Can the Properties of the Lever be Deduced without Experimenting?
  • Context: Undergrad
  • Thread starter Thread starter pmclough
    Lever Properties
The forum discussion centers on the question of whether the properties of the lever can be deduced without experimental observation. Participants reference Archimedes' axiom regarding equilibrium and Lagrange's principles from "Mécanique analytique" as foundational texts. The discussion highlights the necessity of axioms based on experiential knowledge, particularly regarding gravity and conservation of energy, which complicates purely geometric deductions of the law of the lever. Ultimately, the consensus suggests that while mathematical deductions are possible, they rely on principles that are inherently linked to experimental observations.
  • Understanding of Archimedes' principles of equilibrium
  • Familiarity with Lagrange's "Mécanique analytique" and its axioms
  • Knowledge of conservation of energy and its implications in physics
  • Basic concepts of virtual work in statics
  • Research Archimedes' axioms and their applications in mechanics
  • Study Lagrange's principles of virtual work and their relevance to statics
  • Explore the relationship between gravity and the law of the lever
  • Investigate the implications of conservation of energy in mechanical systems
This discussion is beneficial for physicists, educators in mechanics, and students seeking to deepen their understanding of classical mechanics and the foundational principles governing levers and equilibrium.
pmclough
I have written a short paper that addresses the question posed in the title.
You can find a copy of the paper here: http://www.math.csusb.edu/faculty/pmclough/LP.pdf.
I think the paper may have some pedagogical value. If you have any comments or suggestions regarding the paper or any different ideas about answering the question posed in the title please feel free to share.
There is on old proof by Archimedes that uses only geometry and the principle that equal masses at equal lengths from the fulcrum are in equilibrium.
Lagrange in his Mécanique analytique, in the first section on Statics, discusses this and a few other elementary principles that can be used to deduce the law of the lever.
Thanks for the reply and the references to Archimedes and Lagrange.
I am aware of the proof by Archimedes that you mentioned. However, your description of it is not completely accurate. In particular, Archimedes uses the following statement as an axiom (this is T.L. Heath translation of the axiom): ''equal weights at equal distances are in equilibrium, and equal weights at unequal distances are not in equilibrium but incline towards the weight which is at the greater distance''. The last part of this axiom presupposes properties of the lever that were observed from experimenting with the lever. Therefore, Archimedes' work does not answer the question that was posed in the title of this thread.
I am not aware of what axioms Lagrange takes when he deduces the law of the lever. I would appreciate it if you or someone else could give me a precise list of these axioms.
I am aware of the proof by Archimedes that you mentioned. However, your description of it is not completely accurate. In particular, Archimedes uses the following statement as an axiom (this is T.L. Heath translation of the axiom): ''equal weights at equal distances are in equilibrium, and equal weights at unequal distances are not in equilibrium but incline towards the weight which is at the greater distance''. The last part of this axiom presupposes properties of the lever that were observed from experimenting with the lever. Therefore, Archimedes work does not answer the question that was posed in the title of this thread.
If I remember correctly, the last part is not used to prove the law of the lever. What he does is (in modern terms) distribute the masses symmetrically about their attachment points so that the density of the distributed masses is equal; then, if the distances are inversely proportional to the masses, the central portion of the lever is covered symmetrically with the distributed masses, so that for each bit on a side of the fulcrum there is an equal bit on the other side, which implies equilibrium.
But more generally, I do not think I understand your intent. Something has to come from experience. Even pure geometry has some axioms that are based solely on our experience. Your use of conservation of energy is no different: it is either hoisted directly from experience as a fundamental principle, or is arrived at indirectly, from another experimental principle such as Newton's second law.
He builds his statics upon the principle of the virtual work, but before that he conducts a review of principles of statics, and that has an interesting commentary to the law of the lever.
I respectfully disagree. I do not think the law of the lever can be proven using only geometry and the first part of the axiom. If you think you can do this I would love to see your proof.
Let me clarify my intent. I think my question may be a little ambiguous the way it is currently worded. Here is what I mean: "Can the Properties of the Lever be Deduced without Experimenting with the Lever?". I agree that any axioms that we choose to use to prove the law of the lever will be based on things that were observed in the physical world. However, the question is asking if it is possible to choose a set of axioms that are not based on any observations that were made while experimenting with a lever. I hope this better clarifies things.
A.T. said:
Assuming conservation of energy makes it rather trivial. Try to explain it for a static case without invoking virtual work or energy. We had some threads on this here.
I would say being able to make a concept trivial, from a pedagogical point of view at the very least, is a good thing.
I believe that the explanation that you quoted proves that.
Hmm. Instead of a stated (and, hopefully, small) set of admissible experimental knowledge, we are given a rather vague set of inadmissible knowledge.
voko said:
I believe that the explanation that you quoted proves that..
If you are referring to my paper then you are mistaken. In the paper I take gravity and the conservation of energy as my axioms and then prove the law of the lever.
There still seems to be some confusion about what I am asking. To avoid any miscommunications between us let my try to state the question again in an isomorphic way: "Without ever experimenting with a lever is it possible to deduce the law of the lever?".
I was referring to my comment in #4.
Mathematically, yes. You can postulate just about any powerful principle, such as the conservation of energy, and ignore the fact that physically we have obtained this principle via a very long chain of development, where fitting the theory with the experiment - with the lever in particular - has played a role.
For the static case you could use angular momentum. The rod with the two masses is connected by a hinge to something and angular momentum with respect to the hinge is calculated. If the rod would start moving, the angular momentum would change. But the rate of change of the angular momentum is the torque and for the rod not to start moving the torque has to be zero. Torques of the forces from the hinge are 0, because the lever arm is 0. From calculating the torque you would get that d1F1=d2F2
When I first learned about 'Machines', we were told that Velocity Ratio and Mechanical Advantage were two different things. VR is governed by the geometry of the machine system and can be derived without experiment. MA involves knowledge of the masses of the parts of the machine and the friction (practical aspects, which need to be measured) . Then
Efficiency = MA/VR
and you can't ignore efficiency.
That is obviously true, if you assume enough "axioms" of Newtonian mechanics. Real-world engineers "deduce" how new design concepts will behave all the time, before they build anything to "experiment" with!
But I'm still not really sure what you are trying to achieve here, since "gravity" is not a very obvious concept. For example if you make the pre-experimental "common sense" assumption that objects with different masses fall with different accelerations, you would come to a different conclusion about levers (or, you wouldn't come to any conclusion at all if you didn't have some clear ideas about "force" that were probably based on experiment).
And "conservation of energy" is VERY non-obvious concept - it wasn't nailed down till hundreds of years after Newton and Galileo, let alone Archimedes.
Conservation of angular momentum works fine in the static case, and you can derive it from Newton's laws.
AlephZero said:
But I'm still not really sure what you are trying to achieve here, since "gravity" is not a very obvious concept. For example if you make the pre-experimental "common sense" assumption that objects with different masses fall with different accelerations, you would come to a different conclusion about levers (or, you wouldn't come to any conclusion at all if you didn't have some clear ideas about "force" that were probably based on experiment). .
The law of the lever being a simple consequence of gravity and the conservation of energy I thought maybe of some value to physics education (some students find the lever mysterious for example see: True Explanation of a Lever...please. ).
Maybe I am mistaken but I was under the impression that gravity and the conservation of energy are both topics that are covered in a beginning physics course.
Levers work with or without the help of Gravity, though.
Virtual Work, otoh, can be invoked anywhere and is an excellent, valid, approach. Why would one want to use only the intellectual tools that were available to 'the Ancients'?
Could you please explain what you mean by a lever working without the help of gravity.
How about a pair of scissors?
If I understand you correctly, it seems that you are suggesting that the conservation of energy notion is dependent on the law of the lever. If this is so then I would appreciate if you could please explain how you came to this conclusion.
Thanks for the example. However, outside of a constant force field the law of the lever does not hold.
Are you referring to what I would know as the 'Principle of Moments'? If not, then you can make any statement you like in the context of ancient Science and I would not necessarily disagree. But how relevant would it be?
This is not what I said. You require independence of experimentation with the lever. You deem conservation of energy so independent. However, as a matter of fact, conservation of energy was historically deduced from certain principles of mechanics, all of which were based on experimentation, with the lever in a particular. Besides, this principle, even if very powerful, is not as general as the principles it is usually derived from. So, to me, accepting this principle but not some others seems quite arbitrary.
I am referring to the Theorem 1 from the paper here: http://www.math.csusb.edu/faculty/pmclough/LP.pdf.
I read it but does the result mean more than the principle of moments? You wrote it, so you presumably can tell me what you meant.
A lever is a lever, wherever it's used and the same calculations apply, surely. You chose to derive a relationship, using a particular scenario but a lever will work the same in all conditions, surely (?).
I agree that what we choose to take as our axioms is quite arbitrary. I chose to prove the law of the lever by taking gravity and the conservation of energy as the axioms for the following reasons:
1.) Gravity and the conservation of energy are both topics that are covered in a beginning physics course;
2.) The proof is a simple consequence of these axioms;
3.) Some students find the lever mysterious and may benefit by being exposed to the proof.
It would seem that if I removed gravity then any two masses placed anywhere on the lever would balance the lever.
More mysterious than the conservation of an abstract quantity called energy? Usually, when someone ask why a lever works, he seeks an explanation based on static forces. Not on conservation laws, which are non-obvious themselves.
You could use a lever to open a stuck door on the space station.
How about forces from two springs, pulling on the lever? Or two rocket engines? etc. etc.? It is surely the Forces and not their origin that counts here.
You still haven't said whether you are referring to the Principle of Moments (very / universally known to apply to levers and many other arrangements). I imagine you know what I mean? Your analysis isn't 'wrong', it's just that I can't see anything special about that paper. Could you point it out if there is anything?
But then your proof is only valid for a lever in a uniform gravitational field. Which, to me, is too restrictive. While this is an important case, levers work just fine with arbitrary forces, not just gravity, and those forces are not always applied at the right angle to it.
  • · Replies 42 ·
  • · Replies 32 ·
  • · Replies 31 ·
