Can We Generate Energy by Drilling Deep Ocean Holes?
  • Thread starter Thread starter Erazman
    Energy Gravity
The discussion revolves around the feasibility of generating energy by drilling deep ocean holes to harness geothermal energy from the Earth's crust. Participants explore theoretical models, technical challenges, and potential energy outputs, considering both the practicality and implications of such an approach.
  • Some participants propose drilling deep holes into the ocean to access extreme heat from the Earth's crust, suggesting that a generator could be set up at the bottom to harness energy from evaporating water.
  • Others highlight the significant technical challenges of drilling and maintaining such a system, including the potential disturbance to ocean life and the costs involved.
  • A participant suggests that the peak power output would depend on the flow rate of water and discusses theoretical efficiency based on temperature differences, estimating potential energy outputs.
  • Some participants introduce speculative ideas about using aether theories and magnetic systems to generate energy, although these concepts are met with skepticism from others.
  • Concerns are raised about the cooling effects of rising steam and the potential for clogging the system with condensed water, questioning the sustainability of the proposed energy generation method.
  • Discussion includes comparisons to existing geothermal power systems and the challenges of maintaining energy output over time due to cooling of the heat source.
Participants express a range of views, with some agreeing on the theoretical potential of the concept while others raise significant concerns about practicality and sustainability. No consensus is reached on the feasibility or efficiency of the proposed energy generation method.
Limitations include unresolved assumptions about the efficiency of energy transfer, the impact of cooling on the geothermal source, and the technical feasibility of drilling and maintaining deep ocean holes.
  • #31
In the game "sid meir's alpha centauri" one can play with what they call "bore holes" and play with geothermal energy in this way. These are holes that go down to where the rock is hot and produce power in this way much like what people are talking about here.
  • #32
There a e already methods of harnessing energy from gravity (like from the flow of water), but not in very massive amounts. What if we drilled a very deep hole into the ocean (down to the extremely hot farthest reaches of the crust where water will evaporate easily) and set up a generator at the bottom?
cinci: Some of the heat at the center of the Earth was caused by gravity, but that would have cooled long ago. The heat we get now is primarily from decay of radioactive materials.
Have a massive pipe connected from the ocean water to the bottom of the pit. The hole won't fill up with water if ventilate the steam to the air above the ocean (driven by the difference in pressure). Mineral Insulated cables could be run down to the generator. I'm talking extremely hot conditions here to allow the massive amount of water flow to evaporate ASAP.. we would actually be using the Earth's heat as a driving force to return the water...
Law of Convservation remains unbroken.. because the steam that rises back up the hole has lost its potential energy from the deep pressures of the ocean and the gravity of the hole... and has given it to us.
There's already a thread on here that talks about harnessing energy from the bottom of the ocean, but not from BENEATH the bottom of the ocean.
cinci: Harnessing the tides is possible. They are gravity driven.
  • #33
HallsofIvy said:
Hydro-electric plants get power from gravity all the time!
Sorry to bring back an old post, but no they do not get the power from gravity. They get the power from the Sun, which brought the water up to a higher level than previously.
  • #34
Er... what?
  • #35
xxChrisxx said:
Er... what?
The Sun converts nuclear bonds into energy through nuclear fusion. The energy then travels to Earth where some of it warms water and causes it to evaporate. The warmed water vapor rises and gains gravitational potential energy. Eventually the water falls as rain and ends up at a higher elevation than it was at the start. As the water flows downstream to a lower elevation we force it to turn turbines to capture some of its energy.
Thus, the energy we get in hydroelectric plants comes from nuclear fusion in the Sun. Energy is conserved, at no point is it created or destroyed. Energy never comes from gravity, it is a force not a source of energy.
  • #36
I still find that an utter crock of a statement as by some level of abstraction all energy comes from the sun. Which although true is not really very helpful.
So purely from a practical point of view, all we care about is the gpe of the mass of water has, not how it got it in the first place.
  • #37
Really, it is a matter of where you draw your system boundary, so I wouldn't get too worked-up about either statement.
  • #38
All energy comes from the sun? I think your statement is crock. When nuclear power plants split atoms, this power is coming from the sun? Or is it coming from the mass that big bang somehow put here? was the sun responsible for that mass being "here" in the first place?
Does our electricity that a generator produces come from the magnets then - since they have potential being rubbed off em kind of like how gravity pulls things out of place.
Really, I am just being pedantic and posting statements to create heated arguments.
  • #39
That's the definition of trolling. Please stop.
  • #40
Not to feed you or anything but, the most important bit of the statement was "...by some level of abstraction...". So in reality you can keep tracing 'how the energy got there' through some bloody tortuous path to get it back to the sun/universe/whatever. As Russ said where do you draw the boundary.
The point was that from a design point of view that is totally useless to know what the energy has done in the past. Making a machine to harness stored gpe, i'll use the practical and simple notion that yes the energy does indeed come from gravity (gpe) as it is the most convenient starting point for a design.
  • #41
What about getting the water up through evaporation/boiling and then harnessing the water flow on the way down?
  • #42
technically, neither the sun, nor gravity could do it alone, so we can say neither is directly responsible for the process alone.
but, gravity is the force we are worried about for engineering purposes. we can control getting water to the power plant, but not the force exerted upon it.
dr
  • #43
In my mind, the problem to focus on is maximizing the capillary action to pull fluids up through gravity. Then condensing the fluid to harness the flow on the way down. A miniature rain machine.
  • #44
it would be better to have a big satellite orbiting Earth and harvesting solar power, and sending it wireless to a receptor, that would distribute electricity to the Earth homes...
i think electrity companies donnt want that of course to happen. free energy EHEH noo..
  • #45
Is that possible? Not a bad idea.
However, I do have a business plan for utility and oil companies that will work with this energy machine. Both types of companies will be very profitable.
Here's the idea in a nutshell:
- intramolecular forces are the root of thermal motion and kinetic theory
- strength of intramolecular forces is a function of temperature
- fluids leveraging natural evaporation/condensation will carry water up against gravity
- harnessing energy from gravity is then possible
This in no way is a perpetual energy machine nor does it break any laws of thermodynamics. With respect to thermodynamics, gravity is frequently ignored in most analyses of kinetic energy.
  • #46
Because of the first law of thermodynamics. It would consume energy to evaporate/boil the water. You could never get more energy out then what is put in. It's easiest to let the sun to the evaporating.
It would take energy to remove the water from the top of the capillary tube.
To paraphrase Homer Simpson: "In this forum, we obey the laws of thermodynamics."
  • #47
The energy to condense water comes from intramolecular forces (hydrogen bonding).
Removing the water from the top of the capillary tube is performed by gravity.
Don't forget about the force of gravity in perceived thermodynamic limitations.
Consider: increasing the condensation rate of water vapor by electrifying a condensation rod. That uses a very slight amount of energy and leverages already existing intramolecular forces (hydrogen bonding). Once a water droplet forms, gravity pulls it off that rod. Imagine that water droplet accelerating as it falls 20m. The energy in that moving water droplet is greater than the tiny current required to attract a few water molecules out of the air. With some intelligent choice of materials (maybe silver iodide) that leverage the pre-existing hydrogen bonding tendencies of water and you wouldn't even require a current.
  • #48
It seems to me that people constantly confuse 'free energy' that breaks the laws of thermodynamics, and energy that costs nowt. (ie is 'free')
  • #49
Yes, perhaps I was misunderstanding what was being said/meant earlier.
Here is my problem with that: if the force drawing the water into the capillary is stronger than gravity, then gravity is too weak to remove the water from the tube. And if the capillary force is weaker, then the water will not move up the tube in the first place.
I have never heard of doing this. Do you have any references, or a link showing an actual working demonstration of this? Also, does "electrifying" mean applying a voltage & creating an electric field, or passing a current through the rod, or something else?
  • #50
Capillary force is determined by the electromagnetic charges of the molecules. Different molecules have different strengths, so you could have a 2 material tube. Strong at first that pulls up, slope down on the weaker strength tube and gravity will overcome the cohesion.
No references. It's an idea I had about 4 weeks ago and am researching now. Given that hydrogen bonds are essentially a magnet, this seems doable. FYI, I do consider hydrogen bonds as the same force governing "capillary action". Just on the molecular level.
  • #51
I really mean no offence by this but... what utter crap.
The single biggest overriding factor that governs capillary action is having a very narrow tube and the relative pressures at either end.
Water isn't attracted by 'magnets' like you are thinking becuse it has a dipole, the attraction has to be induced and water has extremely low permeability. (Ie it doesn't magenetise well.)There is much much more interesting (similar) thing being done like this already. It uses a membrane and salt and fresh water. Due to the different concentrations the water crosses the membrane by osmosis raising the levels and forcing the water up and through a nozzle that drives a turbine.
Only really any good if you live next to a river and the sea but, it's pretty cool.
http://news.bbc.co.uk/1/hi/world/europe/8377186.stm
I'm trying to find the video I saw of it.
  • #52
Where gravity overcomes the capillary force, the water will stop rising in the tube. It won't make it to the top.
Hydrogen bonds are not "essentially a magnet", they are electrostatic in nature.
To put things nicely but honestly, it sounds like you do not actually understand the science behind what you are proposing.
  • #53
Um... what do you think "dipole" and "electrostatic" are? They are forms of ELECTROMAGNETISM.
Why do you think water molecules form hydrogen bonds? The negative charge of the O is attracted to the positive charge in the H. That's essentially a magnet my friends.
Why is water attracted to its glass container? Well.. take a look at the structure of a molecule of glass. Lots of H's my friends. What is attracted to those H's? Why that would be the O's in the water molecules.
Why does water evaporate most quickly in butane? Again... take a look at a butane molecule. A few C's surrounded by a bunch of H's. What is attracted to those H's? Well a bunch of O's in water molecules.
It is YOU that doesn't understand the science. Why don't YOU explain water cohesion and its attraction to glass? If you use "dipole" or "electrostatic", please look up the words first.
  • #54
'Essentially' a magnet. Do you know what permeability is? Water has a similar permeability to air and aluminium. They don't respond to regular strength magnets, and neither does water.
  • #55
Individual molecules act as tiny magnets with each other, but the effect is not additive across chains of hydrogen-bonded molecules.
EDIT: water molecules are affected by electromagnetic fields. EG. microwaves will spin the molecules.
  • #56
Did you learn this chemistry in school or are you going on your own deductions?
  • #57
This is all just mental masturbation. You try to 'suck' water up using a magnetic field it WILL fail. Water just doesn't magnetise, that is really as simple as it gets. You can use magnets to polarise molecules (a la NMR machines), but this is a very far cry from acutally moving molecules with them.
Applying a strong magnetic field does have a very small effect on the surface tension. By stong I mean on the order of 100000's gauss to give small percentage changes in surface tension.
Top marks for creative thinking. However like all things, creative thinking and pratical useage are worlds apart.
  • #58
I agree. You won't suck up water using magnetism. But individual molecules do respond to electrical charge.
The strength of the charge of a single molecule is a function of where the electrons are in relation to the protons. On water, the hydrogen atoms' electrons are covalently bonded to the Oxygen so the Hydrogen's protons' positive charge is exposed. Since there are 2 un-bonded electrons on the Oxygen, that side is negatively charged and can attract the Hydrogen side of another water molecule. That attraction is electromagnetic, but the effect is certainly not additive, so hydrogen-bonded water molecules are not going to form a magnet.
At high temperatures, the above is not a huge effect because hydrogen bonds are weakened, however at room temperatures, this effect is important. I am trying to find ways to accelerate condensation of water vapor at room temperature.
  • #59
look water is magnetized like matter is.. just check those videos on youtube with high power magnets and you will se water foating like zero-G
  • #60
and we all know no one fakes stuff on utube
like the cell phone popcorn thing
somehow the idea of a magnet that strong brings the image to mind of the coyote road runner cartoons, where the coyote shallows the magnet, then everything magnetic comes chasing after him
dr
  • · Replies 42 ·
  • · Replies 23 ·
  • · Replies 32 ·
