1.7777777 which i guess got rounded to 1.8. thanks for the help. is there a simpler way of doing this though?
You usually have to solve the system. In some cases, you can use equivalent resistance to simplify the circuit.
