Can we hear a supersonic plane?
136 replies · 22K views · last reply
On a bit of a side note, the boom you typically hear from a supersonic jet at a relatively large distance is a normal sound wave that the shock wave degrades into as it's amplitude diminishes over distance and time. An actual shock wave sounds more like a crack, as heard in this video:
This is in actuality a fascinating discussion. I do have an additional bit of input to throw in that I will not attempt to calculate as it might make my brain hurt.
I know and often demonstrate for classes that it is possible to cancel all sound when the two waves are 180oout of phase. Of course with low frequencies this is easy to accomplish perfectly with little effort. As frequency of the sound increases it is easier to approximate due to reduced wave length but less effective as the interaction is more limited.
To actually calculate this with a broad spectrum sound on the compression side of two different doppler shifted waves, well one would have to pitch in for a lot of my time to see how it goes.
CalcNerd said:
all sound between the tail and point of the aircraft have to reside between the two booms
mfb said:
it is clearly wrong, as you can hear supersonic aircraft after their sonic boom(s).
I am very much enjoying sitting back and just learning from the discussion. But while not yet understanding what happens to sound emitted from the body of the plane, and the extent to which its propagation is constrained, I do have a theory - which I advanced in the OP - as to why we can still hear a supersonic plane after the boom passes, even if the two booms did somehow prevent the propagation of sound from the plane body. Here it is:
andrewkirk said:
My initial reaction was that of course that is wrong because a ground observer hears the sonic boom and then hears a lower, continuous roar. But I thought that what we might be hearing there is not the engines themselves, which [arguably might be] shielded from us by the [front and rear booms], but the noise of the jet stream that is fired backwards by the engines, as it hits the air behind the [rear boom]. Because that collision occurs outside of the [putatively] sonically shielded region immediately around the plane, it is free to propagate and so we can hear it.
The picture in @jack action's post 27 shows this jet stream extending beyond/behind the rear 'boom'. The gas is ejected so fast that it is essentially a powerful, incredibly high-speed projectile that laughs derisively at boom regions as it smashes through them at super-supersonic speeds.
mfb said:
Sound backwards and forwards.There is no limit on the time you get backwards sounds. The sounds played 1 minute before you hear the airplane have been played at a distance of about 2 "sound-minutes", so you'll hear them two minutes after the airplane passes you. Well, in theory, because hearing sound over ~40 km distance is impractical.
How? At the very least, sounds trying to travel away from the plane forward will be overtaken and obliterated by the plane. And it is my understanding that the whole forward arc from the points tangent to the mach cone are part of the mach cone because they are emitted on the cone.
It is overtaken (by the rear shockwave), but the signal is still there. Assuming you don't have some object so blunt and fast that you are really creating a good vacuum over a large range.
The sound simply does not care (in any relevant amount) about other sound or shockwaves nearby.
I suspect it is not. Air is not elastic ie there comes a point when the pressure simply compresses the air beyond any elastic limit and produces heat. A 120+ dB (I suspect the sound is much higher, but even 120dB would exhibit this effect) sound/sonic wave will simply crush out a 60 dB conversation. I would like you to provide some type of theoretical argument otherwise. If we were talking electrical signals, I would be on board with your reasoning. However, air reaches a compression limit where it turns into heat instead of allowing another signal to ride on top of this sonic boom that you seem to believe can carry information from inside of the aircraft.
You are the one suggesting some additional effect. Where is your theoretical argument?
My argument again relies upon the obvious (for me, anyway). You are trying to capture information on the other side of (or thru) a sonic wave front (Shock wave). As I alluded to earlier, the air is compressed beyond its sound transmission range into a heating range ie acoustic heating where the air molecules cannot resonate fast enough and are simply crushed together by a sonic wave. I can see no way that you can provide any mechanism to put information on a wave form that is cropped off by thermal upper limit ie the air will only resonate at some upper frequency (speed of sound), beyond that it just booms and heats on the intensity of the sonic wave ie it has a maximum value (wiki, not a great source) of 190 dB. Of course this value drops off as the wave front travels away from the plane. However, simple math on a limit is 190 + anything (your sound wave/voice) = 190 db. The tail sonic wave boom is this limit of information (I am still at a loss of how you propose to do a frequency analysis and capture the information on the other side of a sonic wave front).
While Jack Action provided sound and pressure waves as two separate examples, they are actually the same example, just at different scales. Sound is simply a pressure wave of a far lower scale. I am stating that the air cannot theoretically carry any information once it is compressed by a sonic boom other than energy information. A spectrum analysis of any exotic form will not recover sound information inside the aircraft cabin ie you will not be able to listen to their music. (we are restricting our argument to sound waves, not laser measurements of the sound perturbation on their cabin wall).
So I am simply asking you to provide your theoretical solution to overcome the above hurdle. I don't see or seem to understand what I have stated is not obvious. Where is the flaw in my logic.
The shockwaves of planes at the relevant distances (10+ meters, where the shockwave meets the sound from the cabin) should be far away from 190 dB. Maintaining a perfect vacuum in a disk with 10 meter radius would require a power of at least 20 GW (31 MN at ~700 m/s), even if we ignore overpressure ahead of the aircraft. That is completely unrealistic, even the most powerful engines just give 100-150 kN thrust.
Why did you link to binoculars?
Deleted binoculars. Was going to respond to another thread and didn't delete.
The sound inside the cabin needs to be captured through the shockwave, doesn't it?
Where did I say anything about a perfect vacuum (or any vacuum)? But since you bring it up, the aircraft does leave a vacuum in its wake (and you are correct, it is not anywhere close to 10 meters in radius, it is what creates that small tail sonic wave front, with the energy content of some ratio of the engine energy as you surmise), and that vacuum plays into my argument as well. Sound doesn't carry through a vacuum.
What does "captured" mean? The sound can travel outwards (and forwards as seen from the ground), a bit later the shockwave passes through it.
If we let the sound be emitted 5 meters in front of the end of the aircraft, and consider the part emitted in a 45° angle forwards (as seen from the ground), then the sound hits the shockwave at a distance of 25 meters from the flight path of the mach 2 aircraft.
The ~190 dB value corresponds to it.
How in the world do you come up with this? The sound hits that shockwave much closer than 25 meters. I suspect we should pick an aircraft for reference (it seems that you are referencing a common diagram on the web, the true sonic cone envelopes as tightly as possible). However that sound is also sandwiched between the two shock waves, so you have a very brief amount of information that you can gather. I concede that iff you can maintain a sound sensor between the two shock waves, maybe there is a conceptual window to listen into the music inside the cabin. That window is the time distance of the length of a clean aircraft (in feet)divided by its feet / second speed. A sample calculation reveals that a 50 foot F-16 traveling at 850 mph (1250 ft/sec) has a sonic window of 1/25th of a second. Could you make out what song that pilot was listening to? That is a very brief window to capture anything. Keeping up with the aircrafts sonic shadow is not how I envisioned your solution. I believe the implied solution is to capture your information from behind the 2nd sonic tail boom.
Do you have such a solution?
As far as 190 dB, that is the maximum value of noise possible (according to wiki). That noise is when the air is compressed in front of an aircraft and it cannot move out of the way fast enough, hence a sonic boom.
Geometry. But I made a mistake, the value is actually 108 m.
Using v=340 m for the sound (it cancels out in the distances) sound and shockwave hit each other 450 milliseconds after the sound is emitted, 108 meter forwards and 108 meter outwards compared to the sound emission point. The airplane, before emitting the part of the shockwave that hits the sound, moves 54 meters, which needs 79 milliseconds. The shockwave from the tail of the aircraft then travels 121 meters, which needs 356 milliseconds.
If you disagree, find a faster way the shockwave can reach the sound.
Repetition won't make it right.
That solution is what we are discussing the whole time?
Am I arguing with a Wikipedia article?
Imagine being right under the plane, already inside the cone, in the right picture:
Why the whole forward arc? Only the parts emitted at 90deg - alpha form the cone.
Let's back up a bit and think about the acoustics of projectile motion; is there anything beyond the sonic boom from near misses by bullets?
That misses the point. Bullets do not generate well defined ordered sound events that could be heard in reverse.
I suggest an experiment. Go look at a paddiling duck. They travel faster than the velocity of surface waves in water. Thus they put out a v shaped wave. Now you need to make a rythemtic disterbence on the surfave of the water and move it at a velocity faster then the surface waves and you will see the answer.
I was thinking that for the problem at hand maybe one shouldn't focus so much on the shockwave of airplanes but on how to model an ideal supersonic sound source. Theoretically simplest is probably an infinitely thin airfoil whose curvature is changing slightly in positive and negative direction. There even exist analytical solutions in the supersonic region called Ackerets formula. But as long as the airfoil is flat, there will be no sound or shockwave at all. Looking now at the special situation that the sound consist of two short clicks separated by time t, the relative order in which the two click will be heard by an observer will be different whether the observer is in front or behind the flying airfoil. So yes, in principle music can be heard backwards. The situation is not different from the order by which two firecrackers will be heard which are fired at different times at different locations.
Neither do planes, for that matter.
There's some good and some bad in this discussion. Sound and pressure waves are the same things but people get confused because of the different magnitudes typically involved. Shocks are nonlinear phenomena, and can't form in a linear medium. When a sound wave interacts with a shock, it is very unlikely that it will come out the other side unchanged. Most likely the wave will undergo some degree of additional attenuation because shocks are highly dissipative. They wouldn't necessarily be completely destroyed, though.
Also, you can certainly hear sound behind the final boom. It's going to sound substantially quieter than the boom itself, but it will be there, especially if it was emitted from a region downstream of the final Mach cone such as by the engines on a fighter plane.
Finally, there's no need to argue about shock angles. There's a simple geometric explanation for the angles of Mach cones. The Mach angle is:
[tex]\mu = \arcsin\left(\dfrac{1}{M}\right)[/tex]
Supersonic fighter jets can for example fire their cannons, in two clearly distinguishable burst (e.g. different number of shots). If the plane then passes a detector close by, that detector would first detect the sonic-booms(s), and then the cannon sounds in reverse order.
Literally any sound, constant or not, will be detected after the sonic boom due to the limitations of sound speed in the medium. The observer would just hear a mix of the gun firing both in reverse and forward briefly before hearing it all forward, just like any sound.
What about a piezoelectric speaker traveling in the direction of its plane & with a surface that could travel at mach 2 plus a little bit? Aside from being materially impossible.
Why would he hear the same shots multiple times? To clarify: Both burst are finished before the plane passes him. And I'm talking about the gun sounds, let him fire blanks for simplicity.
"Sound waves are linear to a good approximation, there is no destruction going on."Sound may be linear under normal, everyday situations but it will not be linear under extreme conditions like the bow wave of a supersonic aircraft.
What you are trying to suggest is that we should be able to record the sonic boom and pick out the police siren in the recording. I don't believe that for a minute.
As for playing backwards, nothing is heard upstream of the sonic cone ( let's limit this to one sonic boom from the nose for simplicity. ) An observer on the ground , or any other non-axial position of observation will hear sound from the aircraft once it has passed and they are BEHIND the sonic cone. At this point the aircraft is going away from the observer, fast.
There is NO sound coming towards the observer from behind ( in the direction from which the plane arrived ). AFAICS, this whole idea of sound playing backwards, is based on the simplistic and inappropriate 'spherical' wave-fronts which do not apply to a supersonic sound source.
There is a strage idea here that sound is left behind the plane, traveling in forwards direction. The only sound moving forwards contributes to the shock wave and any sound information is lost.
[EDIT]
I've just seen A.T's comment #45
https://www.physicsforums.com/threads/can-we-hear-a-supersonic-plane.881162/page-3#post-5540053
This diagram puts the 'spherical' waves in their correct context. I do not see how anyone can conceive of hearing sounds in a reverse order. The older waves always arrive first.
I like the idea of firing the cannon a lot better than the supersonic ghettoblaster.
If the plane fired it's cannon whilst over the observer ( he is in front of the sonic cone ) , he would never hear those shots. Neither backwards, not forwards.
He can only hear shots fires after the shockwave has passed.
The following is the best I've been able to come up with so far, as a practically feasible experimental demonstration of the backwards sound phenomenon:
A plane traveling forwards at Mach 2 fires three exploding shells backwards, at speeds of Mach 1.2 relative to the plane, at times t, t+1, t+3, each programmed to explode after time T, which is the minimum time such that the explosion would be far enough away from the plane to not endanger it.
The shells explode behind the rear boom, at times t+T, t+T+1, t+T+3, and in each case is at the same displacement vector from the plane at the time of the explosion. So we can consider those explosions as part of the supersonically moving phenomenon or system of the plane.
The intervals between explosions, in the reference frame of the plane, are 1 second, then 2 seconds.
But for an observer on the ground that is well in front of the location of the last explosion, the explosions are heard at intervals 2 seconds, then 1 second. That is, they are heard in reverse order.
Because the shells were traveling subsonically prior to exploding (at Mach 2 - 1.2 = 0.8), there is no sonic boom of the shells to complicate the analysis.
In the above scenario, the backwards pattern of shells is heard after the boom.
If the shells were instead fired forwards, a ground observer in front of the plane would hear the explosions in reverse order before the boom, but the analysis would be complicated by having to consider what effect the sonic boom of the shells themselves (which are traveling at Mach 3.2) had on the sound wave of their explosions.
This highlights the basic problem of the reverse play idea. You need to introduce a contrived means to have a secondary source of sound propagating in all directions behind the plane, including forwards. This will not happen with the plane as the source of the original sound. This does not provide a means to suggest that the firing the planes cannon would be heard in reverse playback.
Firing the cannon seems to give the most useful conceptual framework for examining how sound will propagate from a supersonic aircraft.
I see no credible explanation of how wave-fronts emanating form the plane could arrive at an observer in reverse order.
The diagram shows the exact opposite, of what you claim it shows: If the supersonic plane passes very close to the detector, the youngest signal (smallest circle, emitted most to the left) will reach the detector first. Thus the signals are detected in reverse of the emission order.
Maybe an animation can help you:
https://upload.wikimedia.org/wikipedia/commons/e/e4/Dopplereffectsourcemovingrightatmach1.4.gif
