Can we rewrite Schrodinger equation using observable variable?
The discussion centers around the possibility of rewriting the Schrödinger equation in a form that utilizes only the observable quantity Ψ·Ψ* (the probability density) instead of the wave function Ψ, which is not directly observable. Participants explore theoretical implications, mathematical transformations, and connections to density functional theory (DFT).
  • Some participants propose rewriting the Schrödinger equation to eliminate Ψ in favor of Ψ·Ψ*, suggesting that this could clarify conservation laws.
  • Others challenge this idea, asserting that such a transformation is not feasible.
  • A participant introduces a mathematical formulation involving real variables R and S, indicating that reducing the equation to a single observable variable changes its nature.
  • Connections to density functional theory (DFT) are made, with some arguing that while DFT is based on the concept of observables, it is an approximation and not fully equivalent to the Schrödinger equation in all contexts.
  • There is discussion about the limitations of DFT, particularly its applicability to ground states versus the broader scope of the Schrödinger equation, which encompasses all states.
  • Some participants express the need for proof regarding the equivalence of DFT and the Schrödinger equation across all states and phenomena.
Participants do not reach consensus on the feasibility of rewriting the Schrödinger equation as proposed. There are multiple competing views regarding the implications and limitations of DFT in relation to the Schrödinger equation.
Limitations include the dependence on definitions of observables and the unresolved nature of the mathematical transformations discussed. The discussion reflects varying interpretations of DFT and its relationship to the Schrödinger equation.
phdphysics
We know that in Schrödinger equation, Ψ is called wave function, which is not observable, while Ψ·Ψ* is the probability, which is observable.
can we rewirte the Schrödinger equation to a form without Ψ but only Ψ·Ψ*?
because I think, in this way can I figure out all conservations in the equation. Although I can make it with present Schrödinger equation, it's obvious that the Schrödinger equation will change if I make t→-t transformation.
Thanks~
Write down the equation of motion for [itex]\psi^*[/itex] given that [itex]\psi[/itex] fulfills the usual Schrödinger equation. Then change [itex]t \rightarrow -t[/itex]!
you mean, this equation set(containing two equation, Ψ and Ψ*) does not change?
by the way, could you tell me, can Schrödinger equation be rewrited to Ψ·Ψ* mathemetically?
thanks
No, we can't.
Define
##\psi = R \, e^{iS}##
with two real variables R and S.
Then introduce
##\rho = \psi^\ast \psi = R^2##
Now we see that an equation in R or ρ is an equation in one single real variable, whereas the original equation was an equation in two independent real variables R and S.
Thanks~
That's essentially the idea behind density functional theory (DFT).
But that's an approximation.
If you mean that the DF theory itself is an approximation - no, it's exact. Practical implementations are approximations, however.
But DFT works only for the ground state, whereas the SG works for all states including all bound and scattering states.
DFT works for the lowest states of a given symmetry, of which there might be several. The calculation of excited state properties (e.g. absorption spectra) can be carried out using time-dependent DFT. More information here: http://en.wikipedia.org/wiki/Time-dependent_density_functional_theory.
I still think that this answer is missleading in our context. Otherwise you would have to prove that DFT is fully equivalent to the SG including the complete set of states (bound plus scattering states) in Hilbert space plus all derived phenomena like superpositions, interference, entanglement etc.
  • · Replies 39 ·
  • · Replies 17 ·
  • · Replies 143 ·
13K
  • · Replies 32 ·
