What is the reason behind bioluminescent displays in phytoplankton?
  • Thread starter Thread starter AryaUnderfoot
Bioluminescence can be observed under normal circumstances, but certain organisms, like Aequorea victoria, may require specific conditions to display their bioluminescent features, such as a green ring at the margin of their bell. This ring is often not visible unless the jellyfish is disturbed. While some bioluminescent phenomena, like fireflies, can be seen with the naked eye, researchers may use fluorescence microscopes to examine finer physiological details that are not visible to the naked eye. The discussion also highlights that many aquatic organisms can control their fluorescence, often in response to environmental stimuli, such as turbulence in the water, which can trigger bioluminescent displays in phytoplankton. The use of Green Fluorescent Protein (GFP) and other chemical drivers like Aquorin in research is noted, with GFP being more convenient for study despite the jellyfish's complex bioluminescent mechanisms.
AryaUnderfoot
Can we see it under normal circumstances? Or do we need the help of special UV light source to see it? I've read that Aequorea victoria can emit bioluminescence with a ring of green dots at the margin of its bell, but normally it is almost invisible to us. What does that mean?
Biology news on Phys.org
I've seen it first hand with normal sight at a bioluminescence bay in Puerto Rico.
Are you specifically asking about A. victoria or bioluminescence in general? In the latter case the answer is unequivocally yes. The most famous example is probably the firefly, which really are quite something if you ever go to a country that has them.
Likes Greg Bernhardt
About A. victoria.
I mean, if we can see the green ring under normal circumstances, why would we need a fluorescence microscope? And I read that they don't usually produce the ring, unless they are disturbed? I couldn't quite grasp that
If you look on youtube you can find a few videos, shot by regular cameras, where the bioluminescence can be seen. As for why a microscope would be used it's likely so that you can see more physiological detail than your eye can provide.
I have seen it in the Florida Keys, there is an organism (do ask I do not remember) that when you stroke the paddle into the water the volume around the paddle lights up.
The (GFP: Green Fluorescent Protein) fluorescence researchers use under a microscope is only one component of what the jellyfish uses. Prior to the isolation of GFP, a large complex (Aquorin) was isolated which is calcium activated and has chemically driven emission of light.
The jellyfish's chemical drivers (chemo-luminescence) aren't often used by researchers because fluorescence is more convenient.
Aquorin used to be used as an intracellular calcium detector, but there are better things for that now.
Aquatic organisms have ways to control when their show their fluorescence so they can turn it off at certain times. This includes a lot of them which have symbiotic bacteria that actually do the fluorescing.
  • · Replies 16 ·
9K
  • · Replies 25 ·
