Struggling with Physics Homework: Who Can Explain Force and Motion Problems?
  • Thread starter Thread starter tinab16
This discussion focuses on solving force and motion problems in physics, specifically involving static and kinetic friction, acceleration, and forces acting on objects. Key problems include calculating the acceleration of a book and block against a wall, determining the force needed to move a crate, and analyzing forces on objects on frictionless inclines. Participants emphasize the importance of understanding Newton's laws and suggest drawing diagrams to visualize problems. The equation for kinetic friction, f_k = μ_kF_N, is highlighted as a useful tool for solving these types of problems.
  • Understanding of Newton's laws of motion
  • Knowledge of static and kinetic friction coefficients
  • Ability to apply basic physics equations related to force and acceleration
  • Familiarity with free-body diagrams for visualizing forces
  • Study the application of Newton's second law (F = ma) in various scenarios
  • Learn how to calculate static and kinetic friction forces using the formula f_k = μ_kF_N
  • Explore the concept of free-body diagrams and their role in solving physics problems
  • Investigate the effects of angles on forces in inclined planes and frictionless surfaces
Students studying physics, educators teaching force and motion concepts, and anyone seeking to improve their problem-solving skills in mechanics.
tinab16
I don't know how to solve this force and motion problems so I'm asking you for help...if someone knows how to solve them,I would like some solutions.
thanks!
1.a horizontal force of 12N pushes a 0.50 kg book against a vertical wall.the book is initially at rest.if coefficient of static friction is 0.6 and of kinetic friction is 0.8 what is the acceleration of the book?
2.a horizontal force of 5N pushes a 0.50kg block against a vertical wall.the block is initially at rest.if coefficient of static friction is 0.6 and of kinetic friction is 0.8 what is the acceleration of the block?
3.a 12kg crate rests on a horizontal surface and a boy pulls on it with a force that is 30° below the horizontal.if the coefficient of static friction is 0.40,the minimum magnitude force he needs to start the crate moving is?
4.a crate resting on arough horizontal floor is to be moved horizontally.the coefficient of static friction is 0.40.to start the crate moving with the weakest possible applied force,in what direction should the force be applied?
5.a 40N crate rests on a rough horizontal floor.a 12N horizontal force is the applied to it.if the coefficient of static friction is 0.5 and of kinetic is 0.4,the magnitude of the frictional force on the crate is?
6.a block slides down a frictionless plane that makes an angle of 30° with the horizontal.the acceleration of the block is?
7.a 25N crate slides down a frictionless incline that is 25° above the horizontal.the magnitude of the normal force of the incline on the crate is?
8.a 25N crate is held at rest on a frictionless incline by a force that is parallel to the incline.if the incline is 25° above the horizontal what is the magnitude of the applied force?
9.a 25N crate is held at rest on a frictionless incline by a force that is parallel to the incline.if the incline is 25° above the horizontal what is the magnitude of the normal force of the incline on the crate?
10.a 32N force,parallel to the incline is required to push a certain crate at constant velocity up a frictionless incline that is 30° above the horizontal.what is the mass of the crate?
Nobody is going to do your homework for you. They will assist you, but only once you have shown that you have made an effort.
you don't have to solve the problems then but can you just give me the formulae?
and I will see what I can do.
thanks a lot.
Hello tinab16 and welcome to PF!
In future, I suggest you break this down and start with one question at a time when asking for help :smile:
Having said that, something that may help you would be to draw a diagram of the problem.
An equation you may find useful is
f_k=\mu_kF_N
Hope that helps. :wink:
lol the idea is to HELP you get the solution, not GIVE you the solution. Let's start with Newton's laws. The first question mentions force, mass, acceleration, friction... does that ring any bells!?
f_k=\mu_kF_N
OK.I'll see what I can do with it.
tnx.
